Can't initialize NIMBLE BLE (bleperph example)
Posted: Sun Nov 08, 2020 8:18 pm
Hey guys,
I have spent all days trying to get the nimble ble peripheral example without success.I have a TinyPico Rev3 and i am working with ESP-IDF v4.1 with PlatformIO on VSCode. I enabled Bluetooth , set NIMBLE
No matter what I try i always get this error when calling esp_nimble_hci_and_controller_init():
I tried the example directly, which compiles and upload with no issue. I tried going raw from the api but it's basically the same logic and still get the same problem.
This is my sdkconfig in case:
And this is my current partition table :
Do you know why i keep getting that NO_MEM error at initialization ?
Thank you guys in advance
.[0;32mI (1505) BTDM_INIT: BT controller compile version [219866f].[0m
ESP_ERROR_CHECK failed: esp_err_t 0x101 (ESP_ERR_NO_MEM) at 0x4008e45c
file: "src\main.cpp" line 40
func: void app_main()
expression: esp_nimble_hci_and_controller_init()
# Automatically generated file. DO NOT EDIT.
# Espressif IoT Development Framework (ESP-IDF) Project Configuration
CONFIG_IDF_CMAKE=y
CONFIG_IDF_TARGET="esp32"
CONFIG_IDF_TARGET_ESP32=y
CONFIG_IDF_FIRMWARE_CHIP_ID=0x0000
# SDK tool configuration
CONFIG_SDK_TOOLPREFIX="xtensa-esp32-elf-"
# CONFIG_SDK_TOOLCHAIN_SUPPORTS_TIME_WIDE_64_BITS is not set
# end of SDK tool configuration
# Build type
CONFIG_APP_BUILD_TYPE_APP_2NDBOOT=y
# CONFIG_APP_BUILD_TYPE_ELF_RAM is not set
CONFIG_APP_BUILD_GENERATE_BINARIES=y
CONFIG_APP_BUILD_BOOTLOADER=y
CONFIG_APP_BUILD_USE_FLASH_SECTIONS=y
# end of Build type
# Application manager
CONFIG_APP_COMPILE_TIME_DATE=y
# CONFIG_APP_EXCLUDE_PROJECT_VER_VAR is not set
# CONFIG_APP_EXCLUDE_PROJECT_NAME_VAR is not set
CONFIG_APP_RETRIEVE_LEN_ELF_SHA=16
# end of Application manager
# Bootloader config
CONFIG_BOOTLOADER_COMPILER_OPTIMIZATION_SIZE=y
# CONFIG_BOOTLOADER_COMPILER_OPTIMIZATION_DEBUG is not set
# CONFIG_BOOTLOADER_COMPILER_OPTIMIZATION_PERF is not set
# CONFIG_BOOTLOADER_COMPILER_OPTIMIZATION_NONE is not set
# CONFIG_BOOTLOADER_LOG_LEVEL_NONE is not set
# CONFIG_BOOTLOADER_LOG_LEVEL_ERROR is not set
# CONFIG_BOOTLOADER_LOG_LEVEL_WARN is not set
CONFIG_BOOTLOADER_LOG_LEVEL_INFO=y
# CONFIG_BOOTLOADER_LOG_LEVEL_DEBUG is not set
# CONFIG_BOOTLOADER_LOG_LEVEL_VERBOSE is not set
CONFIG_BOOTLOADER_LOG_LEVEL=3
# CONFIG_BOOTLOADER_VDDSDIO_BOOST_1_8V is not set
CONFIG_BOOTLOADER_VDDSDIO_BOOST_1_9V=y
# CONFIG_BOOTLOADER_FACTORY_RESET is not set
# CONFIG_BOOTLOADER_APP_TEST is not set
CONFIG_BOOTLOADER_WDT_ENABLE=y
# CONFIG_BOOTLOADER_WDT_DISABLE_IN_USER_CODE is not set
CONFIG_BOOTLOADER_WDT_TIME_MS=9000
# CONFIG_BOOTLOADER_APP_ROLLBACK_ENABLE is not set
# CONFIG_BOOTLOADER_SKIP_VALIDATE_IN_DEEP_SLEEP is not set
CONFIG_BOOTLOADER_RESERVE_RTC_SIZE=0
# CONFIG_BOOTLOADER_CUSTOM_RESERVE_RTC is not set
# end of Bootloader config
# Security features
# CONFIG_SECURE_SIGNED_APPS_NO_SECURE_BOOT is not set
# CONFIG_SECURE_BOOT is not set
# CONFIG_SECURE_FLASH_ENC_ENABLED is not set
# end of Security features
# Serial flasher config
CONFIG_ESPTOOLPY_BAUD_OTHER_VAL=115200
# CONFIG_ESPTOOLPY_FLASHMODE_QIO is not set
# CONFIG_ESPTOOLPY_FLASHMODE_QOUT is not set
CONFIG_ESPTOOLPY_FLASHMODE_DIO=y
# CONFIG_ESPTOOLPY_FLASHMODE_DOUT is not set
CONFIG_ESPTOOLPY_FLASHMODE="dio"
# CONFIG_ESPTOOLPY_FLASHFREQ_80M is not set
CONFIG_ESPTOOLPY_FLASHFREQ_40M=y
# CONFIG_ESPTOOLPY_FLASHFREQ_26M is not set
# CONFIG_ESPTOOLPY_FLASHFREQ_20M is not set
CONFIG_ESPTOOLPY_FLASHFREQ="40m"
# CONFIG_ESPTOOLPY_FLASHSIZE_1MB is not set
# CONFIG_ESPTOOLPY_FLASHSIZE_2MB is not set
CONFIG_ESPTOOLPY_FLASHSIZE_4MB=y
# CONFIG_ESPTOOLPY_FLASHSIZE_8MB is not set
# CONFIG_ESPTOOLPY_FLASHSIZE_16MB is not set
CONFIG_ESPTOOLPY_FLASHSIZE="4MB"
CONFIG_ESPTOOLPY_FLASHSIZE_DETECT=y
CONFIG_ESPTOOLPY_BEFORE_RESET=y
# CONFIG_ESPTOOLPY_BEFORE_NORESET is not set
CONFIG_ESPTOOLPY_BEFORE="default_reset"
CONFIG_ESPTOOLPY_AFTER_RESET=y
# CONFIG_ESPTOOLPY_AFTER_NORESET is not set
CONFIG_ESPTOOLPY_AFTER="hard_reset"
# CONFIG_ESPTOOLPY_MONITOR_BAUD_9600B is not set
# CONFIG_ESPTOOLPY_MONITOR_BAUD_57600B is not set
CONFIG_ESPTOOLPY_MONITOR_BAUD_115200B=y
# CONFIG_ESPTOOLPY_MONITOR_BAUD_230400B is not set
# CONFIG_ESPTOOLPY_MONITOR_BAUD_921600B is not set
# CONFIG_ESPTOOLPY_MONITOR_BAUD_2MB is not set
# CONFIG_ESPTOOLPY_MONITOR_BAUD_OTHER is not set
CONFIG_ESPTOOLPY_MONITOR_BAUD_OTHER_VAL=115200
CONFIG_ESPTOOLPY_MONITOR_BAUD=115200
# end of Serial flasher config
# Partition Table
# CONFIG_PARTITION_TABLE_SINGLE_APP is not set
# CONFIG_PARTITION_TABLE_TWO_OTA is not set
CONFIG_PARTITION_TABLE_CUSTOM=y
CONFIG_PARTITION_TABLE_CUSTOM_FILENAME="partitions.csv"
CONFIG_PARTITION_TABLE_FILENAME="partitions.csv"
CONFIG_PARTITION_TABLE_OFFSET=0x8000
CONFIG_PARTITION_TABLE_MD5=y
# end of Partition Table
# Example Configuration
CONFIG_EXAMPLE_FIRMWARE_UPG_URL="http://192.168.0.234:8070/firmware.bin"
CONFIG_EXAMPLE_SKIP_COMMON_NAME_CHECK=y
