When switch the max_cpu_freq between RTC_CPU_FREQ_80M and RTC_CPU_FREQ_240M ,
The wifi will 100% reset , all TCP connections lost.
[0;32mI (9085) pm_esp32: Frequency switching config: CPU_MAX: 80, APB_MAX: 80, APB_MIN: 80, Light sleep: DISABLED[0m
cfg.max_cpu_freq changed to 1 , result 0
I (15041) wifi: bcn_timout,ap_probe_send_start
I (17544) wifi: ap_probe_send over, resett wifi status to disassoc
I (17545) wifi: state: run -> init (100)
I (17546) wifi: pm stop, total sleep time: 5687366 us / 15097450 us
I (17550) wifi: n:2 0, o:2 1, ap:2 1, sta:2 1, prof:2
I (17982) wifi: n:2 1, o:2 0, ap:2 1, sta:2 1, prof:2
I (17983) wifi: state: init -> auth (b0)
I (17986) wifi: state: auth -> assoc (0)
I (17991) wifi: state: assoc -> run (10)
I (18006) wifi: connected with NC-BGN, channel 2
I (18007) wifi: pm start, type: 1
[0;32mI (18721) event: sta ip: 192.168.1.2, mask: 255.255.255.0, gw: 192.168.1.1[0m
The code like this
extern "C"{
#include "esp_pm.h"
esp_pm_config_esp32_t cfg;
void _cpu_cfg()
cfg.min_cpu_freq = cfg.max_cpu_freq; //RTC_CPU_FREQ_XTAL;
esp_err_t err=esp_pm_configure(&cfg);
printf("cfg.max_cpu_freq changed to %d , result %d\r\n",(int)cfg.max_cpu_freq,(int)err);
extern void _cpu_min()
cfg.max_cpu_freq = RTC_CPU_FREQ_80M;
//cfg.light_sleep_enable=true; //result 262 ESP_ERR_NOT_SUPPORTED
_cpu_cfg();
extern void _cpu_max()
cfg.max_cpu_freq = RTC_CPU_FREQ_240M;
//cfg.light_sleep_enable=false;
_cpu_cfg();
_cpu_min() or _cpu_max() are called in cpu core 1
Regards,
Thanks.
Changing max_cpu_freq will 100% couse wifi: bcn_timout,ap_probe_send_start
Re: Changing max_cpu_freq will 100% couse wifi: bcn_timout,ap_probe_send_start
HI @ZHDX227,
Sorry for late response.
I just can't reproduce this issue for 10 hours test with a Mercury soft-AP. My reproduce method:
1. Configure ESP32 as STA mode
2. Connects ESP32 to a Mercury AP
3. Change CPU core#1 frequency between 80M and 240M every 5 seconds
Need you help to provide following information:
1. The AP type to which ESP32 STA is connected
2. How much time is needed in order to reproduce this issue
3. Does this issue happen on a specific ESP32 device or every ESP32 devices you have
I just do some tests.
It's ONLY happend when use
Environment :
Board : DevKitC v4, ESP-WROVER-B
CONFIG - Default , and turn's on the Power Management
Code :
esp_wifi_set_mode(WIFI_MODE_APSTA)
Environment :
Code :
/* WiFi station Example
#include <string.h>
#include "freertos/task.h"
#include "esp_system.h"
#include "esp_wifi.h"
#include "esp_event_loop.h"
#include "esp_log.h"
#include "nvs_flash.h"
#include "lwip/err.h"
#include "lwip/sys.h"
/* The examples use WiFi configuration that you can set via 'make menuconfig'.
If you'd rather not, just change the below entries to strings with
the config you want - ie #define EXAMPLE_WIFI_SSID "mywifissid"
#define EXAMPLE_ESP_WIFI_SSID "SSID"
#define EXAMPLE_ESP_WIFI_PASS "12345678"
#define EXAMPLE_ESP_MAXIMUM_RETRY CONFIG_ESP_MAXIMUM_RETRY
/* FreeRTOS event group to signal when we are connected*/
static EventGroupHandle_t s_wifi_event_group;
/* The event group allows multiple bits for each event, but we only care about one event
* - are we connected to the AP with an IP? */
const int WIFI_CONNECTED_BIT = BIT0;
static const char *TAG = "wifi station";
static int s_retry_num = 0;
static esp_err_t event_handler(void *ctx, system_event_t *event)
switch(event->event_id) {
case SYSTEM_EVENT_STA_START:
esp_wifi_connect();
case SYSTEM_EVENT_STA_GOT_IP:
ESP_LOGI(TAG, "got ip:%s",
ip4addr_ntoa(&event->event_info.got_ip.ip_info.ip));
s_retry_num = 0;
xEventGroupSetBits(s_wifi_event_group, WIFI_CONNECTED_BIT);
case SYSTEM_EVENT_STA_DISCONNECTED:
if (s_retry_num < EXAMPLE_ESP_MAXIMUM_RETRY) {
esp_wifi_connect();
xEventGroupClearBits(s_wifi_event_group, WIFI_CONNECTED_BIT);
s_retry_num++;
ESP_LOGI(TAG,"retry to connect to the AP");
ESP_LOGI(TAG,"connect to the AP fail\n");
default:
return ESP_OK;
void wifi_init_sta()
s_wifi_event_group = xEventGroupCreate();
tcpip_adapter_init();
ESP_ERROR_CHECK(esp_event_loop_init(event_handler, NULL) );
wifi_config_t wifi_config = {
.sta = {
.ssid = EXAMPLE_ESP_WIFI_SSID,
.password = EXAMPLE_ESP_WIFI_PASS
ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_APSTA) );
ESP_ERROR_CHECK(esp_wifi_set_config(ESP_IF_WIFI_STA, &wifi_config) );
wifi_config_t wifi_ap_config = {
.ap = {
.ssid = "ESP_SSID",
.ssid_len = strlen("ESP_SSID"),
.password = EXAMPLE_ESP_WIFI_PASS,
.max_connection = 8,
.authmode = WIFI_AUTH_WPA_WPA2_PSK
ESP_ERROR_CHECK(esp_wifi_set_config(ESP_IF_WIFI_AP, &wifi_ap_config));
ESP_ERROR_CHECK(esp_wifi_start() );
ESP_LOGI(TAG, "wifi_init_sta finished.");
ESP_LOGI(TAG, "connect to ap SSID:%s password:%s",
EXAMPLE_ESP_WIFI_SSID, EXAMPLE_ESP_WIFI_PASS);
//extern "C"{
#include "esp_pm.h"
void _cpu_cfg()
_cpu_cfg();
_cpu_cfg();
void app_main()
//Initialize NVS
ESP_ERROR_CHECK(ret);
ESP_LOGI(TAG, "ESP_WIFI_MODE_STA");
wifi_init_sta();
for(;;)
_cpu_max();
vTaskDelay(5000 / portTICK_PERIOD_MS);
_cpu_min();
OK, I will try to reproduce it again
Users browsing this forum: No registered users and 76 guests
