Good morning,
I am working on the Esp32S3 chip and I have created an application program for it.
This application program will be flashed over USBJTAG in production via the corresponding command
and I would like to secure the future programming of the chip.
1) I would like to disable the possibility to read back the firmware that will be in the chip.
I don't know exactly if it is possible or not with Espressif Chips. I just know that with some MCU (Other brands), users have the possibility to read the firmware that is in the chip and to generate a file with the datas. Then, users have the possibility to flash
this file on other chips. Do you have the answer please ?
2) Moreover, is there a way to disable the possibility for users to flash the chip with firmwares that are not from my company ?
This for programming over UART, USB and OTA. Is there a possibility to "lock" the chip for some particular programs (To identify some firmwares and to reject them) ?
Thank you for your help on this subject,
Best regards,
Thomas TRUILHE
ESP32S3 : Is there a way to secure the programming of the Esp32S3 ?
Users browsing this forum: Bing [Bot] and 76 guests