# CONFIG_EXAMPLE_SKIP_VERSION_CHECK is not set
CONFIG_EXAMPLE_GPIO_DIAGNOSTIC=21
CONFIG_EXAMPLE_OTA_RECV_TIMEOUT=5000
# end of Example Configuration
# Example Connection Configuration
CONFIG_EXAMPLE_CONNECT_WIFI=y
# CONFIG_EXAMPLE_CONNECT_ETHERNET is not set
CONFIG_EXAMPLE_WIFI_SSID=""
CONFIG_EXAMPLE_WIFI_PASSWORD=""
CONFIG_EXAMPLE_CONNECT_IPV6=y
# end of Example Connection Configuration
# Compiler options
# CONFIG_COMPILER_OPTIMIZATION_DEFAULT is not set
CONFIG_COMPILER_OPTIMIZATION_SIZE=y
# CONFIG_COMPILER_OPTIMIZATION_PERF is not set
# CONFIG_COMPILER_OPTIMIZATION_NONE is not set
CONFIG_COMPILER_OPTIMIZATION_ASSERTIONS_ENABLE=y
# CONFIG_COMPILER_OPTIMIZATION_ASSERTIONS_SILENT is not set
# CONFIG_COMPILER_OPTIMIZATION_ASSERTIONS_DISABLE is not set
CONFIG_COMPILER_CXX_EXCEPTIONS=y
CONFIG_COMPILER_CXX_EXCEPTIONS_EMG_POOL_SIZE=0
# CONFIG_COMPILER_CXX_RTTI is not set
CONFIG_COMPILER_STACK_CHECK_MODE_NONE=y
# CONFIG_COMPILER_STACK_CHECK_MODE_NORM is not set
# CONFIG_COMPILER_STACK_CHECK_MODE_STRONG is not set
# CONFIG_COMPILER_STACK_CHECK_MODE_ALL is not set
# CONFIG_COMPILER_WARN_WRITE_STRINGS is not set
# CONFIG_COMPILER_DISABLE_GCC8_WARNINGS is not set
# end of Compiler options
# Component config
# Application Level Tracing
# CONFIG_APPTRACE_DEST_TRAX is not set
CONFIG_APPTRACE_DEST_NONE=y
CONFIG_APPTRACE_LOCK_ENABLE=y
# end of Application Level Tracing
# Bluetooth
CONFIG_BT_ENABLED=y
# Bluetooth controller
CONFIG_BTDM_CTRL_MODE_BLE_ONLY=y
# CONFIG_BTDM_CTRL_MODE_BR_EDR_ONLY is not set
# CONFIG_BTDM_CTRL_MODE_BTDM is not set
CONFIG_BTDM_CTRL_BLE_MAX_CONN=1
CONFIG_BTDM_CTRL_BR_EDR_SCO_DATA_PATH_EFF=0
CONFIG_BTDM_CTRL_PCM_ROLE_EFF=0
CONFIG_BTDM_CTRL_PCM_POLAR_EFF=0
CONFIG_BTDM_CTRL_BLE_MAX_CONN_EFF=1
CONFIG_BTDM_CTRL_BR_EDR_MAX_ACL_CONN_EFF=0
CONFIG_BTDM_CTRL_BR_EDR_MAX_SYNC_CONN_EFF=0
CONFIG_BTDM_CTRL_PINNED_TO_CORE_0=y
# CONFIG_BTDM_CTRL_PINNED_TO_CORE_1 is not set
CONFIG_BTDM_CTRL_PINNED_TO_CORE=0
CONFIG_BTDM_CTRL_HCI_MODE_VHCI=y
# CONFIG_BTDM_CTRL_HCI_MODE_UART_H4 is not set
# MODEM SLEEP Options
CONFIG_BTDM_MODEM_SLEEP=y
CONFIG_BTDM_MODEM_SLEEP_MODE_ORIG=y
# CONFIG_BTDM_MODEM_SLEEP_MODE_EVED is not set
CONFIG_BTDM_LPCLK_SEL_MAIN_XTAL=y
# end of MODEM SLEEP Options
CONFIG_BTDM_BLE_DEFAULT_SCA_250PPM=y
CONFIG_BTDM_BLE_SLEEP_CLOCK_ACCURACY_INDEX_EFF=1
CONFIG_BTDM_BLE_SCAN_DUPL=y
CONFIG_BTDM_SCAN_DUPL_TYPE_DEVICE=y
# CONFIG_BTDM_SCAN_DUPL_TYPE_DATA is not set
# CONFIG_BTDM_SCAN_DUPL_TYPE_DATA_DEVICE is not set
CONFIG_BTDM_SCAN_DUPL_TYPE=0
CONFIG_BTDM_SCAN_DUPL_CACHE_SIZE=200
# CONFIG_BTDM_BLE_MESH_SCAN_DUPL_EN is not set
CONFIG_BTDM_CTRL_FULL_SCAN_SUPPORTED=y
CONFIG_BTDM_BLE_ADV_REPORT_FLOW_CTRL_SUPP=y
CONFIG_BTDM_BLE_ADV_REPORT_FLOW_CTRL_NUM=100
CONFIG_BTDM_BLE_ADV_REPORT_DISCARD_THRSHOLD=20
# CONFIG_BTDM_COEX_BT_OPTIONS is not set
# end of Bluetooth controller
# CONFIG_BT_BLUEDROID_ENABLED is not set
CONFIG_BT_NIMBLE_ENABLED=y
# CONFIG_BT_CONTROLLER_ONLY is not set
CONFIG_BT_RESERVE_DRAM=0xdb5c
# NimBLE Options
# CONFIG_BT_NIMBLE_MEM_ALLOC_MODE_INTERNAL is not set
CONFIG_BT_NIMBLE_MEM_ALLOC_MODE_EXTERNAL=y
# CONFIG_BT_NIMBLE_MEM_ALLOC_MODE_DEFAULT is not set
CONFIG_BT_NIMBLE_MAX_CONNECTIONS=1
CONFIG_BT_NIMBLE_MAX_BONDS=3
CONFIG_BT_NIMBLE_MAX_CCCDS=8
CONFIG_BT_NIMBLE_L2CAP_COC_MAX_NUM=0
CONFIG_BT_NIMBLE_PINNED_TO_CORE_0=y
# CONFIG_BT_NIMBLE_PINNED_TO_CORE_1 is not set
CONFIG_BT_NIMBLE_PINNED_TO_CORE=0
CONFIG_BT_NIMBLE_TASK_STACK_SIZE=512
CONFIG_BT_NIMBLE_ROLE_CENTRAL=y
CONFIG_BT_NIMBLE_ROLE_PERIPHERAL=y
CONFIG_BT_NIMBLE_ROLE_BROADCASTER=y
CONFIG_BT_NIMBLE_ROLE_OBSERVER=y
CONFIG_BT_NIMBLE_NVS_PERSIST=y
CONFIG_BT_NIMBLE_SM_LEGACY=y
CONFIG_BT_NIMBLE_SM_SC=y
# CONFIG_BT_NIMBLE_DEBUG is not set
# CONFIG_BT_NIMBLE_SM_SC_DEBUG_KEYS is not set
CONFIG_BT_NIMBLE_SVC_GAP_DEVICE_NAME="nimble"
CONFIG_BT_NIMBLE_GAP_DEVICE_NAME_MAX_LEN=31
CONFIG_BT_NIMBLE_ATT_PREFERRED_MTU=256
CONFIG_BT_NIMBLE_SVC_GAP_APPEARANCE=0
CONFIG_BT_NIMBLE_ACL_BUF_COUNT=12
CONFIG_BT_NIMBLE_ACL_BUF_SIZE=255
CONFIG_BT_NIMBLE_HCI_EVT_BUF_SIZE=70
CONFIG_BT_NIMBLE_HCI_EVT_HI_BUF_COUNT=30
CONFIG_BT_NIMBLE_HCI_EVT_LO_BUF_COUNT=8
CONFIG_BT_NIMBLE_MSYS1_BLOCK_COUNT=12
CONFIG_BT_NIMBLE_HS_FLOW_CTRL=y
CONFIG_BT_NIMBLE_HS_FLOW_CTRL_ITVL=1000
CONFIG_BT_NIMBLE_HS_FLOW_CTRL_THRESH=2
CONFIG_BT_NIMBLE_HS_FLOW_CTRL_TX_ON_DISCONNECT=y
CONFIG_BT_NIMBLE_RPA_TIMEOUT=900
# CONFIG_BT_NIMBLE_MESH is not set
CONFIG_BT_NIMBLE_CRYPTO_STACK_MBEDTLS=y
# end of NimBLE Options
# end of Bluetooth
# CONFIG_BLE_MESH is not set
# CoAP Configuration
CONFIG_COAP_MBEDTLS_PSK=y
# CONFIG_COAP_MBEDTLS_PKI is not set
# CONFIG_COAP_MBEDTLS_DEBUG is not set
CONFIG_COAP_LOG_DEFAULT_LEVEL=0
# end of CoAP Configuration
# Driver configurations
# ADC configuration
# CONFIG_ADC_FORCE_XPD_FSM is not set
CONFIG_ADC_DISABLE_DAC=y
# end of ADC configuration
# SPI configuration
# CONFIG_SPI_MASTER_IN_IRAM is not set
CONFIG_SPI_MASTER_ISR_IN_IRAM=y
# CONFIG_SPI_SLAVE_IN_IRAM is not set
CONFIG_SPI_SLAVE_ISR_IN_IRAM=y
