Page 1 of 2
guru meditation error
Posted: Wed Dec 26, 2018 10:08 am
by burkulesomesh43
Hi all,
I am getting this error-->>
Guru Meditation Error: Core 0 panic'ed (LoadProhibited)
. Exception was unhandled.
Core 0 register dump:
PC : 0x4008fb06 PS : 0x00060533 A0 : 0x40091aef A1 : 0x3ffd83b0
A2 : 0x00050523 A3 : 0x00000000 A4 : 0x3ffc5148 A5 : 0x3ffc5148
A6 : 0x60033c68 A7 : 0x3ffd3588 A8 : 0x00000018 A9 : 0x00000000
A10 : 0x3ffc1100 A11 : 0x00000000 A12 : 0x3ffc5330 A13 : 0x00000000
A14 : 0x00000000 A15 : 0x00000000 SAR : 0x0000001c EXCCAUSE: 0x0000001c
EXCVADDR: 0x0000000c LBEG : 0x4000c2e0 LEND : 0x4000c2f6 LCOUNT : 0xffffffff
Backtrace: 0x4008fb06:0x3ffd83b0 0x40091aec:0x3ffd83d0 0x40091aa2:0x00000000
Rebooting...
ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x1b (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:5800
load:0x40078000,len:0
ho 12 tail 0 room 4
load:0x40078000,len:15000
entry 0x40078630
Not getting what is the reason.
please help me out for this.
Re: guru meditation error
Posted: Wed Dec 26, 2018 11:57 pm
by fivdiAtESP32
Did you run the program with "make monitor"?
If not, give it a try. With a bit of luck it will display a trace log showing where the error occurred.
Posted: Thu Dec 27, 2018 5:21 am
by burkulesomesh43
fivdiAtESP32 wrote: ↑Wed Dec 26, 2018 11:57 pm
showing following error by make monitor-->>>
0x4008fb06: vTaskSwitchContext at C:/esp32/esp-idf/components/freertos/tasks.c:3564
0x40091aef: _frxt_dispatch at C:/esp32/esp-idf/components/freertos/portasm.S:407
A2 : 0x00050023 A3 : 0x00000000 A4 : 0x3ffc5150 A5 : 0x3ffc5150
A6 : 0x00000001 A7 : 0x00000000 A8 : 0x00000018 A9 : 0x00000000
A10 : 0x3ffc1100 A11 : 0x00000000 A12 : 0x3ffc5338 A13 : 0x00000000
A14 : 0x00000000 A15 : 0x00000000 SAR : 0x00000015 EXCCAUSE: 0x0000001c
EXCVADDR: 0x0000000c LBEG : 0x00000000 LEND : 0x00000000 LCOUNT : 0x00000000
Backtrace: 0x4008fb06:0x3ffd8470 0x40091aec:0x3ffd8490 0x40091aa2:0x00000000
0x40091aec: _frxt_dispatch at C:/esp32/esp-idf/components/freertos/portasm.S:406
0x40091aa2: _frxt_int_exit at C:/esp32/esp-idf/components/freertos/portasm.S:206
Posted: Thu Dec 27, 2018 12:04 pm
by fivdiAtESP32
The crash occurs while attempting to do a task context switch. If I had to guess I'd say it's a stack size issue somewhere but I may be incorrect here. There are several configuration options for stack sizes in menuconfig. Try increasing them to see if it helps. Try increasing "Component config > ESP32-specific > (3584) Main task stack size" first to see if it helps.
Posted: Thu Dec 27, 2018 12:54 pm
by burkulesomesh43
fivdiAtESP32 wrote: ↑Thu Dec 27, 2018 12:04 pm
Ok. can you please explain, what is this main task stack size?
Posted: Thu Dec 27, 2018 1:29 pm
by fivdiAtESP32
Your app_main function runs in a task and that task needs a stack for storing things like local variables, arguments passed to functions and function call return address. The stack for this task is called the main stack and it must have a certain number of bytes. If it has less bytes than required things like what you are seeing can happen. The size of this stack in bytes is called the main task stack size.
As an example, if I run the following program on an ESP32-WROVER-B:
#include <iostream>
void foo(int val) {
std::cout << val << "\n";
if (val < 1000) {
foo(val + 1);
extern "C" void app_main() {
foo(0);
This is the output (it's not exactly like your output but similar):
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
11Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
Core 1 register dump:
PC : 0x4008569c PS : 0x00060033 A0 : 0x8008573a A1 : 0x3ffb7730
0x4008569c: prvCheckTasksWaitingTermination at /home/brian/src/esp-idf/esp-iot-solution/submodule/esp-idf/components/freertos/tasks.c:4579
A2 : 0x013f4032 A3 : 0x00000001 A4 : 0x00000000 A5 : 0x3ffb7070
A6 : 0x00000000 A7 : 0x00000001 A8 : 0x00000000 A9 : 0x00000001
A10 : 0x3ffb5771 A11 : 0x80000001 A12 : 0x00000000 A13 : 0x00000001
A14 : 0x00060021 A15 : 0x00000000 SAR : 0x00000000 EXCCAUSE: 0x0000001c
EXCVADDR: 0x013f407a LBEG : 0x00000000 LEND : 0x00000000 LCOUNT : 0x00000000
Backtrace: 0x4008569c:0x3ffb7730 0x40085737:0x3ffb7750
0x40085737: prvIdleTask at /home/brian/src/esp-idf/esp-iot-solution/submodule/esp-idf/components/freertos/tasks.c:4579
CPU halted.
The program calls foo recursively, uses too much stack and crashes.
Posted: Thu Dec 27, 2018 1:34 pm
by burkulesomesh43
fivdiAtESP32 wrote: ↑Thu Dec 27, 2018 1:29 pm
#include <iostream>
void foo(int val) {
if (val < 1000) {
foo(val + 1);
foo(0);
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
CPU halted.
So if you want to avoid this, what we have to do?
By increasing main task stack size is it works?
Posted: Thu Dec 27, 2018 1:43 pm
by fivdiAtESP32
As already mentioned above, changing the main tasks size may fix the issue, but it may not.
Try the following:
Call "make menuconfig" from a command line, navigate to "Component config > ESP32-specific > (nnnn) Main task stack size", and change nnnn to the number you would like it to be.
Note that we're in the "ESP32 IDF" forum here so I'm assuming that you're using esp-idf directly.
Posted: Thu Dec 27, 2018 1:55 pm
by burkulesomesh43
fivdiAtESP32 wrote: ↑Thu Dec 27, 2018 1:43 pm
Try the following:
yes, I am using esp idf.
I have changed main task stack size from 3584 to 4000 again giving error.
Posted: Thu Dec 27, 2018 2:00 pm
by fivdiAtESP32
Try with an even bigger number, maybe 10000.
