Hello forum.
I also intend to use ESP-IDF to work on some ESP32 projects utilizing FreeBSD (CURRENT, 14-STABLE and 13-STABLE as of today), without Linuxulator!
With the toolchain pkg patches provided by Tomoyuki Sakurai [
http://info.mkrsgh.org/blog/makerspace/ ... n-FreeBSD/ ] one is able to install a proper and recent toolchain in a standard FreeBSD ports path. After compiling the ports provided by Tomoyuki Sakurai, the FreeBSD environment provides the toolchain for IDF v5.1.1 (set via proper FLAVOR) :
/usr/local/xtensa-esp32-elf-idf51/ (basic toolchain, gcc v12.2)
/usr/local/esp-gdb-xtensa/ (ELF gdb, v12.1)
Following the instructions getting IDF v5.1.1, recen git pull is situated at
~/esp/esp-idf51/
Before altering IDF_PATH globally, running
~/esp/esp-idf51/install.sh
will pull a lot of (and most of them most likely unnecessary) Linux binaries and tries to install Python in ~/.espressif which bails out due to conflicts with standard FreeBSD packages already installed. So far, I ignored most of the errors, but it seems that some Python libraries/packages are missing, but I'll come to that later.
Pulling/installing these Linux binaries will also provide my with
~/.espressif/tools/esp-rom-elfs/
binaries, which I consider important.
After install.sh quit, IDF_PATH is set to
IDF_PATH=~/esp/esp-idf51/
and
IDF_TOOLS_PATH=~/esp/esp-idf51/tools
and running "${IDF_PATH}/tools/idf_tools.py" install-python-env.
This is now my starting point - and I fail!
Running ${IDF_PATH}/export.sh still bails out on two (mutually) important toolchain members:
Detecting the Python interpreter
Checking "python3" ...
Python 3.9.18
"python3" has been detected
Checking Python compatibility
Checking other ESP-IDF version.
ERROR: tool xtensa-esp-elf-gdb has no installed versions. Please run '/usr/local/bin/python3 ... tools/idf_tools.py install' to install it
[ along with some notes about unwanted ESP32XX types]
ERROR: tool esp32ulp-elf has no installed versions. Please run '/usr/local/bin/python3 ...
An unsupported version of tool esp32ulp-elf was found in PATH: 2.28.51 ...
ERROR: tool openocd-esp32 has no installed versions. Please run '/usr/local/bin/python3 ...
An unsupported version of tool openocd-esp32 was found in PATH: 0.11.0. To use it, run '/usr/local/bin/python3 ...
ERROR: tool esp-rom-elfs has no installed versions. Please run '/usr/local/bin/python3 ...
Running the suggested script
tools/idf_tools.py export --prefer-system
results in
ERROR: tool xtensa-esp-elf-gdb has no installed versions. Please run ...
WARNING: using an unsupported version of tool esp-clang found in PATH: unknown
WARNING: using an unsupported version of tool esp32ulp-elf found in PATH: 2.28.51
WARNING: using an unsupported version of tool cmake found in PATH: 3.27.7
WARNING: using an unsupported version of tool openocd-esp32 found in PATH: 0.11.0
WARNING: using an unsupported version of tool ninja found in PATH: 1.11.1
export IDF_PYTHON_ENV_PATH="~/esp/esp-idf51/tools/python_env/idf5.1_py3.9_env";...
The first question is: how do I provide the proper environment variables to make the IDF scripts find
1) xtensa-esp-elf-gdb (located at /usr/local/esp-gdb-xtensa/bin/xtensa-esp32-elf-gd)
2) esp-rom-elfs (located at .espressif/tools/esp-rom-elfs/
As one can see, things do not run very well for me here. I'm sorry if my description of failure is to "longish", but I hope someone will discover my major mistake.
Since FreeBSD isn't officially supported, I aim for some workarounds setting up the environment manually as the script would do this task in a more automatica fashion, but this seems to be a mission impossible without further informations about the hierachy of variables requisite to sucessfully setup the IDF's environment.
Running idf.py at the status quo described above as suggested with "hello_world" bails out with
Please use idf.py only in an ESP-IDF shell environment.
which seems to indicate missing Python packages and/or a proper path to the IDF location where these packages might reside.
I'm not even getting close to a point from which a descent developer might catch attention to real problems.
Is it possible to completely avoid/circumvent the Python scripts and setup manually an environment?
Usually I use ANJUTA as my favorite IDE, so that might be a suitabel task to provide a working setup ...
Thanks for reading ...