# end of SPI configuration
# UART configuration
# CONFIG_UART_ISR_IN_IRAM is not set
# end of UART configuration
# RTCIO configuration
# CONFIG_RTCIO_SUPPORT_RTC_GPIO_DESC is not set
# end of RTCIO configuration
# end of Driver configurations
# eFuse Bit Manager
# CONFIG_EFUSE_CUSTOM_TABLE is not set
# CONFIG_EFUSE_VIRTUAL is not set
# CONFIG_EFUSE_CODE_SCHEME_COMPAT_NONE is not set
CONFIG_EFUSE_CODE_SCHEME_COMPAT_3_4=y
# CONFIG_EFUSE_CODE_SCHEME_COMPAT_REPEAT is not set
CONFIG_EFUSE_MAX_BLK_LEN=192
# end of eFuse Bit Manager
# ESP-TLS
CONFIG_ESP_TLS_USING_MBEDTLS=y
# CONFIG_ESP_TLS_SERVER is not set
# CONFIG_ESP_TLS_PSK_VERIFICATION is not set
# end of ESP-TLS
# ESP32-specific
CONFIG_ESP32_ECO3_CACHE_LOCK_FIX=y
# CONFIG_ESP32_REV_MIN_0 is not set
# CONFIG_ESP32_REV_MIN_1 is not set
# CONFIG_ESP32_REV_MIN_2 is not set
CONFIG_ESP32_REV_MIN_3=y
CONFIG_ESP32_REV_MIN=3
# CONFIG_ESP32_DEFAULT_CPU_FREQ_80 is not set
CONFIG_ESP32_DEFAULT_CPU_FREQ_160=y
# CONFIG_ESP32_DEFAULT_CPU_FREQ_240 is not set
CONFIG_ESP32_DEFAULT_CPU_FREQ_MHZ=160
CONFIG_ESP32_SPIRAM_SUPPORT=y
# SPI RAM config
CONFIG_SPIRAM_TYPE_AUTO=y
# CONFIG_SPIRAM_TYPE_ESPPSRAM32 is not set
# CONFIG_SPIRAM_TYPE_ESPPSRAM64 is not set
CONFIG_SPIRAM_SIZE=-1
CONFIG_SPIRAM_SPEED_40M=y
CONFIG_SPIRAM=y
CONFIG_SPIRAM_BOOT_INIT=y
# CONFIG_SPIRAM_IGNORE_NOTFOUND is not set
# CONFIG_SPIRAM_USE_MEMMAP is not set
# CONFIG_SPIRAM_USE_CAPS_ALLOC is not set
CONFIG_SPIRAM_USE_MALLOC=y
CONFIG_SPIRAM_MEMTEST=y
CONFIG_SPIRAM_MALLOC_ALWAYSINTERNAL=16384
# CONFIG_SPIRAM_TRY_ALLOCATE_WIFI_LWIP is not set
CONFIG_SPIRAM_MALLOC_RESERVE_INTERNAL=32768
# CONFIG_SPIRAM_ALLOW_BSS_SEG_EXTERNAL_MEMORY is not set
# SPIRAM cache workaround debugging
# end of SPIRAM cache workaround debugging
CONFIG_SPIRAM_BANKSWITCH_ENABLE=y
CONFIG_SPIRAM_BANKSWITCH_RESERVE=8
# CONFIG_SPIRAM_ALLOW_STACK_EXTERNAL_MEMORY is not set
# PSRAM clock and cs IO for ESP32-DOWD
CONFIG_D0WD_PSRAM_CLK_IO=17
CONFIG_D0WD_PSRAM_CS_IO=16
# end of PSRAM clock and cs IO for ESP32-DOWD
# PSRAM clock and cs IO for ESP32-D2WD
CONFIG_D2WD_PSRAM_CLK_IO=9
CONFIG_D2WD_PSRAM_CS_IO=10
# end of PSRAM clock and cs IO for ESP32-D2WD
# PSRAM clock and cs IO for ESP32-PICO
CONFIG_PICO_PSRAM_CS_IO=10
# end of PSRAM clock and cs IO for ESP32-PICO
CONFIG_SPIRAM_SPIWP_SD3_PIN=7
# CONFIG_SPIRAM_2T_MODE is not set
# end of SPI RAM config
# CONFIG_ESP32_TRAX is not set
CONFIG_ESP32_TRACEMEM_RESERVE_DRAM=0x0
# CONFIG_ESP32_UNIVERSAL_MAC_ADDRESSES_TWO is not set
CONFIG_ESP32_UNIVERSAL_MAC_ADDRESSES_FOUR=y
CONFIG_ESP32_UNIVERSAL_MAC_ADDRESSES=4
CONFIG_ESP32_ULP_COPROC_ENABLED=y
CONFIG_ESP32_ULP_COPROC_RESERVE_MEM=512
# CONFIG_ESP32_PANIC_PRINT_HALT is not set
CONFIG_ESP32_PANIC_PRINT_REBOOT=y
# CONFIG_ESP32_PANIC_SILENT_REBOOT is not set
# CONFIG_ESP32_PANIC_GDBSTUB is not set
CONFIG_ESP32_DEBUG_OCDAWARE=y
CONFIG_ESP32_BROWNOUT_DET=y
CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_0=y
# CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_1 is not set
# CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_2 is not set
# CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_3 is not set
# CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_4 is not set
# CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_5 is not set
# CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_6 is not set
# CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_7 is not set
CONFIG_ESP32_BROWNOUT_DET_LVL=0
CONFIG_ESP32_REDUCE_PHY_TX_POWER=y
CONFIG_ESP32_TIME_SYSCALL_USE_RTC_FRC1=y
# CONFIG_ESP32_TIME_SYSCALL_USE_RTC is not set
# CONFIG_ESP32_TIME_SYSCALL_USE_FRC1 is not set
# CONFIG_ESP32_TIME_SYSCALL_USE_NONE is not set
CONFIG_ESP32_RTC_CLK_SRC_INT_RC=y
# CONFIG_ESP32_RTC_CLK_SRC_EXT_CRYS is not set
# CONFIG_ESP32_RTC_CLK_SRC_EXT_OSC is not set
# CONFIG_ESP32_RTC_CLK_SRC_INT_8MD256 is not set
CONFIG_ESP32_RTC_CLK_CAL_CYCLES=1024
CONFIG_ESP32_DEEP_SLEEP_WAKEUP_DELAY=2000
CONFIG_ESP32_XTAL_FREQ_40=y
# CONFIG_ESP32_XTAL_FREQ_26 is not set
# CONFIG_ESP32_XTAL_FREQ_AUTO is not set
CONFIG_ESP32_XTAL_FREQ=40
# CONFIG_ESP32_DISABLE_BASIC_ROM_CONSOLE is not set
# CONFIG_ESP32_COMPATIBLE_PRE_V2_1_BOOTLOADERS is not set
# CONFIG_ESP32_USE_FIXED_STATIC_RAM_SIZE is not set
CONFIG_ESP32_DPORT_DIS_INTERRUPT_LVL=5
# end of ESP32-specific
# Power Management
CONFIG_PM_ENABLE=y
# CONFIG_PM_DFS_INIT_AUTO is not set
# CONFIG_PM_USE_RTC_TIMER_REF is not set
# CONFIG_PM_PROFILING is not set
# CONFIG_PM_TRACE is not set
# end of Power Management
# ADC-Calibration
CONFIG_ADC_CAL_EFUSE_TP_ENABLE=y
CONFIG_ADC_CAL_EFUSE_VREF_ENABLE=y
CONFIG_ADC_CAL_LUT_ENABLE=y
# end of ADC-Calibration
# Common ESP-related
# CONFIG_ESP_TIMER_PROFILING is not set
CONFIG_ESP_ERR_TO_NAME_LOOKUP=y
CONFIG_ESP_SYSTEM_EVENT_QUEUE_SIZE=32
CONFIG_ESP_SYSTEM_EVENT_TASK_STACK_SIZE=2304
CONFIG_ESP_MAIN_TASK_STACK_SIZE=3584
CONFIG_ESP_IPC_TASK_STACK_SIZE=1024
CONFIG_ESP_IPC_USES_CALLERS_PRIORITY=y
CONFIG_ESP_TIMER_TASK_STACK_SIZE=3584
