STA_GOT_IP takes too long on WPA / WPA2.
Posted: Sat Jul 14, 2018 1:27 pm
by cendev
Connecting to a WPA network takes too much time compared to ESP8266 modules. While it is possible for me to connect to a open network within a 0.3 to 0.5 second, it is 0.5 to 0.8 second to connect to a WEP and between 1.1 to 3.4 seconds to connect to WPA secured network. These results are with static ip and from boot to STA_GOT_IP.
While using 8266 modules I was able to wake up, connect to WiFi with WPA, connect to TCP server on the same LAN, Auth,Send,Get Replies, Interprete and sleep back in just a second, 1.4 seconds at max..
For Both I use Static IPs,
Tried both on arduino32 and IDF and the results are the same.
Are there any tips for me to reach STA_GOT_IP phase faster? Am I missing something?
Re: STA_GOT_IP takes too long on WPA / WPA2.
Posted: Sat Jul 14, 2018 5:14 pm
by fly135
I've been trying to get help from others to verify an issue I'm seeing. Do you see a time to connect difference between WPA and WPA2 (PSK)? I am seeing multiple (random from 0 to 15 observed) disconnects with 203 reason code when using WPA2 (vs WPA). Which of course just lengthens the time it takes to get connected.
John A
Posted: Sat Jul 14, 2018 5:50 pm
by Deouss
Small question - how to measure ticks and convert them to μs and ms?
Once someone posted code in asm how to read ticks
Posted: Mon Mar 11, 2019 1:15 am
by JLIspace
Hey, did you eventually solve the issue? Sometimes my esp32 takes up to 8 seconds for STA_GOT_IP to appear.. :/
regards
