I'm using IDF 5.0 and I can receive IR frames correctly with RMT peripheral. I want to send what I receive but as far as I see rmt_transmit function in IDF 5.0 allows users to manually set command and data. Then it uses encoder to convert this data to RMT symbols. In my case, I already have RMT symbols since I've received them. How can I send these symbols directly without using any IR encoder?
Thanks in advance
RMT Peripheral - Sending RMT symbols directly
Re: RMT Peripheral - Sending RMT symbols directly
I solved this problem as follows.
I’ve installed tx channel following guide on esp offical site IDF5.0. Instead of
I’ve used
Where txHandle is handle for transmit channel and p.data is my own IR packet implementation. It must point to beginning of rmt symbols array.
rmt_transmit
/* Reset channel memory */
rmt_ll_tx_reset_pointer(txHandle->group->hal.regs, txHandle->channel_id);
/* Copy IR frame to Tx channel’s memory */
memcpy((void*) txHandle->hw_mem_base, &p.data[0], sizeof(p.data));
/* Start transmission */
rmt_ll_tx_start(txHandle->group->hal.regs, txHandle->channel_id);
Users browsing this forum: No registered users and 76 guests