CONFIG_ESP_MINIMAL_SHARED_STACK_SIZE=2048
CONFIG_ESP_CONSOLE_UART_DEFAULT=y
# CONFIG_ESP_CONSOLE_UART_CUSTOM is not set
# CONFIG_ESP_CONSOLE_UART_NONE is not set
CONFIG_ESP_CONSOLE_UART_NUM=0
CONFIG_ESP_CONSOLE_UART_BAUDRATE=115200
CONFIG_ESP_INT_WDT=y
CONFIG_ESP_INT_WDT_TIMEOUT_MS=600
CONFIG_ESP_INT_WDT_CHECK_CPU1=y
CONFIG_ESP_TASK_WDT=y
# CONFIG_ESP_TASK_WDT_PANIC is not set
CONFIG_ESP_TASK_WDT_TIMEOUT_S=5
CONFIG_ESP_TASK_WDT_CHECK_IDLE_TASK_CPU0=y
CONFIG_ESP_TASK_WDT_CHECK_IDLE_TASK_CPU1=y
# CONFIG_ESP_PANIC_HANDLER_IRAM is not set
# end of Common ESP-related
# Ethernet
CONFIG_ETH_ENABLED=y
CONFIG_ETH_USE_ESP32_EMAC=y
CONFIG_ETH_PHY_INTERFACE_RMII=y
# CONFIG_ETH_PHY_INTERFACE_MII is not set
CONFIG_ETH_RMII_CLK_INPUT=y
# CONFIG_ETH_RMII_CLK_OUTPUT is not set
CONFIG_ETH_RMII_CLK_IN_GPIO=0
CONFIG_ETH_DMA_BUFFER_SIZE=512
CONFIG_ETH_DMA_RX_BUFFER_NUM=10
CONFIG_ETH_DMA_TX_BUFFER_NUM=10
CONFIG_ETH_USE_SPI_ETHERNET=y
CONFIG_ETH_SPI_ETHERNET_DM9051=y
# CONFIG_ETH_USE_OPENETH is not set
# end of Ethernet
# Event Loop Library
# CONFIG_ESP_EVENT_LOOP_PROFILING is not set
CONFIG_ESP_EVENT_POST_FROM_ISR=y
CONFIG_ESP_EVENT_POST_FROM_IRAM_ISR=y
# end of Event Loop Library
# GDB Stub
# end of GDB Stub
# ESP HTTP client
CONFIG_ESP_HTTP_CLIENT_ENABLE_HTTPS=y
# CONFIG_ESP_HTTP_CLIENT_ENABLE_BASIC_AUTH is not set
# end of ESP HTTP client
# HTTP Server
CONFIG_HTTPD_MAX_REQ_HDR_LEN=512
CONFIG_HTTPD_MAX_URI_LEN=512
CONFIG_HTTPD_ERR_RESP_NO_DELAY=y
CONFIG_HTTPD_PURGE_BUF_LEN=32
# CONFIG_HTTPD_LOG_PURGE_DATA is not set
# end of HTTP Server
# ESP HTTPS OTA
CONFIG_OTA_ALLOW_HTTP=y
# end of ESP HTTPS OTA
# ESP HTTPS server
# CONFIG_ESP_HTTPS_SERVER_ENABLE is not set
# end of ESP HTTPS server
# ESP NETIF Adapter
CONFIG_ESP_NETIF_IP_LOST_TIMER_INTERVAL=120
CONFIG_ESP_NETIF_TCPIP_LWIP=y
# CONFIG_ESP_NETIF_LOOPBACK is not set
CONFIG_ESP_NETIF_TCPIP_ADAPTER_COMPATIBLE_LAYER=y
# end of ESP NETIF Adapter
# Wi-Fi
CONFIG_ESP32_WIFI_SW_COEXIST_ENABLE=y
CONFIG_ESP32_WIFI_STATIC_RX_BUFFER_NUM=10
CONFIG_ESP32_WIFI_DYNAMIC_RX_BUFFER_NUM=32
CONFIG_ESP32_WIFI_STATIC_TX_BUFFER=y
CONFIG_ESP32_WIFI_TX_BUFFER_TYPE=0
CONFIG_ESP32_WIFI_STATIC_TX_BUFFER_NUM=16
# CONFIG_ESP32_WIFI_CSI_ENABLED is not set
CONFIG_ESP32_WIFI_AMPDU_TX_ENABLED=y
CONFIG_ESP32_WIFI_TX_BA_WIN=6
CONFIG_ESP32_WIFI_AMPDU_RX_ENABLED=y
CONFIG_ESP32_WIFI_RX_BA_WIN=16
CONFIG_ESP32_WIFI_NVS_ENABLED=y
CONFIG_ESP32_WIFI_TASK_PINNED_TO_CORE_0=y
# CONFIG_ESP32_WIFI_TASK_PINNED_TO_CORE_1 is not set
CONFIG_ESP32_WIFI_SOFTAP_BEACON_MAX_LEN=752
CONFIG_ESP32_WIFI_MGMT_SBUF_NUM=32
# CONFIG_ESP32_WIFI_DEBUG_LOG_ENABLE is not set
# CONFIG_ESP32_WIFI_IRAM_OPT is not set
# CONFIG_ESP32_WIFI_RX_IRAM_OPT is not set
CONFIG_ESP32_WIFI_ENABLE_WPA3_SAE=y
# end of Wi-Fi
# PHY
CONFIG_ESP32_PHY_CALIBRATION_AND_DATA_STORAGE=y
# CONFIG_ESP32_PHY_INIT_DATA_IN_PARTITION is not set
CONFIG_ESP32_PHY_MAX_WIFI_TX_POWER=20
CONFIG_ESP32_PHY_MAX_TX_POWER=20
# end of PHY
# Core dump
# CONFIG_ESP32_ENABLE_COREDUMP_TO_FLASH is not set
# CONFIG_ESP32_ENABLE_COREDUMP_TO_UART is not set
CONFIG_ESP32_ENABLE_COREDUMP_TO_NONE=y
# end of Core dump
# FAT Filesystem support
# CONFIG_FATFS_CODEPAGE_DYNAMIC is not set
CONFIG_FATFS_CODEPAGE_437=y
# CONFIG_FATFS_CODEPAGE_720 is not set
# CONFIG_FATFS_CODEPAGE_737 is not set
# CONFIG_FATFS_CODEPAGE_771 is not set
# CONFIG_FATFS_CODEPAGE_775 is not set
# CONFIG_FATFS_CODEPAGE_850 is not set
# CONFIG_FATFS_CODEPAGE_852 is not set
# CONFIG_FATFS_CODEPAGE_855 is not set
# CONFIG_FATFS_CODEPAGE_857 is not set
# CONFIG_FATFS_CODEPAGE_860 is not set
# CONFIG_FATFS_CODEPAGE_861 is not set
# CONFIG_FATFS_CODEPAGE_862 is not set
# CONFIG_FATFS_CODEPAGE_863 is not set
# CONFIG_FATFS_CODEPAGE_864 is not set
# CONFIG_FATFS_CODEPAGE_865 is not set
# CONFIG_FATFS_CODEPAGE_866 is not set
# CONFIG_FATFS_CODEPAGE_869 is not set
# CONFIG_FATFS_CODEPAGE_932 is not set
# CONFIG_FATFS_CODEPAGE_936 is not set
# CONFIG_FATFS_CODEPAGE_949 is not set
# CONFIG_FATFS_CODEPAGE_950 is not set
CONFIG_FATFS_CODEPAGE=437
CONFIG_FATFS_LFN_NONE=y
# CONFIG_FATFS_LFN_HEAP is not set
# CONFIG_FATFS_LFN_STACK is not set
CONFIG_FATFS_FS_LOCK=0
CONFIG_FATFS_TIMEOUT_MS=10000
CONFIG_FATFS_PER_FILE_CACHE=y
CONFIG_FATFS_ALLOC_PREFER_EXTRAM=y
# end of FAT Filesystem support
# Modbus configuration
CONFIG_FMB_COMM_MODE_RTU_EN=y
CONFIG_FMB_COMM_MODE_ASCII_EN=y
CONFIG_FMB_MASTER_TIMEOUT_MS_RESPOND=150
CONFIG_FMB_MASTER_DELAY_MS_CONVERT=200
CONFIG_FMB_QUEUE_LENGTH=20
CONFIG_FMB_SERIAL_TASK_STACK_SIZE=2048
CONFIG_FMB_SERIAL_BUF_SIZE=256
CONFIG_FMB_SERIAL_ASCII_BITS_PER_SYMB=8
CONFIG_FMB_SERIAL_ASCII_TIMEOUT_RESPOND_MS=1000
CONFIG_FMB_SERIAL_TASK_PRIO=10
# CONFIG_FMB_CONTROLLER_SLAVE_ID_SUPPORT is not set
CONFIG_FMB_CONTROLLER_NOTIFY_TIMEOUT=20
CONFIG_FMB_CONTROLLER_NOTIFY_QUEUE_SIZE=20
CONFIG_FMB_CONTROLLER_STACK_SIZE=4096
CONFIG_FMB_EVENT_QUEUE_TIMEOUT=20
CONFIG_FMB_TIMER_PORT_ENABLED=y
CONFIG_FMB_TIMER_GROUP=0
CONFIG_FMB_TIMER_INDEX=0
