[SOLVED] MCPWM works in app_main but not in a FreeRTOS task
twadek
Postby twadek » Tue Dec 19, 2023 9:51 pm
I am experiencing an issue with MCPWM when inside a FreeRTOS task. My code is adapted from the esp-idf BLDC MCPWM example:https://github.com/espressif/esp-idf/tr ... dc_control.
When executed in app_main as a standalone function, motor control works as expected. When I use the same function implemented as a task, I get an error in either mcpwm_comparator_set_compare_value or mcpwm_generator_set_force_level.
I've been chasing this for a while; does anyone have a clue as to what may be causing this? Any help would be appreciated.
Example of error:
  1. Guru Meditation Error: Core  0 panic'ed (LoadProhibited). Exception was unhandled.
  2. Core  0 register dump:
  3. PC      : 0x4200ba9e  PS      : 0x00060030  A0      : 0x82008635  A1      : 0x3fc9da60
  4. 0x4200ba9e: mcpwm_comparator_set_compare_value at C:/Espressif/frameworks/esp-idf-v5.0.4-2/components/driver/mcpwm/mcpwm_cmpr.c:128 (discriminator 2)
  5. A2      : 0xb33fffff  A3      : 0x00000000  A4      : 0x3fc99948  A5      : 0x00000000
  6. A6      : 0x00000000  A7      : 0x3fc93d8c  A8      : 0x8037b0b5  A9      : 0x3fc9da30
  7. A10     : 0x3fc93d8c  A11     : 0x3fc942b4  A12     : 0x00060020  A13     : 0x00060023
  8. A14     : 0x00060223  A15     : 0x0000cdcd  SAR     : 0x00000000  EXCCAUSE: 0x0000001c
  9. EXCVADDR: 0xb3400003  LBEG    : 0x40056f5c  LEND    : 0x40056f72  LCOUNT  : 0xffffffff
  10. ClearCommError failed (PermissionError(13, 'The device does not recognize the command.', None, 22))
  11. Waiting for the device to reconnect
  12. Backtrace: 0x4200ba9b:0x3fc9da60 0x42008632:0x3fc9da90 0x4037a049:0x3fc9dab0
  13. 0x4200ba9b: mcpwm_comparator_set_compare_value at C:/Espressif/frameworks/esp-idf-v5.0.4-2/components/driver/mcpwm/mcpwm_cmpr.c:127 (discriminator 5)
  14. 0x42008632: vChangeSpeedFromQueue at C:/Espressif/esp_applications_working/motor_commutation/main/main.c:115
  15. 0x4037a049: vPortTaskWrapper at C:/Espressif/frameworks/esp-idf-v5.0.4-2/components/freertos/FreeRTOS-Kernel/portable/xtensa/port.c:149
  16. ELF file SHA256: f039a8f7c9e5c080
  17. Rebooting...
  18. ESP-ROM:esp32s3-20210327
  19. Build:Mar 27 2021
  20. rst:0x3 (RTC_SW_SYS_RST),boot:0xa (SPI_FAST_FLASH_BOOT)
  21. Saved PC:0x4037576d
  22. 0x4037576d: esp_restart_noos_dig at C:/Espressif/frameworks/esp-idf-v5.0.4-2/components/esp_system/esp_system.c:64 (discriminator 1)
  23.
  24. SPIWP:0xee
  25. mode:DIO, clock div:1
  26. load:0x3fce3810,len:0x168c
  27. load:0x403c9700,len:0xbf4
  28. load:0x403cc700,len:0x2da8
  29. entry 0x403c9904
Here is my code (some sections removed for brevity). There are other tasks as well that are running properly when the vCommutateMotor is run outside of a task.
  1.
  2. static portMUX_TYPE xSpinLock = portMUX_INITIALIZER_UNLOCKED;
  3.
  4. const bldc_hall_phase_action_t xHallStates[] = {
  5.     [6] = vSetState1,
  6.     [4] = vSetState2,
  7.     [5] = vSetState3,
  8.     [1] = vSetState4,
  9.     [3] = vSetState5,
  10.     [2] = vSetState6,
  11. };
  12.
  13. // Representative function, vSetState2-vSetState6 are not shown.
