this is the error message I am getting...can't understand the reason..please help me...
I (710863) wifi:bcn_timout,ap_probe_send_start
ESP_ERROR_CHECK failed: esp_err_t 0x101 (ESP_ERR_NO_MEM) at 0x400898c4
0x400898c4: _esp_error_check_failed at C:/Users/ACER/esp/esp-idf/components/esp_system/esp_err.c:42
file: "IDF/components/esp_timer/src/ets_timer_legacy.c" line 69
func: ets_timer_setfn
expression: esp_timer_create(&create_args, (esp_timer_handle_t*)&(ptimer->timer_arg))
abort() was called at PC 0x400898c7 on core 0
ESP32 reboots regularly within 20 minutes
Re: ESP32 reboots regularly within 20 minutes
Dear ESP_SPRITE,
how can I identify a memory leak
You could use heap tracing for that. But before resorting to that, I suggest taking a long, hard look at your code to see if you're not allocating something and then not freeing it; that's basically what a memory leak boils down to.
Dear ESP_SPRITE,
Thanks for the help... there was a code like this
esp_err_t err_is_charger_locked = load_int_value("isLocked:", &isChargerLocked);
if (err_is_charger_locked != ESP_OK)
ESP_LOGE(TAG, "Error (%s) loading to NVS", esp_err_to_name(err_is_charger_locked));
where as the isChargerLocked is not initialized that caused the memory leak. after initializing now its working fine..thanks again for the support.
Users browsing this forum: warwound and 65 guests
