SPI_FLASH_ERASE_YIELD_DURATION_MS and CONFIG_SPI_FLASH_ERASE_YIELD_TICKS
derricksenva
Postby derricksenva » Thu Jan 04, 2024 12:02 am
Can someone explain what SPI_FLASH_ERASE_YIELD_DURATION_MS and CONFIG_SPI_FLASH_ERASE_YIELD_TICKS do? The descriptions from docs.espressif.com are not worded very well and almost sound exactly the same. Is CONFIG_SPI_FLASH_ERASE_YIELD_DURATION_MS the amount of time passed to vTaskDelay() at the end of a call to esp_partition_erase_range()? How is CONFIG_SPI_FLASH_ERASE_YIELD_TICKS any different?
Duration of erasing to yield CPUs (ms)
Found in: Component config > SPI Flash driver > CONFIG_SPI_FLASH_YIELD_DURING_ERASE
If a duration of one erase command is large then it will yield CPUs after finishing a current command.
Default value:
20
CPU release time (tick) for an erase operation
Defines how many ticks will be before returning to continue a erasing.
Default value:
1
I've also looked at the source in
components/spi_flash/spi_flash_os_func_app.c
and the comments there seem to require a deeper understanding of the entire SPI flash component.
MicroController
Re: SPI_FLASH_ERASE_YIELD_DURATION_MS and CONFIG_SPI_FLASH_ERASE_YIELD_TICKS
Postby MicroController » Thu Jan 04, 2024 9:44 am
Erasing will yield every CONFIG_SPI_FLASH_ERASE_YIELD_DURATION_MS for CONFIG_SPI_FLASH_ERASE_YIELD_TICKS, i.e. by default, it will yield/pause for 1 OS tick (10ms) after running for 20ms.
ViennaTom
Postby ViennaTom » Mon Jan 15, 2024 9:54 pm
Having you knowing and understanding SPI-flash memory of all manufactures here is really a pity !!!
I hope in this case you can easily explain why
E (7149) mqtt: Writing to partition subtype 130 at offset 0x700000
E (7149) mqtt: partition size 655360 datalen:655360
E (8829) mqtt: Erasing took 1686924 uSecs for partition size 655360
will return ESP_OK but without waiting for another 500 to 1000mSecs flash will not be written correctly ?
Interested in your knowledge !
Users browsing this forum: No registered users and 70 guests
