Wrap around ESP function
Stipa88
Postby Stipa88 » Thu Oct 10, 2024 7:28 am
Hello everyone.
I want to build a wrapper around some ESP function. Inside the function wrapper, I will execute my own code and call the original function. For example i want to wrap esp_panic_handler function.
Inside the main CMakeLists.txt I have the following commands:
cmake_minimum_required(VERSION 3.16)
set(application_name "PROJECT")
project(${application_name})
target_link_libraries(${project_elf} PRIVATE "-Wl,--wrap=esp_panic_handler")
Inside the project, for example in the folder MyPanic.c, I have a function defined
void __real_esp_panic_handler(panic_info_t *info);
void __wrap_esp_panic_handler(panic_info_t *info)
	// My code ...
	__real_esp_panic_handler(info);
The compilation result is:
system.a(panic_handler.c.obj): in function `panic_handler':
C:/Espressif/frameworks/esp-idf-v5.0/components/esp_system/port/panic_handler.c:189: undefined reference to `__wrap_esp_panic_handler'
How to solve the problem, so that the linker "sees" the Wrap.. function.
Tny
nopnop2002
Contact:
Re: Wrap around ESP function
Postby nopnop2002 » Thu Oct 10, 2024 2:43 pm
Your problem is very similar to this.
https://github.com/espressif/esp-idf/issues/7681
Stipa88
Postby Stipa88 » Thu Oct 10, 2024 7:17 pm
It's exactly what I need. Linking is a problem.
Error: C:/Espressif/frameworks/esp-idf-v5.0/components/esp_system/port/panic_handler.c:189: undefined reference to `__wrap_esp_panic_handler'
Please can someone check with esp-idf v5.0.7? Tnx
chegewara
Postby chegewara » Fri Oct 11, 2024 5:13 pm
Please try this definition
// void __real_esp_panic_handler(panic_info_t *info);
// void __wrap_esp_panic_handler(panic_info_t *info)
// 	// My code ...
// 	__real_esp_panic_handler(info);
void __real_esp_panic_handler(void *info);
void __wrap_esp_panic_handler(void *info)
    esp_rom_printf("\t\tpanic\n");
	// My code ...
and
idf_build_set_property(LINK_OPTIONS "-Wl,--wrap=esp_panic_handler" APPEND)
Stipa88
Postby Stipa88 » Sat Oct 12, 2024 8:35 pm
When an abort occurs, what function prints
"0x4200e011: HelpBtn_EventCb at E:/Program/Screen/TestScreen.c:294"
I need to override that function, because I want to save that data in NVS in the call point of the abort() function.
This is the result of printing log messages when abort() occurs:
abort() was called at PC 0x4200e011 on core 0
Core 0 register dump:
MEPC : 0x40380948 RA : 0x403873f8 SP : 0x3fcbff30 GP : 0x3fc90400
0x40380948: panic_abort at C:/Espressif/frameworks/esp-idf-v5.0/components/esp_system/panic.c:446
0x403873f8: __ubsan_include at C:/Espressif/frameworks/esp-idf-v5.0/components/esp_system/ubsan.c:313
TP : 0x3fc25b90 T0 : 0x37363534 T1 : 0x7271706f T2 : 0x33323130
S0/FP : 0x00000004 S1 : 0x3fcbff94 A0 : 0x3fcbff5c A1 : 0x3fcbff92
A2 : 0x00000000 A3 : 0x3fcbff89 A4 : 0x00000001 A5 : 0x3fcb9000
A6 : 0x7a797877 A7 : 0x76757473 S2 : 0x3fcbffe4 S3 : 0x00000001
ITD
Users browsing this forum: dg9ngf and 96 guests
