Strange Interrupt wdt timeout
Posted: Tue Oct 23, 2018 2:44 am
Currently I have a project running BLE connecting to a few sensors, making a measurement and then dropping the connection. I am running into an issue were a bit of pre compiled code is getting stuck and triggering the watchdog.
It seems strange though since it is saying that CPU 1 is in the idle task, however the interrupt wdt has time out???
I have a task pinned to the same core as the BLE code which is outputting the time difference from the last time it was called by using
the gettimeofday(), this seems to be correct and demonstrating the code is not stuck.
I have also increased the interrupt wdt to 5 seconds.....
I am using version 3.1 of the IDF.
Every time I am observing this crash ASSERT_PARAM(2051 0), in llc_util.c at line 289 has been output to the terminal.
Task watchdog got triggered. The following tasks did not reset the watchdog in t
ime:
- IDLE (CPU 1)
Tasks currently running:
CPU 0: Guru Meditation Error: Core 1 panic'ed (Interrupt wdt timeout on CPU1)
Core 1 register dump:
PC : 0x4008464d PS : 0x00060b34 A0 : 0x80046350 A1 : 0x3f
fbcb40
A2 : 0x00000001 A3 : 0x00000000 A4 : 0x00000000 A5 : 0x60
008054
A6 : 0x3ffc1028 A7 : 0x60008050 A8 : 0x8008464d A9 : 0x3f
fbcb20
A10 : 0x00000004 A11 : 0x00000000 A12 : 0x6000804c A13 : 0xff
ffffff
A14 : 0x00000000 A15 : 0xfffffffc SAR : 0x00000004 EXCCAUSE: 0x00
000006
EXCVADDR: 0x00000000 LBEG : 0x40084585 LEND : 0x4008458c LCOUNT : 0x00
000000
Backtrace: 0x4008464d:0x3ffbcb40 0x4004634d:0x3ffbcb60 0x40121ac1:0x3ffbcb80 0x4
0019d11:0x3ffbcbc0 0x40055b4d:0x3ffbcbe0 0x4011dad3:0x3ffbcc00 0x4011de55:0x3ffb
cc20
Core 0 register dump:
PC : 0x4000921a PS : 0x00060034 A0 : 0x80007d16 A1 : 0x3f
fc0500
A2 : 0x00800000 A3 : 0x00060023 A4 : 0x8008cd21 A5 : 0x3f
fd3b00
A6 : 0x00000003 A7 : 0x00060b23 A8 : 0x3ff40000 A9 : 0x00
000049
A10 : 0x00800000 A11 : 0x3ff4001c A12 : 0x00000000 A13 : 0x3f
fd3c20
A14 : 0x3ffc63b0 A15 : 0x3ffc52f4 SAR : 0x00000011 EXCCAUSE: 0x00
000006
EXCVADDR: 0x00000000 LBEG : 0x00000000 LEND : 0x00000000 LCOUNT : 0x00
000000
Backtrace: 0x4000921a:0x3ffc0500 0x40007d13:0x3ffc0520 0x40007c69:0x3ffc0540 0x4
0008106:0x3ffc0560 0x400d1e32:0x3ffc05f0 0x4008265d:0x3ffc0610 0x4014516b:0x0000
0000