  14. void vSetState1(mcpwm_gen_handle_t (*pxGenerators)[2])
  15. {
  16.     mcpwm_generator_set_force_level(pxGenerators[PWM_OP_INDEX_1][PWM_GEN_INDEX_EN], 0, true);
  17.     mcpwm_generator_set_force_level(pxGenerators[PWM_OP_INDEX_1][PWM_GEN_INDEX_MOTOR], 0, true);
  18.     mcpwm_generator_set_force_level(pxGenerators[PWM_OP_INDEX_3][PWM_GEN_INDEX_EN], 1, true);
  19.     mcpwm_generator_set_force_level(pxGenerators[PWM_OP_INDEX_3][PWM_GEN_INDEX_MOTOR], 0, true);
  20.     mcpwm_generator_set_force_level(pxGenerators[PWM_OP_INDEX_2][PWM_GEN_INDEX_EN], 1, true);
  21.     mcpwm_generator_set_force_level(pxGenerators[PWM_OP_INDEX_2][PWM_GEN_INDEX_MOTOR], -1, true);
  22. }
  23.
  24. uint32_t ulGetHallSensorValue(bool xMotorDirectionCounterClockwise)
  25. {
  26.     uint32_t ulHallValue = gpio_get_level(DIN_HALL_1) * 4 + gpio_get_level(DIN_HALL_2) * 2 + gpio_get_level(DIN_HALL_3) * 1;
  27.     return xMotorDirectionCounterClockwise ? ulHallValue ^ (0x07) : ulHallValue;
  28. }
  29.
  30. void vChangeSpeedFromQueue(void *pvParameters)
  31. {
  32.     static uint32_t ulCurrentSpeedValue;
  33.     mcpwm_cmpr_handle_t *xComparators = (mcpwm_cmpr_handle_t *)pvParameters;
  34.     while (1) {
  35.         if (xQueueReceive(xSpeedControlQueue, &ulCurrentSpeedValue, 0)) {
  36.             for (int i = 0; i < 3; i++) {
  37.                 if (ulCurrentSpeedValue < PWM_PERIOD) {
  38.                     ESP_ERROR_CHECK(mcpwm_comparator_set_compare_value(xComparators[i], ulCurrentSpeedValue));
  39.                 } else {
  40.                     ESP_ERROR_CHECK(mcpwm_comparator_set_compare_value(xComparators[i], PWM_PERIOD));
  41.                 }
  42.             }
  43.         }
  44.     }
  45. }
  46.
  47. void vCommutateMotor(void *pvParameters) {
  48.     mcpwm_gen_handle_t (*xGenerators)[3][2] = pvParameters;
  49.     uint32_t ulHallSensorValue = 0;
  50.
  51.     while (1) {
  52.         ulHallSensorValue = ulGetHallSensorValue(SPIN_DIRECTION_CCW);
  53.         if (ulHallSensorValue >= 1 && ulHallSensorValue <= 6) {
  54.             taskENTER_CRITICAL(&xSpinLock);
  55.             xHallStates[ulHallSensorValue](xGenerators);
  56.             taskEXIT_CRITICAL(&xSpinLock);
  57.         } else {
  58.             ESP_LOGE(TAG, "invalid bldc phase, wrong hall sensor value:%"PRIu32, ulHallSensorValue);
  59.         }
  60.
  61.         ulTaskNotifyTake(pdTRUE, portMAX_DELAY);
  62.     }
  63. }
  64.
  65. void app_main(void) {
  66.     mcpwm_cmpr_handle_t xComparators[3];
  67.     mcpwm_gen_handle_t xGenerators[3][2] = {};
  68.
  69.     xTaskCreate(vChangeSpeedFromQueue, "vChangeSpeedFromQueue", 8192, &xComparators, tskIDLE_PRIORITY, NULL);
  70.
  71.     // Throws error, core panics and restarts.
  72.     xTaskCreate(vCommutateMotor, "vCommutateMotor", 8192, xGenerators, tskIDLE_PRIORITY + 1, NULL);
  73.
  74.     // Controls BLDC motor as expected.
  75.     vCommutateMotor(xGenerators);
  76. }
ESP_Sprite
Re: MCPWM works in app_main but not in a FreeRTOS task
Postby ESP_Sprite » Wed Dec 20, 2023 5:41 am
Not sure what exactly is wrong, but to add some info: app_main is also running as a plain old RTOS task (just one that is started and cleaned up within ESP-IDF rather than explicitly), so there's not really much difference there. If any, I'd look at how you pass xGenerators as an argument; something feels off there but I can't lay my finger on it exactly.
MicroController
Postby MicroController » Wed Dec 20, 2023 10:40 am
Sprite is correct: You're passing a pointer to xGenerators to the new task, but xGenerators is a local variable in app_main(). When, after starting the new task, app_main() exits, the pointer to xGenerators becomes invalid, but vCommutateMotor will continue to use it.
Same thing with xComparators in
Make xComparators and xGenerators global variables, or make them local in their respective task's function.
twadek
Postby twadek » Wed Dec 20, 2023 3:45 pm
That worked. Thank you for the help!
Users browsing this forum: full_spectrum, rsimpsonbusa and 90 guests
