I added the following line early in my project level `CMakeLists.txt`:CMake Warning (dev) at C:/Users/mdbra/Documents/esp-idf/components/mbedtls/CMakeLists.txt:114 (target_sources):
Policy CMP0076 is not set: target_sources() command converts relative paths
to absolute. Run "cmake --help-policy CMP0076" for policy details. Use
the cmake_policy command to set the policy and suppress this warning.
A private source from a directory other than that of target "mbedcrypto"
has a relative path.
This warning is for project developers. Use -Wno-dev to suppress it.
cmake_policy(SET CMP0076 NEW)
Does anyone know the correct incantation to eliminate the cause of the warning?
