OTA doesn't work over Ethernet but works fine over WiFi
adam_esp
Postby adam_esp » Thu Jul 22, 2021 2:54 pm
I came across a strange problem as in the title of the post.
Module or chip used: ESP32-WROOM-32E
IDF version: esp-idf_v4.3 Release
Build System: CMake
Compiler version (xtensa-esp32-elf-gcc esp-2020r3-8.4.0)
Sources: simple_ota_example with ESP-IDF (esp-idf_v4.3\examples\system\ota\simple_ota_example)
When i initialize ota via Ethernet i get errors like below:
esp_https_ota: Starting OTA...[0m
[0;32mI (51776) esp_https_ota: Writing to partition subtype 17 at offset 0x1a0000[0m
[0;31mE (58206) TRANS_SSL: esp_tls_conn_read error, errno=No more processes[0m
[0;33mW (58206) HTTP_CLIENT: esp_transport_read returned:-26880 and errno:11 [0m
[0;31mE (68386) TRANS_SSL: esp_tls_conn_read error, errno=No more processes[0m
[0;33mW (68386) HTTP_CLIENT: esp_transport_read returned:-26880 and errno:11 [0m
[0;31mE (89686) TRANS_SSL: esp_tls_conn_read error, errno=No more processes[0m
[0;33mW (89686) HTTP_CLIENT: esp_transport_read returned:-26880 and errno:11 [0m
[0;31mE (95766) TRANS_SSL: esp_tls_conn_read error, errno=No more processes[0m
[0;33mW (95766) HTTP_CLIENT: esp_transport_read returned:-26880 and errno:11 [0m
[0;31mE (101466) TRANS_SSL: esp_tls_conn_read error, errno=No more processes[0m
[0;33mW (101466) HTTP_CLIENT: esp_transport_read returned:-26880 and errno:11 [0m
[0;33mW (101466) OTA_dev: SetUpdateStatus: 255 [0xFF][0m
[0;31mE (101466) OTA: WAN Firmware Upgrades Failed ![0m
when I initialize it via WiFi everything is fine
OTA: WAN Firmware Upgrades Success !
Has anyone had similar problems and fixed them?
Best regards
Adam
WiFive
Re: OTA doesn't work over Ethernet but works fine over WiFi
Postby WiFive » Thu Jul 22, 2021 9:29 pm
It would help if you state what Ethernet hardware you are using
mbratch
Postby mbratch » Fri Jul 23, 2021 2:35 am
I haven't read the documentation to determine the limitations of it's capability, but I do know that OTA stands for "over the air".
adam_esp
Postby adam_esp » Fri Jul 23, 2021 6:04 am
The equipment is my proprietary solution, I do not think there is a problem with it. Other tasks after Ethernet work, such as SNTP time synchronization, telemetry with an external server, local control etc. Only OTA does't work.
I forgot to write that the problem appeared after updating the library from version 4.2 to 4.3 with dedicated tools.
Before that, OTA worked fine over Ethernet.
Best Regards
Adam
WiFive
Postby WiFive » Fri Jul 23, 2021 10:46 am
Esp-idf supports different Ethernet chips and they have different drivers with different bugs...
adam_esp
Postby adam_esp » Fri Jul 23, 2021 12:04 pm
I am using ethernet PHY lan8720 cp abc.
I took the latest esp-idf 4.3 from git. Updated the tool to xtensa-esp32-elf-gcc esp-2021r1-8.4.0.
Still the same errors for OTA over Ethernet.
mbratch
Postby mbratch » Fri Jul 23, 2021 1:40 pm
You mentioned it worked with the prior version of ESP-IDF then stopped working when you upgraded. Is the upgrade the only difference between the working version and the one that now doesn't work? Or are there app changes mixed in as well?
adam_esp
Postby adam_esp » Fri Jul 23, 2021 2:31 pm
Changes in the OTA task I did not do because it was stable, only in other tasks such as the support of the SPI, button, LEDs.
Below I place a more extensive log.
