Hi there, i recently was installing minggw on my computer, separate from the msys2 install. Since then, i keep getting "Can't run interactive configuration inside non-interactive build process" "Open a command line terminal and run 'make menuconfig' from there"
... This is inside of msys2 mingw shell when running make menuconfig.
Does anybody know what i can do about this? I re-installed msys2 and i updated my esp-idf to the latest version.
- ESP_Roland
Re: "Can't run interactive configuration inside non-interactive build process"
It seems to me that your BATCH_BUILD variable is permanently set.
Does
produces any output (or value 1)?
Does
echo $BATCH_BUILD
That was it! how did you figure this one out? Thanks.
Fix: ensure "BATCH_BUILD" is not defined as an environment variable in windows, to ensure the above problem does not continue.
Users browsing this forum: Bing [Bot] and 77 guests
