I (1474) wifi:wifi driver task: 3ffc6bf8, prio:23, stack:6656, core=0
I (1499) wifi:wifi firmware version: 9c89486
I (1499) wifi:wifi certification version: v7.0
I (1499) wifi:config NVS flash: enabled
I (1500) wifi:config nano formating: disabled
I (1504) wifi:Init data frame dynamic rx buffer num: 32
I (1509) wifi:Init management frame dynamic rx buffer num: 32
I (1514) wifi:Init management short buffer num: 32
I (1519) wifi:Init dynamic tx buffer num: 32
I (1523) wifi:Init static rx buffer size: 1600
I (1527) wifi:Init static rx buffer num: 10
I (1531) wifi:Init dynamic rx buffer num: 32
I (10412) wifi:set country: cc=US schan=1 nchan=11 policy=0
D (10416) wifi:clear blacklist
D (10510) wifi:filter: set rx policy=0
I (10511) wifi:mode : sta (f0:08:d1:79:8c:28)
D (10512) wifi:filter: set rx policy=1
D (10516) wifi:connect status 0 -> 0
D (10523) wifi:Start wifi connect
D (10526) wifi:connect status 0 -> 0
D (10529) wifi:connect chan=0
D (10532) wifi:first chan=1
D (10534) wifi:connect status 0 -> 1
D (10538) wifi:filter: set rx policy=3
D (10541) wifi:clear scan ap list
D (10544) wifi:start scan: type=0x50f, priority=2, cb=0x40164534, arg=0x0, ss_state=0x1, time=35459, index=0
0x40164534: cnx_start_handoff_cb at ??:?
D (10554) wifi:perform scan: ss_state=0x9, chan<1,0>, dur<0,120>
D (10680) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (10680) wifi:perform scan: ss_state=0x9, chan<2,0>, dur<0,120>
D (10802) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (10802) wifi:perform scan: ss_state=0x9, chan<3,0>, dur<0,120>
D (10923) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (10923) wifi:perform scan: ss_state=0x9, chan<4,0>, dur<0,120>
D (11044) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (11045) wifi:perform scan: ss_state=0x9, chan<5,0>, dur<0,120>
D (11165) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (11166) wifi:perform scan: ss_state=0x9, chan<6,0>, dur<0,120>
D (11287) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (11287) wifi:perform scan: ss_state=0x9, chan<7,0>, dur<0,120>
D (11408) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (11409) wifi:perform scan: ss_state=0x9, chan<8,0>, dur<0,120>
D (11529) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (11530) wifi:perform scan: ss_state=0x9, chan<9,0>, dur<0,120>
D (11651) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (11651) wifi:perform scan: ss_state=0x9, chan<10,0>, dur<0,120>
D (11772) wifi:scan end: arg=0x0, status=0, ss_state=0x3
D (11773) wifi:perform scan: ss_state=0x9, chan<11,0>, dur<0,120>
D (11779) wifi:rsn valid: gcipher=3 ucipher=3 akm=5
D (11781) wifi:profile match: ss_state=0x7
D (11801) wifi:rsn valid: gcipher=3 ucipher=3 akm=5
D (11801) wifi:set max rate: from <rate=130, phy=3, sig=0> to <rate=144, phy=3 sig=0>
D (11802) wifi:sig_b=0, sig_g=0, sig_n=0, max_b=22, max_g=108, max_n=144
D (11808) wifi:profile match: ss_state=0x7
D (11893) wifi:scan end: arg=0x0, status=0, ss_state=0x7
D (11894) wifi:find first mathched ssid, scan done
D (11894) wifi:filter: set rx policy=4
D (11896) wifi:first chan=1
D (11898) wifi:handoff_cb: status=0
D (11901) wifi:ap found, mac=18:a6:f7:ab:ca:66
D (11905) wifi:new_bss=0x3ffb7d58, cur_bss=0x0, new_chan=<11,2>, cur_chan=1
D (11912) wifi:filter: set rx policy=5
I (11916) wifi:new:<11,2>, old:<1,0>, ap:<255,255>, sta:<11,2>, prof:1
D (11922) wifi:connect_op: status=0, auth=5, cipher=3
D (11927) wifi:auth mode is not none
D (12461) wifi:connect_bss: auth=1, reconnect=0