[0;32mI (35679) esp_https_ota: Writing to partition subtype 17 at offset 0x1a0000[0m
[0;32mI (37449) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (37509) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (37519) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (41799) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (41809) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (41869) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (41879) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (41899) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (41909) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (41929) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (41939) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (41939) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=22[0m
[0;32mI (44519) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=267[0m
[0;32mI (44579) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (44589) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (44609) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (44619) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (44639) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (44649) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (44709) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (44719) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (44739) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (44749) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (44769) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (44779) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (44839) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (44849) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (44869) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (44879) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (44899) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (44909) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (44969) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (44979) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (44999) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (45009) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (45029) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (45039) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=222[0m
[0;32mI (46699) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=67[0m
[0;32mI (46759) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (46769) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (46789) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (46799) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (46819) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (46829) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (46889) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (46899) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (46919) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (46929) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (46949) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (46959) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (47029) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (47039) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (47059) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (47069) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (47089) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (47099) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (47149) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (47159) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (47179) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (47189) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (47209) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (47219) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=133[0m
[0;32mI (48399) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=156[0m
[0;32mI (48449) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (48459) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (48479) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (48489) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (48509) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (48519) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (48579) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (48589) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (48609) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (48619) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (48639) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (48649) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (48709) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (48719) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (48739) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (48749) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (48769) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (48779) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (48839) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (48849) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (48869) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (48879) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (48899) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (48909) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (48909) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=44[0m
[0;32mI (50029) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=245[0m
[0;32mI (50089) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50099) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50119) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50129) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50149) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50159) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50219) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50229) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50249) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50259) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50279) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50289) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50339) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50349) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50369) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50379) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50399) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50409) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50469) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50479) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50499) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50509) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50529) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50539) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=244[0m
[0;32mI (52009) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=45[0m
[0;32mI (52069) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (52079) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (52099) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (52109) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (52129) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (52139) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (52209) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (52219) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (52239) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (52249) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (52269) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (52279) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (52339) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (52349) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (52369) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (52379) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (52399) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (52409) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (52459) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (52469) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (52489) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (52499) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (52519) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (52529) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=155[0m
[0;32mI (55349) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=134[0m
[0;32mI (55399) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (55409) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (55429) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (55439) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (55459) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (55469) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (55529) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (55539) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (55559) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (55569) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (55589) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (55599) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (55659) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (55669) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (55689) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (55699) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (55719) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (55729) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (55809) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (55819) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (55839) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (55849) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (55869) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (55879) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=66[0m
[0;32mI (55999) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=223[0m
[0;32mI (56049) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (56059) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (56079) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (56089) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (56109) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (56119) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (56179) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (56189) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (56209) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (56219) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (56239) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (56249) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (56319) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (56329) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (56349) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (56359) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (56379) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (56389) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (56439) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (56449) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (56469) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (56479) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (56499) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (56509) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=266[0m
[0;32mI (57489) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=23[0m
[0;32mI (57559) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (57569) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (57589) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (57599) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (57619) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (57629) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (57699) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (57709) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (57729) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (57739) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (57759) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (57769) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (57829) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (57839) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (57859) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (57869) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (57889) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (57899) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (57959) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (57969) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (57989) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (57999) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (58019) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (58029) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=177[0m
