How to use alternate esptool in esp-idf-v446?
Posted: Sat Jan 20, 2024 9:19 am
I am using idf v4.4.6 in ubuntu 22.04.03 running in a Windows VirtualBox host.
I am unable to flash over serial cable with the version of esptool that is included with v4.4.6. However, the current version of esptool on github works fine. I thought I could just edit this section of export.sh to substitute the esptool in components/esptool_py/esptool/ with a different version:
However, this does not work. It appears the path to "${IDF_PATH}/components/esptool_py/esptool" is hard-coded somewhere. But Where? (For one, it is hard-coded in idf.py on line 502, but that is just an informational message.)
I've traced it down to where esp-idf-v446\tools\idf_py_actions\tools.py calls "ninja flash" as a subprocess.
This is where I am lost. I know nothing about how ninja works. Where is ninja finding what esptool to use if not from the path?
I have come up with a few hacks to fix this, but shouldn't setting the path to esptool.py "just work"?
--Joe
# Allow calling some IDF python tools without specifying the full path
# ${IDF_PATH}/tools is already added by 'idf_tools.py export'
# Comment out: IDF_ADD_PATHS_EXTRAS="${IDF_PATH}/components/esptool_py/esptool"
# Use this version of esptool insted:
IDF_ADD_PATHS_EXTRAS="${HOME}/repos/esptool"
IDF_ADD_PATHS_EXTRAS="${IDF_ADD_PATHS_EXTRAS}:${IDF_PATH}/components/espcoredump"
IDF_ADD_PATHS_EXTRAS="${IDF_ADD_PATHS_EXTRAS}:${IDF_PATH}/components/partition_table"
IDF_ADD_PATHS_EXTRAS="${IDF_ADD_PATHS_EXTRAS}:${IDF_PATH}/components/app_update"
export PATH="${IDF_ADD_PATHS_EXTRAS}:${PATH}"
Executing action: flash
task: <__main__.init_cli.<locals>.Task object at 0x7fc5b8097df0>
ctx: <click.core.Context object at 0x7fc5b9540940>
global_args: {'verbose': None, 'port': '/dev/ttyUSB0', 'project_dir': '/home/jmd/repos/wcb', 'build_dir': '/home/jmd/repos/wcb/build', 'cmake_warn_uninitialized': False, 'preview': False, 'ccache': False, 'generator': None, 'dry_run': False, 'define_cache_entry': [], 'baud': 460800}
task.action_args: {}
Running ninja in directory /home/jmd/repos/wcb/build
Executing "ninja flash"...
jmd: Is this it?
jmd: args: ['ninja', 'flash']
jmd: env_copy: {'SHELL': '/bin/bash', 'SESSION_MANAGER': 'local/jmd-VirtualBox:@/tmp/.ICE-unix/2763,unix/jmd-VirtualBox:/tmp/.ICE-unix/2763', 'QT_ACCESSIBILITY': '1', 'COLORTERM': 'truecolor', 'XDG_CONFIG_DIRS': '/etc/xdg/xdg-ubuntu:/etc/xdg', 'SSH_AGENT_LAUNCHER': 'gnome-keyring', 'XDG_MENU_PREFIX': 'gnome-', 'GNOME_DESKTOP_SESSION_ID': 'this-is-deprecated', 'GNOME_SHELL_SESSION_MODE': 'ubuntu', 'SSH_AUTH_SOCK': '/run/user/1000/keyring/ssh', 'XMODIFIERS': '@im=ibus', 'DESKTOP_SESSION': 'ubuntu', 'IDF_PYTHON_ENV_PATH': '/home/jmd/.espressif/python_env/idf4.4_py3.10_env', 'GTK_MODULES': 'gail:atk-bridge', 'PWD': '/home/jmd/repos/wcb', 'LOGNAME': 'jmd', 'XDG_SESSION_DESKTOP': 'ubuntu', 'XDG_SESSION_TYPE': 'wayland', 'SYSTEMD_EXEC_PID': '2796', 'IDF_PATH': '/home/jmd/esp/esp-idf-v446', 'XAUTHORITY': '/run/user/1000/.mutter-Xwaylandauth.FX4DH2', 'OPENOCD_SCRIPTS': '/home/jmd/.espressif/tools/openocd-esp32/v0.12.0-esp32-20230419/openocd-esp32/share/openocd/scripts', 'HOME': '/home/jmd', 'USERNAME': 'jmd', 'IM_CONFIG_PHASE': '1', 'LANG': 'en_US.UTF-8', 'LS_COLORS': 'rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.zst=01;31:*.tzst=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.wim=01;31:*.swm=01;31:*.dwm=01;31:*.esd=01;31:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.webp=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36:', 'XDG_CURRENT_DESKTOP': 'ubuntu:GNOME', 'VTE_VERSION': '6800', 'WAYLAND_DISPLAY': 'wayland-0', 'GHPAT': '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', 'GNOME_TERMINAL_SCREEN': '/org/gnome/Terminal/screen/84ea3a0c_cbf9_4b9b_b581_e342f80bfde9', 'GNOME_SETUP_DISPLAY': ':1', 'LESSCLOSE': '/usr/bin/lesspipe %s %s', 'XDG_SESSION_CLASS': 'user', 'TERM': 'xterm-256color', 'LESSOPEN': '| /usr/bin/lesspipe %s', 'USER': 'jmd', 'GNOME_TERMINAL_SERVICE': ':1.112', 'DISPLAY': ':0', 'SHLVL': '1', 'QT_IM_MODULE': 'ibus', 'XDG_RUNTIME_DIR': '/run/user/1000', 'XDG_DATA_DIRS': '/usr/share/ubuntu:/usr/local/share/:/usr/share/:/var/lib/snapd/desktop', 'PATH': '/home/jmd/repos/esptool:/home/jmd/esp/esp-idf-v446/components/espcoredump:/home/jmd/esp/esp-idf-v446/components/partition_table:/home/jmd/esp/esp-idf-v446/components/app_update:/home/jmd/.espressif/tools/xtensa-esp-elf-gdb/11.2_20220823/xtensa-esp-elf-gdb/bin:/home/jmd/.espressif/tools/xtensa-esp32-elf/esp-2021r2-patch5-8.4.0/xtensa-esp32-elf/bin:/home/jmd/.espressif/tools/esp32ulp-elf/2.35_20220830/esp32ulp-elf/bin:/home/jmd/.espressif/tools/openocd-esp32/v0.12.0-esp32-20230419/openocd-esp32/bin:/home/jmd/.espressif/python_env/idf4.4_py3.10_env/bin:/home/jmd/esp/esp-idf-v446/tools:/home/jmd/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/snap/bin', 'IDF_TOOLS_EXPORT_CMD': '/home/jmd/esp/esp-idf-v446/export.sh', 'IDF_TOOLS_INSTALL_CMD': '/home/jmd/esp/esp-idf-v446/install.sh', 'GDMSESSION': 'ubuntu', 'DBUS_SESSION_BUS_ADDRESS': 'unix:path=/run/user/1000/bus', 'OLDPWD': '/home/jmd/repos', '_': '/home/jmd/esp/esp-idf-v446/tools/idf.py', 'PYTHON': '/home/jmd/.espressif/python_env/idf4.4_py3.10_env/bin/python', 'ESPBAUD': '460800', 'ESPPORT': '/dev/ttyUSB0'}
jmd: cwd /home/jmd/repos/wcb/build
jmd: running subprocess now...
[1/6] cd /home/jmd/repos/wcb/build/esp....bin /home/jmd/repos/wcb/build/wcb.bin
wcb.bin binary size 0x1751b0 bytes. Smallest app partition is 0x190000 bytes. 0x1ae50 bytes (7%) free.
[2/6] Performing build step for 'bootloader'
[1/1] cd /home/jmd/repos/wcb/build/bootloader/esp-idf/esptool_py && /home/jmd/.espressif/python_env/idf4.4_py3.10_env/bin/python /home/jmd/esp/esp-idf-v446/components/partition_table/check_sizes.py --offset 0xc000 bootloader 0x1000 /home/jmd/repos/wcb/build/bootloader/bootloader.bin
Bootloader binary size 0x6a30 bytes. 0x45d0 bytes (40%) free.
[3/4] cd /home/jmd/esp/esp-idf-v446/co...nents/esptool_py/run_serial_tool.cmake
esptool.py esp32 -p /dev/ttyUSB0 -b 460800 --before=default_reset --after=hard_reset write_flash --flash_mode dio --flash_freq 40m --flash_size 16MB 0x1000 bootloader/bootloader.bin 0x30000 wcb.bin 0xc000 partition_table/partition-table.bin 0x2b000 ota_data_initial.bin 0x3fc000 storage.bin
esptool.py v3.3.4-dev
Serial port /dev/ttyUSB0
Connecting......................................
A fatal error occurred: Failed to connect to ESP32: Wrong boot mode detected (0x17)! The chip needs to be in download mode.
For troubleshooting steps visit: https://docs.espressif.com/projects/esptool/en/latest/troubleshooting.html
CMake Error at run_serial_tool.cmake:56 (message):
/home/jmd/esp/esp-idf-v446/components/esptool_py/esptool/esptool.py --chip
esp32 failed
--Joe