I (12461) wifi:state: init -> auth (b0)
D (12462) wifi:start 1s AUTH timer
D (12462) wifi:clear scan ap list
D (12465) wifi:rsn valid: gcipher=3 ucipher=3 akm=5
D (12469) wifi:rsn valid: gcipher=3 ucipher=3 akm=5
D (12474) wifi:rsn valid: gcipher=3 ucipher=3 akm=5
D (12478) wifi:rsn valid: gcipher=3 ucipher=3 akm=5
D (12483) wifi:rsn valid: gcipher=3 ucipher=3 akm=5
D (12490) wifi:recv auth: seq=2, status=0
I (12491) wifi:state: auth -> assoc (0)
D (12495) wifi:restart connect 1s timer for assoc
D (12515) wifi:recv assoc: type=0x10
D (12515) wifi:filter: set rx policy=6
I (12515) wifi:state: assoc -> run (10)
D (12516) wifi:start 10s connect timer for 4 way handshake
D (12520) wifi:rsn valid: gcipher=3 ucipher=3 akm=5
I (12532) wifi:connected with TEST-AP, aid = 1, channel 11, 40D, bssid = 18:a6:f7:ab:ca:66
I (12532) wifi:security: WPA2-PSK, phy: bgn, rssi: -35
D (12537) wifi:remove all except 18:a6:f7:ab:ca:66 from rc list
D (12543) wifi:clear blacklist
D (12546) wifi:filter: set rx policy=7
I (12549) wifi:pm start, type: 1
D (12552) wifi:Send sta connected event
D (12556) wifi:connect status 1 -> 5
D (12559) wifi:obss scan is disabled
D (12562) wifi:start obss scan: obss scan is stopped
I (12620) wifi:AP's beacon interval = 102400 us, DTIM period = 1
I (14474) wifi:Set ps type: 1
I (1597530) wifi:state: run -> init (ce00)
D (1597531) wifi:connect status 5 -> 6
D (1597531) wifi:stop beacon/connect timer, send diassoc(8)
D (1597533) wifi:sta leave
I (1597535) wifi:pm stop, total sleep time: 1347002455 us / 1584983019 us
D (1597542) wifi:stop CSA timer
D (1597545) wifi:remove 18:a6:f7:ab:ca:66 from rc list
I (1597549) wifi:new:<11,0>, old:<11,2>, ap:<255,255>, sta:<11,2>, prof:1
D (1597557) wifi:filter: set rx policy=8
D (1597560) wifi:Send disconnect event, reason=8, AP number=0
D (1597588) wifi:Start wifi connect
D (1597591) wifi:connect status 6 -> 0
D (1597594) wifi:connect chan=0
D (1597597) wifi:first chan=11
D (1597600) wifi:connect status 0 -> 1
D (1597604) wifi:filter: set rx policy=3
D (1597607) wifi:clear scan ap list
D (1597610) wifi:start scan: type=0x50f, priority=2, cb=0x40164534, arg=0x0, ss_state=0x1, time=1595304308, index=0
D (1597620) wifi:perform scan: ss_state=0x9, chan<11,0>, dur<0,120>
D (1597633) wifi:rsn valid: gcipher=3 ucipher=3 akm=5
D (1597634) wifi:profile match: ss_state=0x7
D (1597636) wifi:rsn valid: gcipher=3 ucipher=3 akm=5
D (1597640) wifi:set max rate: from <rate=130, phy=3, sig=0> to <rate=144, phy=3 sig=0>
D (1597648) wifi:sig_b=0, sig_g=0, sig_n=0, max_b=22, max_g=108, max_n=144
D (1597655) wifi:profile match: ss_state=0x7
D (1597735) wifi:rsn valid: gcipher=3 ucipher=3 akm=5
D (1597735) wifi:profile match: ss_state=0x7
D (1597747) wifi:scan end: arg=0x0, status=0, ss_state=0x7
D (1597747) wifi:find first mathched ssid, scan done
D (1597747) wifi:filter: set rx policy=4
D (1597750) wifi:first chan=1
D (1597752) wifi:handoff_cb: status=0
D (1597756) wifi:ap found, mac=18:a6:f7:ab:ca:66
D (1597760) wifi:new_bss=0x3ffb7d58, cur_bss=0x0, new_chan=<11,2>, cur_chan=11
D (1597767) wifi:filter: set rx policy=5
I (1597771) wifi:new:<11,2>, old:<11,0>, ap:<255,255>, sta:<11,2>, prof:1
D (1597778) wifi:connect_op: status=0, auth=5, cipher=3
D (1597782) wifi:auth mode is not none
D (1597786) wifi:connect_bss: auth=1, reconnect=0
I (1597790) wifi:state: init -> auth (b0)
D (1597794) wifi:start 1s AUTH timer
D (1597797) wifi:clear scan ap list
D (1597805) wifi:recv auth: seq=2, status=0
