esp_ble_gatt_set_local_mtu not work on Gatts Server code
Posted: Sun Jun 10, 2018 11:28 am
Hi folks,
While I was implementing Gatt Server and Client on the same esp32 component, I've figured that after registering the Gatt server handler the command "esp_ble_gatt_set_local_mtu" is doing nothing.
After I've found it, I've tested this command in the gatt_server example and I've encountered the same problem.
Here is my main code from gatt_server example (with little changes):
and here is the output:
The client I've connected to is nRF connect (Nordic's BLE Application).
thanks for helping,
Albert
void app_main()
esp_err_t ret;
// Initialize NVS.
ret = nvs_flash_init();
if (ret == ESP_ERR_NVS_NO_FREE_PAGES) {
ESP_ERROR_CHECK(nvs_flash_erase());
ESP_ERROR_CHECK( ret );
ESP_ERROR_CHECK(esp_bt_controller_mem_release(ESP_BT_MODE_CLASSIC_BT));
esp_bt_controller_config_t bt_cfg = BT_CONTROLLER_INIT_CONFIG_DEFAULT();
ret = esp_bt_controller_init(&bt_cfg);
if (ret) {
ESP_LOGE(GATTS_TAG, "%s initialize controller failed\n", __func__);
return;
ret = esp_bt_controller_enable(ESP_BT_MODE_BLE);
if (ret) {
ESP_LOGE(GATTS_TAG, "%s enable controller failed\n", __func__);
return;
ret = esp_bluedroid_init();
if (ret) {
ESP_LOGE(GATTS_TAG, "%s init bluetooth failed\n", __func__);
return;
ret = esp_bluedroid_enable();
if (ret) {
ESP_LOGE(GATTS_TAG, "%s enable bluetooth failed\n", __func__);
return;
ret = esp_ble_gatts_register_callback(gatts_event_handler);
if (ret){
ESP_LOGE(GATTS_TAG, "gatts register error, error code = %x", ret);
return;
ret = esp_ble_gap_register_callback(gap_event_handler);
if (ret){
ESP_LOGE(GATTS_TAG, "gap register error, error code = %x", ret);
return;
ret = esp_ble_gatts_app_register(PROFILE_A_APP_ID);
if (ret){
ESP_LOGE(GATTS_TAG, "gatts app register error, error code = %x", ret);
return;
ret = esp_ble_gatts_app_register(PROFILE_B_APP_ID);
if (ret){
return;
esp_err_t local_mtu_ret = esp_ble_gatt_set_local_mtu(50);
if (local_mtu_ret){
ESP_LOGE(GATTS_TAG, "set local MTU failed, error code = %x", local_mtu_ret);
// init gpio2 as output
gpio_config_t io_conf;
//disable interrupt
io_conf.intr_type = GPIO_PIN_INTR_DISABLE;
//set as output mode
io_conf.mode = GPIO_MODE_OUTPUT;
//bit mask of the pins that you want to set,e.g.GPIO18/19
io_conf.pin_bit_mask = (1ULL<<2);
//disable pull-down mode
io_conf.pull_down_en = 0;
//disable pull-up mode
io_conf.pull_up_en = 0;
//configure GPIO with the given settings
gpio_config(&io_conf);
//Init ADC and Characteristics
// esp_adc_cal_characteristics_t characteristics;
// adc1_config_width(ADC_WIDTH_BIT_12);
// adc1_config_channel_atten(ADC1_TEST_CHANNEL, ADC_ATTEN_DB_11);
// esp_adc_cal_get_characteristics(V_REF, ADC_ATTEN_DB_11, ADC_WIDTH_BIT_12, &characteristics);
uint8_t currentGpioState = 0;
gpio_set_level(2, currentGpioState);
while(1){
// if (currentGpioState)
// currentGpioState = 0;
// else
// currentGpioState = 1;
// gpio_set_level(2, currentGpioState);
// gatts_bb_measurementsCharValue.attr_value[0] = currentGpioState;
// vTaskDelay(pdMS_TO_TICKS(10000));
// pulseVoltage = adc1_to_voltage(ADC1_TEST_CHANNEL, &characteristics);
// printf("%d mV\n",pulseVoltage);
// if (threshold < pulseVoltage) {
// char_pulseVal[0] = 1ULL;
// //gatts_demo_pulseVoltage_val.attr_value[0] = 1ULL;
// else {
// char_pulseVal[0] = NULL;
// //gatts_demo_pulseVoltage_val.attr_value[0] = NULL;
if (gl_profile_tab[PROFILE_A_APP_ID].connected) {
esp_err_t local_mtu_ret = esp_ble_gatt_set_local_mtu(155);
if (local_mtu_ret){
static int j = 0;
gpio_set_level(2, 1);
esp_ble_gatts_send_indicate(gl_profile_tab[PROFILE_A_APP_ID].gatts_if, gl_profile_tab[PROFILE_A_APP_ID].conn_id, gl_profile_tab[PROFILE_A_APP_ID].char_handle,
gatts_bb_measurementsCharValue.attr_len, gatts_bb_measurementsCharValue.attr_value, false);
// currentGpioState = char_pulseVal[0];
// gpio_set_level(2, gatts_demo_pulseVoltage_val.attr_value[0]);
for (int i = 6; i <= 9; i++)
bb_measurementsCharValue[i]++;
bb_measurementsCharValue[16]++;
j++;
if (j > 8) {
bb_measurementsCharValue[6] = 91;
bb_measurementsCharValue[7] = 85;
bb_measurementsCharValue[8] = 100;
bb_measurementsCharValue[9] = 90;
bb_measurementsCharValue[16] = 11;
j = 0;
vTaskDelay(pdMS_TO_TICKS(200));
gpio_set_level(2, 0);
vTaskDelay(pdMS_TO_TICKS(19800));
return;
I (433) cpu_start: Pro cpu start user code
I (115) cpu_start: Starting scheduler on PRO CPU.