# CONFIG_FMB_TIMER_ISR_IN_IRAM is not set
# end of Modbus configuration
# FreeRTOS
# CONFIG_FREERTOS_UNICORE is not set
CONFIG_FREERTOS_NO_AFFINITY=0x7FFFFFFF
CONFIG_FREERTOS_CORETIMER_0=y
# CONFIG_FREERTOS_CORETIMER_1 is not set
CONFIG_FREERTOS_HZ=100
CONFIG_FREERTOS_ASSERT_ON_UNTESTED_FUNCTION=y
# CONFIG_FREERTOS_CHECK_STACKOVERFLOW_NONE is not set
# CONFIG_FREERTOS_CHECK_STACKOVERFLOW_PTRVAL is not set
CONFIG_FREERTOS_CHECK_STACKOVERFLOW_CANARY=y
# CONFIG_FREERTOS_WATCHPOINT_END_OF_STACK is not set
CONFIG_FREERTOS_INTERRUPT_BACKTRACE=y
CONFIG_FREERTOS_THREAD_LOCAL_STORAGE_POINTERS=1
CONFIG_FREERTOS_ASSERT_FAIL_ABORT=y
# CONFIG_FREERTOS_ASSERT_FAIL_PRINT_CONTINUE is not set
# CONFIG_FREERTOS_ASSERT_DISABLE is not set
CONFIG_FREERTOS_IDLE_TASK_STACKSIZE=1536
CONFIG_FREERTOS_ISR_STACKSIZE=1536
# CONFIG_FREERTOS_LEGACY_HOOKS is not set
CONFIG_FREERTOS_MAX_TASK_NAME_LEN=16
CONFIG_FREERTOS_SUPPORT_STATIC_ALLOCATION=y
# CONFIG_FREERTOS_ENABLE_STATIC_TASK_CLEAN_UP is not set
CONFIG_FREERTOS_TIMER_TASK_PRIORITY=1
CONFIG_FREERTOS_TIMER_TASK_STACK_DEPTH=2048
CONFIG_FREERTOS_TIMER_QUEUE_LENGTH=10
CONFIG_FREERTOS_QUEUE_REGISTRY_SIZE=0
# CONFIG_FREERTOS_USE_TRACE_FACILITY is not set
# CONFIG_FREERTOS_GENERATE_RUN_TIME_STATS is not set
# CONFIG_FREERTOS_USE_TICKLESS_IDLE is not set
# CONFIG_FREERTOS_DEBUG_INTERNALS is not set
CONFIG_FREERTOS_CHECK_MUTEX_GIVEN_BY_OWNER=y
# CONFIG_FREERTOS_CHECK_PORT_CRITICAL_COMPLIANCE is not set
CONFIG_FREERTOS_DEBUG_OCDAWARE=y
# end of FreeRTOS
# Heap memory debugging
CONFIG_HEAP_POISONING_DISABLED=y
# CONFIG_HEAP_POISONING_LIGHT is not set
# CONFIG_HEAP_POISONING_COMPREHENSIVE is not set
CONFIG_HEAP_TRACING_OFF=y
# CONFIG_HEAP_TRACING_STANDALONE is not set
# CONFIG_HEAP_TRACING_TOHOST is not set
# end of Heap memory debugging
# jsmn
# CONFIG_JSMN_PARENT_LINKS is not set
# CONFIG_JSMN_STRICT is not set
# end of jsmn
# libsodium
# end of libsodium
# Log output
# CONFIG_LOG_DEFAULT_LEVEL_NONE is not set
# CONFIG_LOG_DEFAULT_LEVEL_ERROR is not set
# CONFIG_LOG_DEFAULT_LEVEL_WARN is not set
CONFIG_LOG_DEFAULT_LEVEL_INFO=y
# CONFIG_LOG_DEFAULT_LEVEL_DEBUG is not set
# CONFIG_LOG_DEFAULT_LEVEL_VERBOSE is not set
CONFIG_LOG_DEFAULT_LEVEL=3
CONFIG_LOG_COLORS=y
CONFIG_LOG_TIMESTAMP_SOURCE_RTOS=y
# CONFIG_LOG_TIMESTAMP_SOURCE_SYSTEM is not set
# end of Log output
# LWIP
CONFIG_LWIP_LOCAL_HOSTNAME="espressif"
CONFIG_LWIP_DNS_SUPPORT_MDNS_QUERIES=y
# CONFIG_LWIP_L2_TO_L3_COPY is not set
# CONFIG_LWIP_IRAM_OPTIMIZATION is not set
CONFIG_LWIP_TIMERS_ONDEMAND=y
CONFIG_LWIP_MAX_SOCKETS=10
# CONFIG_LWIP_USE_ONLY_LWIP_SELECT is not set
# CONFIG_LWIP_SO_LINGER is not set
CONFIG_LWIP_SO_REUSE=y
CONFIG_LWIP_SO_REUSE_RXTOALL=y
# CONFIG_LWIP_SO_RCVBUF is not set
# CONFIG_LWIP_NETBUF_RECVINFO is not set
CONFIG_LWIP_IP4_FRAG=y
CONFIG_LWIP_IP6_FRAG=y
# CONFIG_LWIP_IP4_REASSEMBLY is not set
# CONFIG_LWIP_IP6_REASSEMBLY is not set
# CONFIG_LWIP_STATS is not set
# CONFIG_LWIP_ETHARP_TRUST_IP_MAC is not set
CONFIG_LWIP_ESP_GRATUITOUS_ARP=y
CONFIG_LWIP_GARP_TMR_INTERVAL=60
CONFIG_LWIP_TCPIP_RECVMBOX_SIZE=32
CONFIG_LWIP_DHCP_DOES_ARP_CHECK=y
# CONFIG_LWIP_DHCP_RESTORE_LAST_IP is not set
# DHCP server
CONFIG_LWIP_DHCPS_LEASE_UNIT=60
CONFIG_LWIP_DHCPS_MAX_STATION_NUM=8
# end of DHCP server
# CONFIG_LWIP_AUTOIP is not set
# CONFIG_LWIP_IPV6_AUTOCONFIG is not set
CONFIG_LWIP_NETIF_LOOPBACK=y
CONFIG_LWIP_LOOPBACK_MAX_PBUFS=8
# TCP
CONFIG_LWIP_MAX_ACTIVE_TCP=16
CONFIG_LWIP_MAX_LISTENING_TCP=16
CONFIG_LWIP_TCP_MAXRTX=12
CONFIG_LWIP_TCP_SYNMAXRTX=6
CONFIG_LWIP_TCP_MSS=1440
CONFIG_LWIP_TCP_TMR_INTERVAL=250
CONFIG_LWIP_TCP_MSL=60000
CONFIG_LWIP_TCP_SND_BUF_DEFAULT=5744
CONFIG_LWIP_TCP_WND_DEFAULT=5744
CONFIG_LWIP_TCP_RECVMBOX_SIZE=6
CONFIG_LWIP_TCP_QUEUE_OOSEQ=y
# CONFIG_LWIP_TCP_SACK_OUT is not set
# CONFIG_LWIP_TCP_KEEP_CONNECTION_WHEN_IP_CHANGES is not set
CONFIG_LWIP_TCP_OVERSIZE_MSS=y
# CONFIG_LWIP_TCP_OVERSIZE_QUARTER_MSS is not set
# CONFIG_LWIP_TCP_OVERSIZE_DISABLE is not set
CONFIG_LWIP_TCP_RTO_TIME=3000
# end of TCP
# UDP
CONFIG_LWIP_MAX_UDP_PCBS=16
CONFIG_LWIP_UDP_RECVMBOX_SIZE=6
# end of UDP
CONFIG_LWIP_TCPIP_TASK_STACK_SIZE=3072
CONFIG_LWIP_TCPIP_TASK_AFFINITY_NO_AFFINITY=y
# CONFIG_LWIP_TCPIP_TASK_AFFINITY_CPU0 is not set
# CONFIG_LWIP_TCPIP_TASK_AFFINITY_CPU1 is not set
CONFIG_LWIP_TCPIP_TASK_AFFINITY=0x7FFFFFFF
# CONFIG_LWIP_PPP_SUPPORT is not set
CONFIG_LWIP_IPV6_MEMP_NUM_ND6_QUEUE=3
CONFIG_LWIP_IPV6_ND6_NUM_NEIGHBORS=5
# ICMP
# CONFIG_LWIP_MULTICAST_PING is not set
# CONFIG_LWIP_BROADCAST_PING is not set
# end of ICMP
# LWIP RAW API
CONFIG_LWIP_MAX_RAW_PCBS=16
# end of LWIP RAW API
# SNTP
CONFIG_LWIP_DHCP_MAX_NTP_SERVERS=1
CONFIG_LWIP_SNTP_UPDATE_DELAY=3600000
# end of SNTP
# end of LWIP
# mbedTLS
CONFIG_MBEDTLS_INTERNAL_MEM_ALLOC=y
# CONFIG_MBEDTLS_EXTERNAL_MEM_ALLOC is not set
# CONFIG_MBEDTLS_DEFAULT_MEM_ALLOC is not set
# CONFIG_MBEDTLS_CUSTOM_MEM_ALLOC is not set
CONFIG_MBEDTLS_ASYMMETRIC_CONTENT_LEN=y
CONFIG_MBEDTLS_SSL_IN_CONTENT_LEN=16384
