Good morning
In the project we are developing, from the provisioner (h2) we configure remote nodes (also h2) into groups using the ESP_BLE_MESH_MODEL_OP_MODEL_SUB_ADD message.
I need to retrieve the configuration present on the remote node, but I found only the ESP_BLE_MESH_MODEL_OP_MODEL_PUB_GET message.
Even the ESP_BLE_MESH_MODEL_OP_SIG_MODEL_SUB_GET message does not seem to return a valid value to me, but if I send a message to the group, the configured node responds.
How can I find out which group a node is registered to?
Regards
BLE-MESH get subscription address
Re: BLE-MESH get subscription address
When sending ESP_BLE_MESH_MODEL_OP_SIG_MODEL_SUB_GET, you need to specify the correct model ID (SIG or Vendor model).
The response handler should correctly process the returned addresses.
Thank you for your response. I had set up the model correctly. After some testing, I saw that the information is returned in
within the sub_addr attribute.
This occurs only if the node has been registered to a group, otherwise the sub_addr.len is 0
param->status_cb.model_sub_list
Users browsing this forum: No registered users and 138 guests