I (204) BTDM_INIT: BT controller compile version [8c18895]
I (204) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (474) phy: phy_version: 366.0, ba9923d, Dec 29 2017, 14:25:06, 0, 0
I (504) GATTS_DEMO: REGISTER_APP_EVT, status 0, app_id 0
I (514) GATTS_DEMO: CREATE_SERVICE_EVT, status 0, service_handle 40
I (514) GATTS_DEMO: SERVICE_START_EVT, status 0, service_handle 40
I (514) GATTS_DEMO: ADD_CHAR_EVT, status 0, attr_handle 42, service_handle 40
I (524) GATTS_DEMO: the gatts demo char length = 1b
I (524) GATTS_DEMO: prf_char[0] =0
I (534) GATTS_DEMO: prf_char[1] =11
I (534) GATTS_DEMO: prf_char[2] =22
I (544) GATTS_DEMO: prf_char[3] =33
I (544) GATTS_DEMO: prf_char[4] =44
I (554) GATTS_DEMO: prf_char[5] =55
I (554) GATTS_DEMO: prf_char[6] =5b
I (554) GATTS_DEMO: prf_char[7] =5f
I (564) GATTS_DEMO: prf_char[8] =64
I (564) GATTS_DEMO: prf_char[9] =50
I (574) GATTS_DEMO: prf_char[a] =aa
I (574) GATTS_DEMO: prf_char[b] =bb
I (584) GATTS_DEMO: prf_char[c] =cc
I (584) GATTS_DEMO: prf_char[d] =dd
I (584) GATTS_DEMO: prf_char[e] =ee
I (594) GATTS_DEMO: prf_char[f] =ff
I (594) GATTS_DEMO: prf_char[10] =b
I (604) GATTS_DEMO: prf_char[11] =0
I (604) GATTS_DEMO: prf_char[12] =0
I (614) GATTS_DEMO: prf_char[13] =0
I (614) GATTS_DEMO: prf_char[14] =0
I (624) GATTS_DEMO: prf_char[15] =0
I (624) GATTS_DEMO: prf_char[16] =0
I (624) GATTS_DEMO: prf_char[17] =0
I (634) GATTS_DEMO: prf_char[18] =0
I (634) GATTS_DEMO: prf_char[19] =0
I (644) GATTS_DEMO: prf_char[1a] =0
I (644) GATTS_DEMO: ADD_DESCR_EVT, status 0, attr_handle 43, service_handle 40
I (654) GATTS_DEMO: REGISTER_APP_EVT, status 0, app_id 1
I (664) GATTS_DEMO: CREATE_SERVICE_EVT, status 0, service_handle 44
I (664) GATTS_DEMO: SERVICE_START_EVT, status 0, service_handle 44
I (674) GATTS_DEMO: ADD_CHAR_EVT, status 0, attr_handle 46, service_handle 44
I (684) GATTS_DEMO: ADD_DESCR_EVT, status 0, attr_handle 47, service_handle 44
I (694) gpio: GPIO[2]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (13244) GATTS_DEMO: ESP_GATTS_CONNECT_EVT, conn_id 0, remote 65:b3:28:22:85:ef:
I (13254) GATTS_DEMO: CONNECT_EVT, conn_id 0, remote 65:b3:28:22:85:ef:
I (13954) GATTS_DEMO: update connetion params status = 0, min_int = 16, max_int = 32,conn_int = 24,latency = 0, timeout = 400
I (14294) GATTS_DEMO: update connetion params status = 0, min_int = 0, max_int = 0,conn_int = 6,latency = 0, timeout = 2000
I (14554) GATTS_DEMO: update connetion params status = 0, min_int = 0, max_int = 0,conn_int = 24,latency = 0, timeout = 400
E (20704) BT: attribute value too long, to be truncated to 20
I (20704) GATTS_DEMO: ESP_GATTS_CONF_EVT, status 0
I (21484) GATTS_DEMO: GATT_WRITE_EVT, conn_id 0, trans_id 1, handle 47
I (21484) GATTS_DEMO: GATT_WRITE_EVT, value len 2, value :
I (21484) GATTS_DEMO: 01 00
I (21494) GATTS_DEMO: notify enable
I (21494) GATTS_DEMO: ESP_GATTS_CONF_EVT status 0
E (40704) BT: attribute value too long, to be truncated to 20
I (40704) GATTS_DEMO: ESP_GATTS_CONF_EVT, status 0
E (60704) BT: attribute value too long, to be truncated to 20
I (60704) GATTS_DEMO: ESP_GATTS_CONF_EVT, status 0
E (80704) BT: attribute value too long, to be truncated to 20
I (80704) GATTS_DEMO: ESP_GATTS_CONF_EVT, status 0
E (100704) BT: attribute value too long, to be truncated to 20
I (100704) GATTS_DEMO: ESP_GATTS_CONF_EVT, status 0
E (120704) BT: attribute value too long, to be truncated to 20
I (120704) GATTS_DEMO: ESP_GATTS_CONF_EVT, status 0
E (140704) BT: attribute value too long, to be truncated to 20
thanks for helping,
Albert
