Problems with converting espnow code to C++
Posted: Fri Oct 29, 2021 4:21 am
I have compiled and run the example code which written in C and it works perfectly. But now I want to integrate that example(Written in C) to my main code which is in C++. I made couple of changes where I replaced malloc keyword with new keyword and I compiled it. It compiles successfully but when I flash the code espnow_send does not work. This is the function where the problem is at,
After seeing the terminal output it appeared to me that the error was in where it did not return a ESP_OK. Can anyone help me understand why this error is given and how to overcome this. The whole code is attached as an attachment below
This is the error printed on the terminal,
E (5897) espnow_example: Send error
extern "C" void example_espnow_task(void *pvParameter)
example_espnow_event_t evt;
uint8_t recv_state = 0;
uint16_t recv_seq = 0;
int recv_magic = 0;
bool is_broadcast = false;
int ret;
vTaskDelay(5000 / portTICK_RATE_MS);
ESP_LOGI(TAG, "Start sending broadcast data");
/* Start sending broadcast ESPNOW data. */
example_espnow_send_param_t *send_param = (example_espnow_send_param_t *)pvParameter;
ESP_LOGI(TAG, "MAC : %d", esp_now_send(send_param->dest_mac, send_param->buffer, send_param->len));
if (esp_now_send(send_param->dest_mac, send_param->buffer, send_param->len) != ESP_OK)
ESP_LOGE(TAG, "Send error");
example_espnow_deinit(send_param);
vTaskDelete(NULL);
while (xQueueReceive(s_example_espnow_queue, &evt, portMAX_DELAY) == pdTRUE)
switch (evt.id)
case EXAMPLE_ESPNOW_SEND_CB:
example_espnow_event_send_cb_t *send_cb = &evt.info.send_cb;
is_broadcast = IS_BROADCAST_ADDR(send_cb->mac_addr);
ESP_LOGD(TAG, "Send data to " MACSTR ", status1: %d", MAC2STR(send_cb->mac_addr), send_cb->status);
if (is_broadcast && (send_param->broadcast == false))
break;
if (!is_broadcast)
send_param->count--;
if (send_param->count == 0)
ESP_LOGI(TAG, "Send done");
vTaskDelete(NULL);
/* Delay a while before sending the next data. */
if (send_param->delay > 0)
vTaskDelay(send_param->delay / portTICK_RATE_MS);
ESP_LOGI(TAG, "send data to " MACSTR "", MAC2STR(send_cb->mac_addr));
memcpy(send_param->dest_mac, send_cb->mac_addr, ESP_NOW_ETH_ALEN);
example_espnow_data_prepare(send_param);
/* Send the next data after the previous data is sent. */
vTaskDelete(NULL);
break;
case EXAMPLE_ESPNOW_RECV_CB:
example_espnow_event_recv_cb_t *recv_cb = &evt.info.recv_cb;
ret = example_espnow_data_parse(recv_cb->data, recv_cb->data_len, &recv_state, &recv_seq, &recv_magic);
free(recv_cb->data);
if (ret == EXAMPLE_ESPNOW_DATA_BROADCAST)
ESP_LOGI(TAG, "Receive %dth broadcast data from: " MACSTR ", len: %d", recv_seq, MAC2STR(recv_cb->mac_addr), recv_cb->data_len);
/* If MAC address does not exist in peer list, add it to peer list. */
if (esp_now_is_peer_exist(recv_cb->mac_addr) == false)
esp_now_peer_info_t *peer = new esp_now_peer_info_t[sizeof(esp_now_peer_info_t)];
if (peer == NULL)
ESP_LOGE(TAG, "Malloc peer information fail");
vTaskDelete(NULL);
memset(peer, 0, sizeof(esp_now_peer_info_t));
peer->channel = CONFIG_ESPNOW_CHANNEL;
peer->ifidx = ESPNOW_WIFI_IF;
peer->encrypt = true;
memcpy(peer->lmk, CONFIG_ESPNOW_LMK, ESP_NOW_KEY_LEN);
memcpy(peer->peer_addr, recv_cb->mac_addr, ESP_NOW_ETH_ALEN);
ESP_ERROR_CHECK(esp_now_add_peer(peer));
free(peer);
/* Indicates that the device has received broadcast ESPNOW data. */
if (send_param->state == 0)
send_param->state = 1;
else if (ret == EXAMPLE_ESPNOW_DATA_UNICAST)
ESP_LOGI(TAG, "Receive %dth unicast data from: " MACSTR ", len: %d", recv_seq, MAC2STR(recv_cb->mac_addr), recv_cb->data_len);
/* If receive unicast ESPNOW data, also stop sending broadcast ESPNOW data. */
send_param->broadcast = false;
else
ESP_LOGI(TAG, "Receive error data from: " MACSTR "", MAC2STR(recv_cb->mac_addr));
break;
default:
ESP_LOGE(TAG, "Callback type error: %d", evt.id);
break;
