Good afternoon,
I am using an Esp32S3WROOM 1 chip on an Esp32S3-DevKit-C-1 board.
I would like to use the USB connector and the USB/JTAG interface to program the chip instead of the USB/UART connector.
I can see the COM port under ESP-IDF but when run the chip programming,
the programming process does not reach the end. I get the message the chip is not responding :
Could you please help me ???
Writing at 0x00251c37... (70 %)
File "C:\Espressif\python_env\idf5.0_py3.8_env\lib\site-packages\esptool\__init__.py", line 1031, in _main
main()
File "C:\Espressif\python_env\idf5.0_py3.8_env\lib\site-packages\esptool\__init__.py", line 831, in main
operation_func(esp, args)
File "C:\Espressif\python_env\idf5.0_py3.8_env\lib\site-packages\esptool\cmds.py", line 580, in write_flash
esp.flash_defl_block(block, seq, timeout=timeout)
File "C:\Espressif\python_env\idf5.0_py3.8_env\lib\site-packages\esptool\loader.py", line 131, in inner
return func(*args, **kwargs)
File "C:\Espressif\python_env\idf5.0_py3.8_env\lib\site-packages\esptool\loader.py", line 1030, in flash_defl_block
self.check_command(
File "C:\Espressif\python_env\idf5.0_py3.8_env\lib\site-packages\esptool\loader.py", line 435, in check_command
val, data = self.command(op, data, chk, timeout=timeout)
File "C:\Espressif\python_env\idf5.0_py3.8_env\lib\site-packages\esptool\loader.py", line 404, in command
p = self.read()
File "C:\Espressif\python_env\idf5.0_py3.8_env\lib\site-packages\esptool\loader.py", line 337, in read
return next(self._slip_reader)
StopIteration
A fatal error occurred: The chip stopped responding.
CMake Error at run_serial_tool.cmake:55 (message):
python;;C:/Espressif/frameworks/esp-idf-v5.0/components/esptool_py/esptool/esptool.py;--chip;esp32s3
failed
Esp32S3 : Fail to program the Esp32S3 using the USB/JTAG interface
Re: Esp32S3 : Fail to program the Esp32S3 using the USB/JTAG interface
Does the chip flash correctly if you force it into boot mode (i.e. pull GPIO0 low then reset/power up the chip)? If so, you may need to update esptool.py.
Users browsing this forum: No registered users and 92 guests
