start_ulp() compile:error:'uint32_t[1]' {aka 'long unsigned int[1]'} with idf v5.2
Posted: Sat Feb 17, 2024 11:46 am
by ginodecock
With idf v5.2 the following code for an esp32 does'nt compile anymore:
static void start_ulp()
	rtc_gpio_init(GPIO_NUM_25);
	rtc_gpio_set_direction(GPIO_NUM_25, RTC_GPIO_MODE_OUTPUT_ONLY);
	rtc_gpio_init(SCL_PIN);
	rtc_gpio_set_direction(SCL_PIN, RTC_GPIO_MODE_INPUT_ONLY);
	rtc_gpio_init(SDA_PIN);
	rtc_gpio_set_direction(SDA_PIN, RTC_GPIO_MODE_INPUT_ONLY);
	ESP_ERROR_CHECK(ulp_load_binary(0, ulp_main_bin_start, (ulp_main_bin_end - ulp_main_bin_start)/sizeof(uint32_t)));
	//REG_SET_FIELD(SENS_ULP_CP_SLEEP_CYC0_REG, SENS_SLEEP_CYCLES_S0,rtc_time_us_to_slowclk((uint64_t)(SENSE_INTERVAL) * 990000,rtc_clk_cal(RTC_CAL_RTC_MUX , CLOCK_MEASURE)));
	REG_SET_FIELD(SENS_ULP_CP_SLEEP_CYC0_REG, SENS_SLEEP_CYCLES_S0,rtc_time_us_to_slowclk((uint64_t)(SENSE_INTERVAL) * 999056,rtc_clk_cal(RTC_CAL_RTC_MUX , CLOCK_MEASURE)));
	//ESP_LOGI(TAG, "SENS_ULP_CP_SLEEP_CYC0_REG = %d", READ_PERI_REG(SENS_ULP_CP_SLEEP_CYC0_REG));
	ESP_ERROR_CHECK( ulp_run((&ulp_entry - RTC_SLOW_MEM) / sizeof(uint32_t)) );
	printf("Initiate deepsleepcounter\n");
	uint32_t *deepsleepcounter = &ulp_deepsleepcounter;
	if ((get_nextOffload() >= 30) && (get_nextOffload() <= LIMIT_WAKEUP)){
		deepsleepcounter[0] = get_nextOffload()/15;
		//printf("Normal init deepsleepcounter %d \n",deepsleepcounter[0]);
	}else{
		deepsleepcounter[0] = RETRY_TIME/15;
		//printf("Retry init Deepsleepcounter %d \n",deepsleepcounter[0]);
	printf("Initiate display matrix\n");
	uint32_t *tmp102config = &ulp_tmp102config;
	tmp102config[0] = 0x0030; //mark read and tx
	uint32_t *counter = &ulp_counter;
	counter[0] = 0;
	uint32_t *displayl = &ulp_displayl;
	displayl[0] = (uint32_t)get_display();// && 0x0000FFFF;
	uint32_t *displayh = &ulp_displayh;
	displayh[0] = (uint32_t)get_display() >> 16;
	uint32_t *intNumber = &ulp_intNumber;
    uint32_t *deciNumber = &ulp_deciNumber;
    intNumber[0] = 0x003F;    intNumber[1] = 0x0006;    intNumber[2] = 0x005B;    intNumber[3] = 0x004F;    intNumber[4] = 0x0066;    intNumber[5] = 0x006D;    intNumber[6] = 0x007D;    intNumber[7] = 0x0007;    intNumber[8] = 0x007F;    intNumber[9] = 0x006F;
    intNumber[10] = 0x063F;    intNumber[11] = 0x0606;    intNumber[12] = 0x065B;    intNumber[13] = 0x064F;    intNumber[14] = 0x0666;    intNumber[15] = 0x066D;    intNumber[16] = 0x067D;    intNumber[17] = 0x0607;    intNumber[18] = 0x067F;    intNumber[19] = 0x066F;
    intNumber[20] = 0x5B3F;    intNumber[21] = 0x5B06;    intNumber[22] = 0x5B5B;    intNumber[23] = 0x5B4F;    intNumber[24] = 0x5B66;    intNumber[25] = 0x5B6D;    intNumber[26] = 0x5B7D;    intNumber[27] = 0x5B07;    intNumber[28] = 0x5B7F;    intNumber[29] = 0x5B6F;
    intNumber[30] = 0x4F3F;    intNumber[31] = 0x4F06;    intNumber[32] = 0x4F5B;    intNumber[33] = 0x4F4F;    intNumber[34] = 0x4F66;    intNumber[35] = 0x4F6D;    intNumber[36] = 0x4F7D;    intNumber[37] = 0x4F07;    intNumber[38] = 0x4F7F;    intNumber[39] = 0x4F6F;
    intNumber[40] = 0x663F;    intNumber[41] = 0x6606;    intNumber[42] = 0x665B;    intNumber[43] = 0x664F;    intNumber[44] = 0x6666;    intNumber[45] = 0x666D;    intNumber[46] = 0x667D;    intNumber[47] = 0x6607;    intNumber[48] = 0x667F;    intNumber[49] = 0x666F;
