Flash encryption key when CODING_SCHEME 3/4 used
Posted: Fri Aug 24, 2018 5:02 pm
by chefotm
Hey guys.
Have one question. I made successfully ESP32 safe boot + flash encryption work on devkit (ESP-WROOM-32). Now i tried to make it work on ESP32-WROWER. I wrote the keys as previously on devkit. The same with the fuses. But the HW bootloader still not found the software bootloader (flash read error , 1000). I compared the fuses with devkit and found that WROWER have set the CODING_SCHEME efuse to 0x01 (it means all the key register blocks are used in 3/4 encode mode). Can you recommend me, how to calculate the encryption key? Here are the fuses:
DEVKIT FUSES:
espefuse.py v2.3.1
Connecting.....
Security fuses:
FLASH_CRYPT_CNT        Flash encryption mode counter                     = 7 R/W (0x7)
FLASH_CRYPT_CONFIG     Flash encryption config (key tweak bits)          = 15 R/W (0xf)
CONSOLE_DEBUG_DISABLE  Disable ROM BASIC interpreter fallback            = 1 R/W (0x1)
ABS_DONE_0             secure boot enabled for bootloader                = 1 R/W (0x1)
ABS_DONE_1             secure boot abstract 1 locked                     = 0 R/W (0x0)
JTAG_DISABLE           Disable JTAG                                      = 1 R/W (0x1)
DISABLE_DL_ENCRYPT     Disable flash encryption in UART bootloader       = 1 R/W (0x1)
DISABLE_DL_DECRYPT     Disable flash decryption in UART bootloader       = 1 R/W (0x1)
DISABLE_DL_CACHE       Disable flash cache in UART bootloader            = 1 R/W (0x1)
BLK1                   Flash encryption key
  = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -/-
BLK2                   Secure boot key
BLK3                   Variable Block 3
  = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 R/W
Efuse fuses:
WR_DIS                 Efuse write disable mask                          = 384 R/W (0x180)
RD_DIS                 Efuse read disablemask                            = 3 R/W (0x3)
CODING_SCHEME          Efuse variable block length scheme                = 0 R/W (0x0)
KEY_STATUS             Usage of efuse block 3 (reserved)                 = 0 R/W (0x0)
Config fuses:
XPD_SDIO_FORCE         Ignore MTDI pin (GPIO12) for VDD_SDIO on reset    = 0 R/W (0x0)
XPD_SDIO_REG           If XPD_SDIO_FORCE, enable VDD_SDIO reg on reset   = 0 R/W (0x0)
XPD_SDIO_TIEH          If XPD_SDIO_FORCE & XPD_SDIO_REG, 1=3.3V 0=1.8V   = 0 R/W (0x0)
SPI_PAD_CONFIG_CLK     Override SD_CLK pad (GPIO6/SPICLK)                = 0 R/W (0x0)
SPI_PAD_CONFIG_Q       Override SD_DATA_0 pad (GPIO7/SPIQ)               = 0 R/W (0x0)
SPI_PAD_CONFIG_D       Override SD_DATA_1 pad (GPIO8/SPID)               = 0 R/W (0x0)
SPI_PAD_CONFIG_HD      Override SD_DATA_2 pad (GPIO9/SPIHD)              = 0 R/W (0x0)
SPI_PAD_CONFIG_CS0     Override SD_CMD pad (GPIO11/SPICS0)               = 0 R/W (0x0)
DISABLE_SDIO_HOST      Disable SDIO host                                 = 0 R/W (0x0)
Identity fuses:
MAC                    MAC Address
  = 30:ae:a4:08:99:78 (CRC b5 OK) R/W
CHIP_VER_REV1          Silicon Revision 1                                = 1 -/W (0x1)
CHIP_VERSION           Reserved for future chip versions                 = 0 -/W (0x0)
CHIP_PACKAGE           Chip package identifier                           = 0 -/W (0x0)
Calibration fuses:
BLK3_PART_RESERVE      BLOCK3 partially served for ADC calibration data  = 0 -/W (0x0)
ADC_VREF               Voltage reference calibration                     = 1100 -/W (0x0)
Flash voltage (VDD_SDIO) determined by GPIO12 on reset (High for 1.8V, Low/NC for 3.3V).
WROWER fuses:
espefuse.py v2.3.1
Connecting........_
Security fuses:
  = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 09 91 12 10 00 00 00 00 00 00 00 00 00 00 00 00 R/W
Efuse fuses:
CODING_SCHEME          Efuse variable block length scheme                = 1 R/W (0x1)
Config fuses:
Identity fuses:
MAC                    MAC Address
  = b4:e6:2d:c8:0a:6d (CRC 79 OK) R/W
CHIP_VERSION           Reserved for future chip versions                 = 2 -/W (0x2)
Calibration fuses:
BLK3_PART_RESERVE      BLOCK3 partially served for ADC calibration data  = 1 -/W (0x1)
ADC_VREF               Voltage reference calibration                     = 1072 -/W (0x14)
ADC1_TP_LOW            ADC1 150mV reading                                = 342 R/W (0x10)
ADC1_TP_HIGH           ADC1 850mV reading                                = 3409 R/W (0x24)
ADC2_TP_LOW            ADC2 150mV reading                                = 489 R/W (0x11)
ADC2_TP_HIGH           ADC2 850mV reading                                = 3482 R/W (0x13)
Re: Flash encryption key when CODING_SCHEME 3/4 used
Posted: Fri Sep 14, 2018 1:53 am
by ESP_Angus
Hi chefotm,
Sorry for the long delay in getting back to you. A small number of WROVER modules were produced with 3/4 Coding Scheme enabled, however they are no longer being produced with this coding scheme. We don't have support for Flash Encryption or Secure Boot with 3/4 Coding Scheme yet, but it is planned for IDF V3.2.
If you have a production quantity of modules with 3/4 Coding Scheme and you need to roll out flash encryption and secure boot on these then please PM me on the forum and we'll work something out.
Angus
