How can i successfully get internet ethernet to AP using DP83848 PHY module
Posted: Tue Dec 13, 2022 10:36 am
by PIYUSHGIRI
i try ethernet example which given in esp idf 4.3 version,but it is working in ethernet kit with IP101 PHY module,but i used DP83848 and i select from menuconfig,also i change address 1 to 0 and PHY reset gpio,SMI MDC gpio,SMI MDIO gpio... than also it will not work,i got a IP from ethernet but its did not connect via wifi AP,
please help me to which changes i do so after that its work fine,
thanks in advance
Re: How can i successfully get internet ethernet to AP using DP83848 PHY module
Posted: Wed Dec 14, 2022 9:39 am
by ESP_ondrej
What Ethernet example do you use? If you want to have Ethernet and Wifi, you need to initialize Ethernet and Wifi. Ethernet examples initializes only Ethernet.
Posted: Wed Dec 14, 2022 10:20 am
by PIYUSHGIRI
Hii ESP_ondreg,
thanks for support i used eth2AP example which given in the ethernet ,its working fine i select DP83848 and gpio change ,but
insufficient TX buffer size and WiFi send packet failed,
i enlarge buffer size than also sometime this error will come.
Posted: Wed Dec 14, 2022 3:18 pm
by PIYUSHGIRI
DP83848 is giving ethernet to AP wifi internet to samsung phone,but other device cant provide internet to PC or other company phone and expressif esp wrover module,idf version is 4.3
Posted: Thu Dec 15, 2022 8:07 am
by ESP_ondrej
but insufficient TX buffer size and WiFi send packet failed,
Yes, this can happen since Ethernet has greater throughput (is faster interface) than WIFI. You did the right thing, it will help you to buffer peaks but cannot solve issues with constant heavy traffic. You can also check other tips here: https://github.com/espressif/esp-idf/tr ... leshooting
I am sorry but I don't follow... Could you please try to split it to multiple bullets what connections are expected where? Or providing a figure with expected topology would be even better. Thanks.