    intNumber[50] = 0x6D3F;    intNumber[51] = 0x6D06;    intNumber[52] = 0x6D5B;    intNumber[53] = 0x6D4F;    intNumber[54] = 0x6D66;    intNumber[55] = 0x6D6D;    intNumber[56] = 0x6D7D;    intNumber[57] = 0x6D07;    intNumber[58] = 0x6D7F;    intNumber[59] = 0x6D6F;
    intNumber[60] = 0x7D3F;    intNumber[61] = 0x7D06;    intNumber[62] = 0x7D5B;    intNumber[63] = 0x7D4F;    intNumber[64] = 0x7D66;    intNumber[65] = 0x7D6D;    intNumber[66] = 0x7D7D;    intNumber[67] = 0x7D07;    intNumber[68] = 0x7D7F;    intNumber[69] = 0x7D6F;
    intNumber[70] = 0x4040;
    deciNumber[0] = 0xBF;//0x3F;//0
    deciNumber[1] = 0x86;//0x06;//1
    deciNumber[2] = 0x86;//0x06;//1
    deciNumber[3] = 0xDB;//0x5B;//2
    deciNumber[4] = 0xDB;//0x5B;//2
    deciNumber[5] = 0xCF;//0x4F;//3
    deciNumber[6] = 0xE6;//0x66;//4
    deciNumber[7] = 0xE6;//0x66;
    deciNumber[8] = 0xED;//0x6D;//5
    deciNumber[9] = 0xFD;//0x7D;//6
    deciNumber[10] = 0xFD;//0x7D;
    deciNumber[11] = 0x87;//0x07;//7
    deciNumber[12] = 0x87;//0x07;
    deciNumber[13] = 0xFF;//0x7F;//8
    deciNumber[14] = 0xEF;//0x6F;
    deciNumber[15] = 0xEF;//0x6F;//9
    struct timeval now;													//Var for boottime measurement
    gettimeofday(&now, NULL);
    start_log_time = now.tv_sec;
This results in following errors:
Y:/VM/eclipse-workspace/bat_sl_ulp_ijzer_temploggerC/main/main.c:139:40: error: array subscript 1 is outside array bounds of 'uint32_t[1]' {aka 'long unsigned int[1]'} [-Werror=array-bounds=]
  139 |     intNumber[0] = 0x003F;    intNumber[1] = 0x0006;    intNumber[2] = 0x005B;    intNumber[3] = 0x004F;    intNumber[4] = 0x0066;    intNumber[5] = 0x006D;    intNumber[6] = 0x007D;    intNumber[7] = 0x0007;    intNumber[8] = 0x007F;    intNumber[9] = 0x006F;
In file included from Y:/VM/eclipse-workspace/bat_sl_ulp_ijzer_temploggerC/main/main.c:49:
Y:/VM/eclipse-workspace/bat_sl_ulp_ijzer_temploggerC/build/esp-idf/main/ulp_main/ulp_main.h:26:17: note: at offset 4 into object 'ulp_intNumber' of size 4
   26 | extern uint32_t ulp_intNumber;
Y:/VM/eclipse-workspace/bat_sl_ulp_ijzer_temploggerC/main/main.c:139:66: error: array subscript 2 is outside array bounds of 'uint32_t[1]' {aka 'long unsigned int[1]'} [-Werror=array-bounds=]
Y:/VM/eclipse-workspace/bat_sl_ulp_ijzer_temploggerC/build/esp-idf/main/ulp_main/ulp_main.h:26:17: note: at offset 8 into object 'ulp_intNumber' of size 4
Y:/VM/eclipse-workspace/bat_sl_ulp_ijzer_temploggerC/main/main.c:139:92: error: array subscript 3 is outside array bounds of 'uint32_t[1]' {aka 'long unsigned int[1]'} [-Werror=array-bounds=]
Y:/VM/eclipse-workspace/bat_sl_ulp_ijzer_temploggerC/build/esp-idf/main/ulp_main/ulp_main.h:26:17: note: at offset 12 into object 'ulp_intNumber' of size 4
Y:/VM/eclipse-workspace/bat_sl_ulp_ijzer_temploggerC/main/main.c:139:118: error: array subscript 4 is outside array bounds of 'uint32_t[1]' {aka 'long unsigned int[1]'} [-Werror=array-bounds=]
Y:/VM/eclipse-workspace/bat_sl_ulp_ijzer_temploggerC/build/esp-idf/main/ulp_main/ulp_main.h:26:17: note: at offset 16 into object 'ulp_intNumber' of size 4
Y:/VM/eclipse-workspace/bat_sl_ulp_ijzer_temploggerC/main/main.c:139:144: error: array subscript 5 is outside array bounds of 'uint32_t[1]' {aka 'long unsigned int[1]'} [-Werror=array-bounds=]
Y:/VM/eclipse-workspace/bat_sl_ulp_ijzer_temploggerC/build/esp-idf/main/ulp_main/ulp_main.h:26:17: note: at offset 20 into object 'ulp_intNumber' of size 4
