Can I use DMA for ESP32C3`IIC to drive ssd1306?
Posted: Sat Aug 17, 2024 9:07 am
by XH_Timmo
It has afterimage when I using ESP32C3`IIC to drive ssd1306 with 1 MHz. So I want to solve this problen with DMA. But in Technical Manuals, I can`t find IIC config in DMA, like this:
屏幕截图 2024-08-17 170549.png (33.94 KiB) Viewed 3309 times
This is my code to write data:
  1. static esp_err_t ssd1306_write_data(void *sensor, const uint8_t *const data_buf,
  2.                                     const uint8_t data_len) {
  3.   ssd1306_dev_t *sens = (ssd1306_dev_t *)sensor;
  4.   esp_err_t ret;
  5.
  6.   i2c_cmd_handle_t cmd = i2c_cmd_link_create();
  7.   ret = i2c_master_start(cmd);
  8.   assert(ESP_OK == ret);
  9.   ret = i2c_master_write_byte(cmd, sens->dev_addr | I2C_MASTER_WRITE, true);
  10.   assert(ESP_OK == ret);
  11.   ret = i2c_master_write_byte(cmd, 0x40, true);
  12.   assert(ESP_OK == ret);
  13.   ret = i2c_master_write(cmd, data_buf, data_len, true);
  14.   assert(ESP_OK == ret);
  15.   ret = i2c_master_stop(cmd);
  16.   assert(ESP_OK == ret);
  17.   ret = i2c_master_cmd_begin(sens->bus, cmd, 1000 / portTICK_PERIOD_MS);
  18.   i2c_cmd_link_delete(cmd);
  19.
  20.   return ret;
  21. }
This is my code to init ssd1306:
  1. void SSD1306_init(void) {
  2.
  3.   esp_err_t ret;
  4.
  5.   ssd1306 = ssd1306_create(I2C_MASTER_NUM, SSD1306_ADDR);
  6.   TEST_ASSERT_NOT_NULL_MESSAGE(ssd1306, "SSD1306 create returned NULL");
  7.   ssd1306_write_cmd(ssd1306, 0xAE);
  8.   ssd1306_write_cmd(ssd1306, 0x00);
  9.   ssd1306_write_cmd(ssd1306, 0x10);
  10.   ssd1306_write_cmd(ssd1306, 0x40);
  11.   ssd1306_write_cmd(ssd1306, 0xB0);
  12.   ssd1306_write_cmd(ssd1306, 0x81);
  13.   ssd1306_write_cmd(ssd1306, 0xFF);
  14.   ssd1306_write_cmd(ssd1306, 0xA1);
  15.   ssd1306_write_cmd(ssd1306, 0xA6);
  16.   ssd1306_write_cmd(ssd1306, 0xA8);
  17.   ssd1306_write_cmd(ssd1306, 0x3F);
  18.   ssd1306_write_cmd(ssd1306, 0xC8);
  19.   ssd1306_write_cmd(ssd1306, 0xD3);
  20.   ssd1306_write_cmd(ssd1306, 0x00);
  21.   ssd1306_write_cmd(ssd1306, 0xD5);
  22.   ssd1306_write_cmd(ssd1306, 0x80);
  23.   ssd1306_write_cmd(ssd1306, 0xD8);
  24.   ssd1306_write_cmd(ssd1306, 0x05);
  25.   ssd1306_write_cmd(ssd1306, 0xD9);
  26.   ssd1306_write_cmd(ssd1306, 0xF1);
  27.   ssd1306_write_cmd(ssd1306, 0xDA);
  28.   ssd1306_write_cmd(ssd1306, 0x12);
  29.   ssd1306_write_cmd(ssd1306, 0xDB);
  30.   ssd1306_write_cmd(ssd1306, 0x30);
  31.   ssd1306_write_cmd(ssd1306, 0x8D);
  32.   ssd1306_write_cmd(ssd1306, 0x14);
  33.   ssd1306_write_cmd(ssd1306, 0xAF);
  34.
  35.   ssd1306_clean();
  36.   ESP_LOGI(TAG, "Finish init %s", TAG);
  37. }
Re: Can I use DMA for ESP32C3`IIC to drive ssd1306?
Posted: Sat Aug 17, 2024 10:22 am
by ESP_Sprite
No, I2C doesn't support DMA. Note that this generally also is not needed as the I2C protocol itself is not really that fast. If your display supports it, you can try using SPI; that can go faster and does support DMA.
Posted: Sat Aug 17, 2024 11:36 am
by XH_Timmo
Thank you. I will look for a better displayer.
Posted: Sat Aug 17, 2024 6:41 pm
by MicroController
It has afterimage
What does that mean?
So I want to solve this problem with DMA.
How would using DMA solve your problem?
Posted: Sat Sep 14, 2024 8:02 am
by XH_Timmo
MicroController wrote: What does that mean?
Sorry, my English is bad , I meanings “残影” , looks like flash frequence is not enough.
MicroController wrote: How would using DMA solve your problem?
If I can use DMA, my transmission will be faster than now.
Posted: Sat Sep 14, 2024 1:17 pm
by QQ26750452
这是一个悲催的现实!国语分论坛一年半载没人回复,只能用蹩脚的英语硬着头皮混在英文分区里提问!
Posted: Mon Sep 16, 2024 1:29 pm
by MicroController
No, it would not.
I'm not sure what the problem is you're seeing, but it may be more of a timing issue, i.e. synchronization with the display's refresh cycle.
How many pixels at what framerate do you want to draw?
