ESP32 IDF extend I2C buffer size
Posted: Mon Nov 26, 2018 3:48 pm
by avgustine13
Hi to everyone.
I have such a problem.
As I understand the I2C buffer (master mode) in ESP32 is limited to 32 bytes.
I need to increase it for more big amounts of data (up to 64 bytes or even 128).
How can I implement this?
Kind regards.
Ivan.
Re: ESP32 IDF extend I2C buffer size
Posted: Tue Nov 27, 2018 11:38 am
by Xiong Yu
https://docs.espressif.com/projects/esp ... _t6size_tb
Try using this function. It uses a linked list to achieve longer data
Posted: Tue Nov 27, 2018 11:51 am
by avgustine13
I'm using this functions.
i2c_master_read_byte, i2c_master_read
I'm reading a sensor, get info that 60 bytes available but read only 32.
Posted: Wed Nov 28, 2018 3:18 am
by ESP_houwenxiang
Hi
32 bytes is hardware limit, but you can read more than 32 bytes each time by software. can you provide your read function?
Posted: Wed Nov 28, 2018 8:00 am
by avgustine13
esp_err_t i2c_master_read_byte(i2c_cmd_handle_t cmd_handle, uint8_t* data, i2c_ack_type_t ack)
I2C_CHECK((data != NULL), I2C_ADDR_ERROR_STR, ESP_ERR_INVALID_ARG);
I2C_CHECK(cmd_handle != NULL, I2C_CMD_LINK_INIT_ERR_STR, ESP_ERR_INVALID_ARG);
I2C_CHECK(ack < I2C_MASTER_ACK_MAX, I2C_ACK_TYPE_ERR_STR, ESP_ERR_INVALID_ARG);
i2c_cmd_t cmd;
cmd.ack_en = 0;
cmd.ack_exp = 0;
cmd.ack_val = ((ack == I2C_MASTER_LAST_NACK) ? I2C_MASTER_NACK : (ack & 0x1));
cmd.byte_num = 1;
cmd.op_code = I2C_CMD_READ;
cmd.data = data;
return i2c_cmd_link_append(cmd_handle, &cmd);
esp_err_t i2c_master_read(i2c_cmd_handle_t cmd_handle, uint8_t* data, size_t data_len, i2c_ack_type_t ack)
I2C_CHECK(data_len > 0, I2C_DATA_LEN_ERR_STR, ESP_ERR_INVALID_ARG);
if(ack != I2C_MASTER_LAST_NACK) {
return i2c_master_read_static(cmd_handle, data, data_len, ack);
} else {
if(data_len == 1) {
return i2c_master_read_byte(cmd_handle, data, I2C_MASTER_NACK);
} else {
esp_err_t ret;
if((ret = i2c_master_read_static(cmd_handle, data, data_len - 1, I2C_MASTER_ACK)) != ESP_OK) {
return ret;
return i2c_master_read_byte(cmd_handle, data + data_len - 1, I2C_MASTER_NACK);
Posted: Wed Nov 28, 2018 8:06 am
by avgustine13
And here is the whole source file
Posted: Wed Dec 05, 2018 6:42 am
by ESP_houwenxiang
Hi, avgustine13
Why you don't use the i2c dirver in IDF?