CONFIG_MBEDTLS_SSL_OUT_CONTENT_LEN=4096
# CONFIG_MBEDTLS_DEBUG is not set
CONFIG_MBEDTLS_ECP_RESTARTABLE=y
CONFIG_MBEDTLS_CMAC_C=y
CONFIG_MBEDTLS_HARDWARE_AES=y
CONFIG_MBEDTLS_HARDWARE_MPI=y
CONFIG_MBEDTLS_HARDWARE_SHA=y
CONFIG_MBEDTLS_HAVE_TIME=y
# CONFIG_MBEDTLS_HAVE_TIME_DATE is not set
CONFIG_MBEDTLS_TLS_SERVER_AND_CLIENT=y
# CONFIG_MBEDTLS_TLS_SERVER_ONLY is not set
# CONFIG_MBEDTLS_TLS_CLIENT_ONLY is not set
# CONFIG_MBEDTLS_TLS_DISABLED is not set
CONFIG_MBEDTLS_TLS_SERVER=y
CONFIG_MBEDTLS_TLS_CLIENT=y
CONFIG_MBEDTLS_TLS_ENABLED=y
# TLS Key Exchange Methods
# CONFIG_MBEDTLS_PSK_MODES is not set
CONFIG_MBEDTLS_KEY_EXCHANGE_RSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_DHE_RSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ELLIPTIC_CURVE=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_RSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_ECDSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_RSA=y
# end of TLS Key Exchange Methods
CONFIG_MBEDTLS_SSL_RENEGOTIATION=y
# CONFIG_MBEDTLS_SSL_PROTO_SSL3 is not set
CONFIG_MBEDTLS_SSL_PROTO_TLS1=y
CONFIG_MBEDTLS_SSL_PROTO_TLS1_1=y
CONFIG_MBEDTLS_SSL_PROTO_TLS1_2=y
# CONFIG_MBEDTLS_SSL_PROTO_DTLS is not set
CONFIG_MBEDTLS_SSL_ALPN=y
CONFIG_MBEDTLS_CLIENT_SSL_SESSION_TICKETS=y
CONFIG_MBEDTLS_SERVER_SSL_SESSION_TICKETS=y
# Symmetric Ciphers
CONFIG_MBEDTLS_AES_C=y
# CONFIG_MBEDTLS_CAMELLIA_C is not set
# CONFIG_MBEDTLS_DES_C is not set
CONFIG_MBEDTLS_RC4_DISABLED=y
# CONFIG_MBEDTLS_RC4_ENABLED_NO_DEFAULT is not set
# CONFIG_MBEDTLS_RC4_ENABLED is not set
# CONFIG_MBEDTLS_BLOWFISH_C is not set
# CONFIG_MBEDTLS_XTEA_C is not set
CONFIG_MBEDTLS_CCM_C=y
CONFIG_MBEDTLS_GCM_C=y
# end of Symmetric Ciphers
# CONFIG_MBEDTLS_RIPEMD160_C is not set
# Certificates
CONFIG_MBEDTLS_PEM_PARSE_C=y
CONFIG_MBEDTLS_PEM_WRITE_C=y
CONFIG_MBEDTLS_X509_CRL_PARSE_C=y
CONFIG_MBEDTLS_X509_CSR_PARSE_C=y
# end of Certificates
CONFIG_MBEDTLS_ECP_C=y
CONFIG_MBEDTLS_ECDH_C=y
CONFIG_MBEDTLS_ECDSA_C=y
CONFIG_MBEDTLS_ECP_DP_SECP192R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP224R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP256R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP384R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP521R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP192K1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP224K1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP256K1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_BP256R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_BP384R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_BP512R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_CURVE25519_ENABLED=y
CONFIG_MBEDTLS_ECP_NIST_OPTIM=y
# CONFIG_MBEDTLS_SECURITY_RISKS is not set
# end of mbedTLS
# mDNS
CONFIG_MDNS_MAX_SERVICES=10
CONFIG_MDNS_TASK_PRIORITY=1
# CONFIG_MDNS_TASK_AFFINITY_NO_AFFINITY is not set
CONFIG_MDNS_TASK_AFFINITY_CPU0=y
# CONFIG_MDNS_TASK_AFFINITY_CPU1 is not set
CONFIG_MDNS_TASK_AFFINITY=0x0
CONFIG_MDNS_SERVICE_ADD_TIMEOUT_MS=2000
CONFIG_MDNS_TIMER_PERIOD_MS=100
# end of mDNS
# ESP-MQTT Configurations
CONFIG_MQTT_PROTOCOL_311=y
CONFIG_MQTT_TRANSPORT_SSL=y
CONFIG_MQTT_TRANSPORT_WEBSOCKET=y
CONFIG_MQTT_TRANSPORT_WEBSOCKET_SECURE=y
# CONFIG_MQTT_USE_CUSTOM_CONFIG is not set
# CONFIG_MQTT_TASK_CORE_SELECTION_ENABLED is not set
# CONFIG_MQTT_CUSTOM_OUTBOX is not set
# end of ESP-MQTT Configurations
# Newlib
CONFIG_NEWLIB_STDOUT_LINE_ENDING_CRLF=y
# CONFIG_NEWLIB_STDOUT_LINE_ENDING_LF is not set
# CONFIG_NEWLIB_STDOUT_LINE_ENDING_CR is not set
# CONFIG_NEWLIB_STDIN_LINE_ENDING_CRLF is not set
# CONFIG_NEWLIB_STDIN_LINE_ENDING_LF is not set
CONFIG_NEWLIB_STDIN_LINE_ENDING_CR=y
# CONFIG_NEWLIB_NANO_FORMAT is not set
# end of Newlib
# NVS
# end of NVS
# OpenSSL
# CONFIG_OPENSSL_DEBUG is not set
# CONFIG_OPENSSL_ASSERT_DO_NOTHING is not set
CONFIG_OPENSSL_ASSERT_EXIT=y
# end of OpenSSL
# PThreads
CONFIG_PTHREAD_TASK_PRIO_DEFAULT=5
CONFIG_PTHREAD_TASK_STACK_SIZE_DEFAULT=3072
CONFIG_PTHREAD_STACK_MIN=768
CONFIG_PTHREAD_DEFAULT_CORE_NO_AFFINITY=y
# CONFIG_PTHREAD_DEFAULT_CORE_0 is not set
# CONFIG_PTHREAD_DEFAULT_CORE_1 is not set
CONFIG_PTHREAD_TASK_CORE_DEFAULT=-1
CONFIG_PTHREAD_TASK_NAME_DEFAULT="pthread"
# end of PThreads
# SPI Flash driver
# CONFIG_SPI_FLASH_VERIFY_WRITE is not set
# CONFIG_SPI_FLASH_ENABLE_COUNTERS is not set
CONFIG_SPI_FLASH_ROM_DRIVER_PATCH=y
CONFIG_SPI_FLASH_DANGEROUS_WRITE_ABORTS=y
# CONFIG_SPI_FLASH_DANGEROUS_WRITE_FAILS is not set
# CONFIG_SPI_FLASH_DANGEROUS_WRITE_ALLOWED is not set
# CONFIG_SPI_FLASH_USE_LEGACY_IMPL is not set
# CONFIG_SPI_FLASH_BYPASS_BLOCK_ERASE is not set
CONFIG_SPI_FLASH_YIELD_DURING_ERASE=y
CONFIG_SPI_FLASH_ERASE_YIELD_DURATION_MS=20
CONFIG_SPI_FLASH_ERASE_YIELD_TICKS=1
# Auto-detect flash chips
CONFIG_SPI_FLASH_SUPPORT_ISSI_CHIP=y
CONFIG_SPI_FLASH_SUPPORT_GD_CHIP=y
# end of Auto-detect flash chips
# end of SPI Flash driver
# SPIFFS Configuration
CONFIG_SPIFFS_MAX_PARTITIONS=3