[0;32mI (58429) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=112[0m
[0;32mI (58479) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (58489) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (58509) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (58519) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (58539) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (58549) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (58609) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (58619) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (58639) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (58649) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (58669) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (58679) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (58739) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (58749) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (58769) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (58779) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (58799) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (58809) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (58879) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (58889) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (58909) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (58919) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (58939) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (58949) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=88[0m
[0;32mI (60049) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=201[0m
[0;32mI (60099) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (60109) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (60129) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (60139) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (60159) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (60169) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (60219) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (60229) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (60249) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (60259) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (60279) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (60289) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (60339) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (60349) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (60369) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (60379) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (60399) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (60409) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (60469) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (60479) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (60499) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (60509) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (60529) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (60539) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=288[0m
[0;32mI (64999) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=1[0m
[0;32mI (65049) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (65059) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (65079) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (65089) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (65109) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (65119) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (65189) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (65199) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (65219) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (65229) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (65249) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (65259) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (65309) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (65319) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (65339) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (65349) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (65369) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (65379) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (65429) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (65439) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (65459) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (65469) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (65489) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (65499) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=199[0m
[0;31mE (72599) TRANS_SSL: esp_tls_conn_read error, errno=No more processes[0m
[0;33mW (72599) HTTP_CLIENT: esp_transport_read returned:-26880 and errno:11 [0m
[0;31mE (82299) CW: TimeOut [11][0m
[0;31mE (82299) CW: Close socket[0m
[0;31mE (83339) CW: Socket unable to connect: errno 104 [bus4.hewalex.pl:50002][0m
[0;32mI (85399) CW: Successfully connected[0m
[0;33mW (85479) RW_PROCESS: Read RPG OK [2, 2][0m
[0;33mW (85519) RW_PROCESS: Read RPG OK [2, 2][0m
[0;33mW (86929) RW_PROCESS: Read RPG OK [2, 2][0m
[0;32mI (87199) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (87259) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (87269) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (87289) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (87299) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (87319) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (87329) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (87379) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (87389) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (87409) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (87419) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (87439) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (87449) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (87509) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (87519) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (87539) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (87549) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (87569) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (87579) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (87629) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (87639) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (87659) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (87669) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (87689) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (87699) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=200[0m
[0;33mW (88429) RW_PROCESS: Read RPG OK [2, 2][0m
[0;33mW (89929) RW_PROCESS: Read RPG OK [2, 2][0m
[0;33mW (90179) RW_PROCESS: Read RPG OK [2, 2][0m
[0;33mW (91429) RW_PROCESS: Read RPG OK [2, 2][0m
[0;33mW (91469) RW_PROCESS: Read RPG OK [2, 2][0m
[0;33mW (92179) RW_PROCESS: Read RPG OK [2, 2][0m
[0;31mE (92699) TRANS_SSL: esp_tls_conn_read error, errno=No more processes[0m
[0;33mW (92699) HTTP_CLIENT: esp_transport_read returned:-26880 and errno:11 [0m
[0;31mE (92819) RW_PROCESS: Read RPG ERR: AA99 [3, 3][0m
[0;31mE (93459) RW_PROCESS: Read RPG ERR: AA99 [4, 4][0m
[0;31mE (94099) RW_PROCESS: Read RPG ERR: AA99 [5, 5][0m
[0;31mE (94739) RW_PROCESS: Read RPG ERR: AA99 [6, 6][0m
[0;31mE (95379) RW_PROCESS: Read RPG ERR: AA99 [7, 7][0m
[0;31mE (96019) RW_PROCESS: Read RPG ERR: AA99 [8, 8][0m
[0;31mE (96659) RW_PROCESS: Read RPG ERR: AA99 [9, 9][0m
[0;31mE (97799) RW_PROCESS: Read RPG ERR: AA99 [10, 10][0m
[0;31mE (98439) RW_PROCESS: Read RPG ERR: AA99 [11, 11][0m
[0;31mE (114649) TRANS_SSL: esp_tls_conn_read error, errno=No more processes[0m
[0;33mW (114649) HTTP_CLIENT: esp_transport_read returned:-26880 and errno:11 [0m
[0;32mI (114649) OTA: ::::::::::::::: HTTP_EVENT_DISCONNECTED[0m
[0;32mI (114659) OTA: ::::::::::::::: HTTP_EVENT_DISCONNECTED[0m
[0;31mE (114659) OTA: ::::::::::::::: Firmware upgrade failed[0m
These are other threads (CW, RW_PROCESS)
Best regards
Adam
adam_esp
Postby adam_esp » Fri Jul 23, 2021 2:34 pm
Another time looks like this:
0;32mI (47282) esp_https_ota: Writing to partition subtype 17 at offset 0x1a0000[0m
[0;32mI (49102) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (49162) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (49172) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (49192) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (49202) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (49222) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (49232) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (49292) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (49302) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (49322) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (49332) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (49352) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (49362) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (49432) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (49442) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (49462) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (49472) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (49492) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (49502) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (49562) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (49572) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (49592) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (49602) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (49622) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (49632) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=200[0m
[0;32mI (50442) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=89[0m
[0;32mI (50522) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50532) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50552) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50562) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50582) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50592) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50642) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50652) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50672) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50682) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50702) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50712) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50782) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50792) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50812) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50822) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50842) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50852) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50932) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50942) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50962) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50972) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (50992) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=289[0m
[0;32mI (51002) OTA: ::::::::::::::: HTTP_EVENT_ON_DATA, len=111[0m
[0;31mE (56982) TRANS_SSL: esp_tls_conn_read error, errno=No more processes[0m
[0;33mW (56982) HTTP_CLIENT: esp_transport_read returned:-26880 and errno:11 [0m
[0;31mE (62862) TRANS_SSL: esp_tls_conn_read error, errno=No more processes[0m
[0;33mW (62862) HTTP_CLIENT: esp_transport_read returned:-26880 and errno:11 [0m
[0;32mI (62862) OTA: ::::::::::::::: HTTP_EVENT_DISCONNECTED[0m
[0;32mI (62872) OTA: ::::::::::::::: HTTP_EVENT_DISCONNECTED[0m
[0;31mE (62872) OTA: ::::::::::::::: Firmware upgrade failed[0m
Best regards
Adam
WiFive
Postby WiFive » Fri Jul 23, 2021 7:53 pm
-26880 is MBEDTLS_ERR_SSL_WANT_READ. You are going to have to turn on more debugging to dig deeper.
Users browsing this forum: Bing [Bot], Google [Bot] and 89 guests