Y:/VM/eclipse-workspace/bat_sl_ulp_ijzer_temploggerC/main/main.c:139:170: error: array subscript 6 is outside array bounds of 'uint32_t[1]' {aka 'long unsigned int[1]'} [-Werror=array-bounds=]
Y:/VM/eclipse-workspace/bat_sl_ulp_ijzer_temploggerC/build/esp-idf/main/ulp_main/ulp_main.h:26:17: note: at offset 24 into object 'ulp_intNumber' of size 4
Y:/VM/eclipse-workspace/bat_sl_ulp_ijzer_temploggerC/main/main.c:139:196: error: array subscript 7 is outside array bounds of 'uint32_t[1]' {aka 'long unsigned int[1]'} [-Werror=array-bounds=]
Y:/VM/eclipse-workspace/bat_sl_ulp_ijzer_temploggerC/build/esp-idf/main/ulp_main/ulp_main.h:26:17: note: at offset 28 into object 'ulp_intNumber' of size 4
Y:/VM/eclipse-workspace/bat_sl_ulp_ijzer_temploggerC/main/main.c:139:222: error: array subscript 8 is outside array bounds of 'uint32_t[1]' {aka 'long unsigned int[1]'} [-Werror=array-bounds=]
Y:/VM/eclipse-workspace/bat_sl_ulp_ijzer_temploggerC/build/esp-idf/main/ulp_main/ulp_main.h:26:17: note: at offset 32 into object 'ulp_intNumber' of size 4
With idf v5.1.2 these were warnings
The issue seems to be the interpretation of uint32_t as unsigned long int vs as just an unsigned int.
Any suggestion's to fix or workaround? Using #include <inttypes.h> doesn't seem to work.
Thanks,
Gino
Re: start_ulp() compile:error:'uint32_t[1]' {aka 'long unsigned int[1]'} with idf v5.2
Posted: Sat Feb 17, 2024 2:43 pm
by MicroController
No. The issue is that a uint32_t is not the same as an array of 2 or more uint32_t's. In the compiler's words: "array subscript 1 is outside array bounds"
You may want to let the compiler know that ulp_intNumber is an array and not a single value.
Posted: Sat Feb 17, 2024 7:35 pm
by ginodecock
I tried to initialize intNumber as an array but that doesn't seem to work well with ulp variables.
Therefore I added the following line to CMakeLists.txt in order to be able to compile like in IDF v5.1.2
idf_build_set_property(COMPILE_OPTIONS "-Wno-error=array-bounds=" APPEND)
Posted: Sat Feb 17, 2024 9:33 pm
by MicroController
A general advice for anyone programming in C or C++:
Compiler warnings are not just there to make your build output look cool.
When the compiler outputs a warning, then you should take that as a warning. Most warnings indicate problems in your code which won't disappear if you just ignore the warnings.
"But my program runs just fine" is not a valid argument to dismiss any warnings. That's just like watching the "check engine" light in your car flashing and saying "car's still moving, so no need to check what's wrong," followed by covering the annoying blinking light with a piece of "-Wno"-brand electrical tape.
Make sure you look up what each warning is trying to tell you, then go ahead and fix the problem. Most of the problems indicated are real and can cause perceivable issues now or at any time in the future.
Also, once you're used to seeing every build produce dozens of warnings you're going to ignore all warnings by default, and are certain to miss any new warnings which may or may not immediately affect the correctness of your program, making your life harder in the end.
Sometimes, sometimes, a warning is not 'cleanly' avoidable by fixing your code. Only in these cases, when you have understood the warning, the cause, the remedies, and why they cannot be applied, you can selectively disable a specific warning at a specific location, and write a comment at that location saying why it is ok to disable this warning at this location.