# SPIFFS Cache Configuration
CONFIG_SPIFFS_CACHE=y
CONFIG_SPIFFS_CACHE_WR=y
# CONFIG_SPIFFS_CACHE_STATS is not set
# end of SPIFFS Cache Configuration
CONFIG_SPIFFS_PAGE_CHECK=y
CONFIG_SPIFFS_GC_MAX_RUNS=10
# CONFIG_SPIFFS_GC_STATS is not set
CONFIG_SPIFFS_PAGE_SIZE=256
CONFIG_SPIFFS_OBJ_NAME_LEN=32
# CONFIG_SPIFFS_FOLLOW_SYMLINKS is not set
CONFIG_SPIFFS_USE_MAGIC=y
CONFIG_SPIFFS_USE_MAGIC_LENGTH=y
CONFIG_SPIFFS_META_LENGTH=4
CONFIG_SPIFFS_USE_MTIME=y
# Debug Configuration
# CONFIG_SPIFFS_DBG is not set
# CONFIG_SPIFFS_API_DBG is not set
# CONFIG_SPIFFS_GC_DBG is not set
# CONFIG_SPIFFS_CACHE_DBG is not set
# CONFIG_SPIFFS_CHECK_DBG is not set
# CONFIG_SPIFFS_TEST_VISUALISATION is not set
# end of Debug Configuration
# end of SPIFFS Configuration
# Unity unit testing library
CONFIG_UNITY_ENABLE_FLOAT=y
CONFIG_UNITY_ENABLE_DOUBLE=y
# CONFIG_UNITY_ENABLE_COLOR is not set
CONFIG_UNITY_ENABLE_IDF_TEST_RUNNER=y
# CONFIG_UNITY_ENABLE_FIXTURE is not set
# CONFIG_UNITY_ENABLE_BACKTRACE_ON_FAIL is not set
# end of Unity unit testing library
# Virtual file system
CONFIG_VFS_SUPPRESS_SELECT_DEBUG_OUTPUT=y
CONFIG_VFS_SUPPORT_TERMIOS=y
# Host File System I/O (Semihosting)
CONFIG_SEMIHOSTFS_MAX_MOUNT_POINTS=1
CONFIG_SEMIHOSTFS_HOST_PATH_MAX_LEN=128
# end of Host File System I/O (Semihosting)
# end of Virtual file system
# Wear Levelling
# CONFIG_WL_SECTOR_SIZE_512 is not set
CONFIG_WL_SECTOR_SIZE_4096=y
CONFIG_WL_SECTOR_SIZE=4096
# end of Wear Levelling
# Wi-Fi Provisioning Manager
CONFIG_WIFI_PROV_SCAN_MAX_ENTRIES=16
CONFIG_WIFI_PROV_AUTOSTOP_TIMEOUT=30
# end of Wi-Fi Provisioning Manager
# Supplicant
CONFIG_WPA_MBEDTLS_CRYPTO=y
# CONFIG_WPA_TLS_V12 is not set
# CONFIG_WPA_WPS_WARS is not set
# end of Supplicant
# end of Component config
# Compatibility options
# CONFIG_LEGACY_INCLUDE_COMMON_HEADERS is not set
# end of Compatibility options
# Deprecated options for backward compatibility
CONFIG_TOOLPREFIX="xtensa-esp32-elf-"
# CONFIG_LOG_BOOTLOADER_LEVEL_NONE is not set
# CONFIG_LOG_BOOTLOADER_LEVEL_ERROR is not set
# CONFIG_LOG_BOOTLOADER_LEVEL_WARN is not set
CONFIG_LOG_BOOTLOADER_LEVEL_INFO=y
# CONFIG_LOG_BOOTLOADER_LEVEL_DEBUG is not set
# CONFIG_LOG_BOOTLOADER_LEVEL_VERBOSE is not set
CONFIG_LOG_BOOTLOADER_LEVEL=3
# CONFIG_APP_ROLLBACK_ENABLE is not set
# CONFIG_FLASH_ENCRYPTION_ENABLED is not set
# CONFIG_FLASHMODE_QIO is not set
# CONFIG_FLASHMODE_QOUT is not set
CONFIG_FLASHMODE_DIO=y
# CONFIG_FLASHMODE_DOUT is not set
# CONFIG_MONITOR_BAUD_9600B is not set
# CONFIG_MONITOR_BAUD_57600B is not set
CONFIG_MONITOR_BAUD_115200B=y
# CONFIG_MONITOR_BAUD_230400B is not set
# CONFIG_MONITOR_BAUD_921600B is not set
# CONFIG_MONITOR_BAUD_2MB is not set
# CONFIG_MONITOR_BAUD_OTHER is not set
CONFIG_MONITOR_BAUD_OTHER_VAL=115200
CONFIG_MONITOR_BAUD=115200
# CONFIG_COMPILER_OPTIMIZATION_LEVEL_DEBUG is not set
CONFIG_COMPILER_OPTIMIZATION_LEVEL_RELEASE=y
CONFIG_OPTIMIZATION_ASSERTIONS_ENABLED=y
# CONFIG_OPTIMIZATION_ASSERTIONS_SILENT is not set
# CONFIG_OPTIMIZATION_ASSERTIONS_DISABLED is not set
CONFIG_CXX_EXCEPTIONS=y
CONFIG_CXX_EXCEPTIONS_EMG_POOL_SIZE=0
CONFIG_STACK_CHECK_NONE=y
# CONFIG_STACK_CHECK_NORM is not set
# CONFIG_STACK_CHECK_STRONG is not set
# CONFIG_STACK_CHECK_ALL is not set
# CONFIG_WARN_WRITE_STRINGS is not set
# CONFIG_DISABLE_GCC8_WARNINGS is not set
# CONFIG_ESP32_APPTRACE_DEST_TRAX is not set
CONFIG_ESP32_APPTRACE_DEST_NONE=y
CONFIG_ESP32_APPTRACE_LOCK_ENABLE=y
CONFIG_BTDM_CONTROLLER_MODE_BLE_ONLY=y
# CONFIG_BTDM_CONTROLLER_MODE_BR_EDR_ONLY is not set
# CONFIG_BTDM_CONTROLLER_MODE_BTDM is not set
CONFIG_BTDM_CONTROLLER_BLE_MAX_CONN=1
CONFIG_BTDM_CONTROLLER_BLE_MAX_CONN_EFF=1
CONFIG_BTDM_CONTROLLER_BR_EDR_MAX_ACL_CONN_EFF=0
CONFIG_BTDM_CONTROLLER_BR_EDR_MAX_SYNC_CONN_EFF=0
CONFIG_BTDM_CONTROLLER_PINNED_TO_CORE=0
CONFIG_BTDM_CONTROLLER_HCI_MODE_VHCI=y
# CONFIG_BTDM_CONTROLLER_HCI_MODE_UART_H4 is not set
CONFIG_BTDM_CONTROLLER_MODEM_SLEEP=y
CONFIG_BLE_SCAN_DUPLICATE=y
CONFIG_SCAN_DUPLICATE_BY_DEVICE_ADDR=y
# CONFIG_SCAN_DUPLICATE_BY_ADV_DATA is not set
# CONFIG_SCAN_DUPLICATE_BY_ADV_DATA_AND_DEVICE_ADDR is not set
CONFIG_SCAN_DUPLICATE_TYPE=0
CONFIG_DUPLICATE_SCAN_CACHE_SIZE=200
# CONFIG_BLE_MESH_SCAN_DUPLICATE_EN is not set
CONFIG_BTDM_CONTROLLER_FULL_SCAN_SUPPORTED=y
CONFIG_BLE_ADV_REPORT_FLOW_CONTROL_SUPPORTED=y
CONFIG_BLE_ADV_REPORT_FLOW_CONTROL_NUM=100
CONFIG_BLE_ADV_REPORT_DISCARD_THRSHOLD=20
# CONFIG_BLUEDROID_ENABLED is not set
CONFIG_NIMBLE_ENABLED=y
# CONFIG_NIMBLE_MEM_ALLOC_MODE_INTERNAL is not set
CONFIG_NIMBLE_MEM_ALLOC_MODE_EXTERNAL=y
# CONFIG_NIMBLE_MEM_ALLOC_MODE_DEFAULT is not set
CONFIG_NIMBLE_MAX_CONNECTIONS=1
CONFIG_NIMBLE_MAX_BONDS=3
CONFIG_NIMBLE_MAX_CCCDS=8
CONFIG_NIMBLE_L2CAP_COC_MAX_NUM=0
CONFIG_NIMBLE_PINNED_TO_CORE_0=y
# CONFIG_NIMBLE_PINNED_TO_CORE_1 is not set
CONFIG_NIMBLE_PINNED_TO_CORE=0
CONFIG_NIMBLE_TASK_STACK_SIZE=512
CONFIG_NIMBLE_ROLE_CENTRAL=y
CONFIG_NIMBLE_ROLE_PERIPHERAL=y
CONFIG_NIMBLE_ROLE_BROADCASTER=y
CONFIG_NIMBLE_ROLE_OBSERVER=y
CONFIG_NIMBLE_NVS_PERSIST=y
CONFIG_NIMBLE_SM_LEGACY=y
CONFIG_NIMBLE_SM_SC=y
# CONFIG_NIMBLE_DEBUG is not set
# CONFIG_NIMBLE_SM_SC_DEBUG_KEYS is not set
CONFIG_NIMBLE_SVC_GAP_DEVICE_NAME="nimble"
CONFIG_NIMBLE_GAP_DEVICE_NAME_MAX_LEN=31
CONFIG_NIMBLE_ATT_PREFERRED_MTU=256
CONFIG_NIMBLE_SVC_GAP_APPEARANCE=0
CONFIG_NIMBLE_ACL_BUF_COUNT=12
CONFIG_NIMBLE_ACL_BUF_SIZE=255
CONFIG_NIMBLE_HCI_EVT_BUF_SIZE=70
CONFIG_NIMBLE_HCI_EVT_HI_BUF_COUNT=30
CONFIG_NIMBLE_HCI_EVT_LO_BUF_COUNT=8
CONFIG_NIMBLE_MSYS1_BLOCK_COUNT=12
CONFIG_NIMBLE_HS_FLOW_CTRL=y
CONFIG_NIMBLE_HS_FLOW_CTRL_ITVL=1000
CONFIG_NIMBLE_HS_FLOW_CTRL_THRESH=2
CONFIG_NIMBLE_HS_FLOW_CTRL_TX_ON_DISCONNECT=y
CONFIG_NIMBLE_RPA_TIMEOUT=900
# CONFIG_NIMBLE_MESH is not set
CONFIG_NIMBLE_CRYPTO_STACK_MBEDTLS=y
CONFIG_ADC2_DISABLE_DAC=y
CONFIG_SPIRAM_SUPPORT=y
# CONFIG_WIFI_LWIP_ALLOCATION_FROM_SPIRAM_FIRST is not set
CONFIG_TRACEMEM_RESERVE_DRAM=0x0
# CONFIG_TWO_UNIVERSAL_MAC_ADDRESS is not set
CONFIG_FOUR_UNIVERSAL_MAC_ADDRESS=y
CONFIG_NUMBER_OF_UNIVERSAL_MAC_ADDRESS=4
CONFIG_ULP_COPROC_ENABLED=y
CONFIG_ULP_COPROC_RESERVE_MEM=512
CONFIG_BROWNOUT_DET=y
CONFIG_BROWNOUT_DET_LVL_SEL_0=y
# CONFIG_BROWNOUT_DET_LVL_SEL_1 is not set
# CONFIG_BROWNOUT_DET_LVL_SEL_2 is not set
# CONFIG_BROWNOUT_DET_LVL_SEL_3 is not set
# CONFIG_BROWNOUT_DET_LVL_SEL_4 is not set
# CONFIG_BROWNOUT_DET_LVL_SEL_5 is not set
# CONFIG_BROWNOUT_DET_LVL_SEL_6 is not set
# CONFIG_BROWNOUT_DET_LVL_SEL_7 is not set
CONFIG_BROWNOUT_DET_LVL=0
CONFIG_REDUCE_PHY_TX_POWER=y
CONFIG_ESP32_RTC_CLOCK_SOURCE_INTERNAL_RC=y
# CONFIG_ESP32_RTC_CLOCK_SOURCE_EXTERNAL_CRYSTAL is not set
# CONFIG_ESP32_RTC_CLOCK_SOURCE_EXTERNAL_OSC is not set
# CONFIG_ESP32_RTC_CLOCK_SOURCE_INTERNAL_8MD256 is not set
# CONFIG_DISABLE_BASIC_ROM_CONSOLE is not set
# CONFIG_COMPATIBLE_PRE_V2_1_BOOTLOADERS is not set
CONFIG_SYSTEM_EVENT_QUEUE_SIZE=32
CONFIG_SYSTEM_EVENT_TASK_STACK_SIZE=2304
CONFIG_MAIN_TASK_STACK_SIZE=3584
CONFIG_IPC_TASK_STACK_SIZE=1024
CONFIG_TIMER_TASK_STACK_SIZE=3584
CONFIG_CONSOLE_UART_DEFAULT=y
# CONFIG_CONSOLE_UART_CUSTOM is not set
# CONFIG_CONSOLE_UART_NONE is not set
CONFIG_CONSOLE_UART_NUM=0
CONFIG_CONSOLE_UART_BAUDRATE=115200
CONFIG_INT_WDT=y
CONFIG_INT_WDT_TIMEOUT_MS=600
CONFIG_INT_WDT_CHECK_CPU1=y
CONFIG_TASK_WDT=y
# CONFIG_TASK_WDT_PANIC is not set
CONFIG_TASK_WDT_TIMEOUT_S=5
CONFIG_TASK_WDT_CHECK_IDLE_TASK_CPU0=y
CONFIG_TASK_WDT_CHECK_IDLE_TASK_CPU1=y
# CONFIG_EVENT_LOOP_PROFILING is not set
CONFIG_POST_EVENTS_FROM_ISR=y
CONFIG_POST_EVENTS_FROM_IRAM_ISR=y
CONFIG_SW_COEXIST_ENABLE=y
CONFIG_MB_MASTER_TIMEOUT_MS_RESPOND=150
CONFIG_MB_MASTER_DELAY_MS_CONVERT=200
CONFIG_MB_QUEUE_LENGTH=20
CONFIG_MB_SERIAL_TASK_STACK_SIZE=2048
CONFIG_MB_SERIAL_BUF_SIZE=256
CONFIG_MB_SERIAL_TASK_PRIO=10
# CONFIG_MB_CONTROLLER_SLAVE_ID_SUPPORT is not set
CONFIG_MB_CONTROLLER_NOTIFY_TIMEOUT=20
CONFIG_MB_CONTROLLER_NOTIFY_QUEUE_SIZE=20
CONFIG_MB_CONTROLLER_STACK_SIZE=4096
CONFIG_MB_EVENT_QUEUE_TIMEOUT=20
CONFIG_MB_TIMER_PORT_ENABLED=y
CONFIG_MB_TIMER_GROUP=0
CONFIG_MB_TIMER_INDEX=0
CONFIG_SUPPORT_STATIC_ALLOCATION=y
# CONFIG_ENABLE_STATIC_TASK_CLEAN_UP_HOOK is not set
CONFIG_TIMER_TASK_PRIORITY=1
CONFIG_TIMER_TASK_STACK_DEPTH=2048
CONFIG_TIMER_QUEUE_LENGTH=10
# CONFIG_L2_TO_L3_COPY is not set
# CONFIG_USE_ONLY_LWIP_SELECT is not set
CONFIG_ESP_GRATUITOUS_ARP=y
CONFIG_GARP_TMR_INTERVAL=60
CONFIG_TCPIP_RECVMBOX_SIZE=32
CONFIG_TCP_MAXRTX=12
CONFIG_TCP_SYNMAXRTX=6
CONFIG_TCP_MSS=1440
CONFIG_TCP_MSL=60000
CONFIG_TCP_SND_BUF_DEFAULT=5744
CONFIG_TCP_WND_DEFAULT=5744
CONFIG_TCP_RECVMBOX_SIZE=6
CONFIG_TCP_QUEUE_OOSEQ=y
# CONFIG_ESP_TCP_KEEP_CONNECTION_WHEN_IP_CHANGES is not set
CONFIG_TCP_OVERSIZE_MSS=y
# CONFIG_TCP_OVERSIZE_QUARTER_MSS is not set
# CONFIG_TCP_OVERSIZE_DISABLE is not set
CONFIG_UDP_RECVMBOX_SIZE=6
CONFIG_TCPIP_TASK_STACK_SIZE=3072
CONFIG_TCPIP_TASK_AFFINITY_NO_AFFINITY=y
# CONFIG_TCPIP_TASK_AFFINITY_CPU0 is not set
# CONFIG_TCPIP_TASK_AFFINITY_CPU1 is not set
CONFIG_TCPIP_TASK_AFFINITY=0x7FFFFFFF
# CONFIG_PPP_SUPPORT is not set
CONFIG_ESP32_PTHREAD_TASK_PRIO_DEFAULT=5
CONFIG_ESP32_PTHREAD_TASK_STACK_SIZE_DEFAULT=3072
CONFIG_ESP32_PTHREAD_STACK_MIN=768
CONFIG_ESP32_DEFAULT_PTHREAD_CORE_NO_AFFINITY=y
# CONFIG_ESP32_DEFAULT_PTHREAD_CORE_0 is not set
# CONFIG_ESP32_DEFAULT_PTHREAD_CORE_1 is not set
CONFIG_ESP32_PTHREAD_TASK_CORE_DEFAULT=-1
CONFIG_ESP32_PTHREAD_TASK_NAME_DEFAULT="pthread"
CONFIG_SPI_FLASH_WRITING_DANGEROUS_REGIONS_ABORTS=y
# CONFIG_SPI_FLASH_WRITING_DANGEROUS_REGIONS_FAILS is not set
# CONFIG_SPI_FLASH_WRITING_DANGEROUS_REGIONS_ALLOWED is not set
CONFIG_SUPPRESS_SELECT_DEBUG_OUTPUT=y
CONFIG_SUPPORT_TERMIOS=y
# End of deprecated options
# ESP-IDF Partition Table
# Name, Type, SubType, Offset, Size, Flags
nvs, data, nvs, 0x9000, 0x4000,
otadata, data, ota, 0xd000, 0x2000,
phy_init, data, phy, 0xf000, 0x1000,
ota_0, 0, ota_0, 0x10000, 0x190000,
ota_1, 0, ota_1, 0x200000, 0x190000,