I (1597805) wifi:state: auth -> assoc (0)
D (1597809) wifi:restart connect 1s timer for assoc
D (1597823) wifi:recv assoc: type=0x10
D (1597823) wifi:filter: set rx policy=6
I (1597824) wifi:state: assoc -> run (10)
D (1597824) wifi:start 10s connect timer for 4 way handshake
D (1597837) wifi:rsn valid: gcipher=3 ucipher=3 akm=5
I (1597839) wifi:connected with TEST-AP, aid = 1, channel 11, 40D, bssid = 18:a6:f7:ab:ca:66
I (1597842) wifi:security: WPA2-PSK, phy: bgn, rssi: -36
D (1597847) wifi:remove all except 18:a6:f7:ab:ca:66 from rc list
D (1597853) wifi:clear blacklist
D (1597856) wifi:filter: set rx policy=7
I (1597860) wifi:pm start, type: 1
D (1597863) wifi:Send sta connected event
D (1597867) wifi:connect status 1 -> 5
D (1597870) wifi:obss scan is disabled
D (1597873) wifi:start obss scan: obss scan is stopped
I (1597939) wifi:AP's beacon interval = 102400 us, DTIM period = 1
I (11603449) wifi:state: run -> init (ce00)
D (11603450) wifi:connect status 5 -> 6
D (11603450) wifi:stop beacon/connect timer, send diassoc(8)
D (11603453) wifi:sta leave
I (11603454) wifi:pm stop, total sleep time: 7966078594 us / 10005591542 us
D (11603461) wifi:stop CSA timer
D (11603464) wifi:remove 18:a6:f7:ab:ca:66 from rc list
I (11603469) wifi:new:<11,0>, old:<11,2>, ap:<255,255>, sta:<11,2>, prof:1
D (11603476) wifi:filter: set rx policy=8
D (11603479) wifi:Send disconnect event, reason=8, AP number=0
D (11603508) wifi:Start wifi connect
D (11603511) wifi:connect status 6 -> 0
D (11603515) wifi:connect chan=0
D (11603518) wifi:first chan=11
D (11603520) wifi:connect status 0 -> 1
D (11603524) wifi:filter: set rx policy=3
D (11603528) wifi:clear scan ap list
D (11603531) wifi:start scan: type=0x50f, priority=2, cb=0x40164534, arg=0x0, ss_state=0x1, time=-1233280566, index=0
D (11603541) wifi:perform scan: ss_state=0x9, chan<11,0>, dur<0,120>
D (11603552) wifi:rsn valid: gcipher=3 ucipher=3 akm=5
D (11603553) wifi:profile match: ss_state=0x7
D (11603557) wifi:rsn valid: gcipher=3 ucipher=3 akm=5
D (11603562) wifi:set max rate: from <rate=130, phy=3, sig=0> to <rate=144, phy=3 sig=0>
D (11603569) wifi:sig_b=0, sig_g=0, sig_n=0, max_b=22, max_g=108, max_n=144
D (11603576) wifi:profile match: ss_state=0x7
D (11603653) wifi:rsn valid: gcipher=3 ucipher=3 akm=5
D (11603654) wifi:profile match: ss_state=0x7
D (11603668) wifi:scan end: arg=0x0, status=0, ss_state=0x7
D (11603668) wifi:find first mathched ssid, scan done
D (11603669) wifi:filter: set rx policy=4
D (11603671) wifi:first chan=1
D (11603674) wifi:handoff_cb: status=0
D (11603677) wifi:ap found, mac=18:a6:f7:ab:ca:66
D (11603682) wifi:new_bss=0x3ffb7d58, cur_bss=0x0, new_chan=<11,2>, cur_chan=11
D (11603689) wifi:filter: set rx policy=5
I (11603693) wifi:new:<11,2>, old:<11,0>, ap:<255,255>, sta:<11,2>, prof:1
D (11603700) wifi:connect_op: status=0, auth=5, cipher=3
D (11603704) wifi:auth mode is not none
D (11603708) wifi:connect_bss: auth=1, reconnect=0
I (11603712) wifi:state: init -> auth (b0)
D (11603717) wifi:start 1s AUTH timer
D (11603720) wifi:clear scan ap list
D (11603725) wifi:recv auth: seq=2, status=0
I (11603727) wifi:state: auth -> assoc (0)
D (11603731) wifi:restart connect 1s timer for assoc
D (11603745) wifi:recv assoc: type=0x10
D (11603746) wifi:filter: set rx policy=6
I (11603746) wifi:state: assoc -> run (10)
D (11603747) wifi:start 10s connect timer for 4 way handshake
D (11603756) wifi:rsn valid: gcipher=3 ucipher=3 akm=5
I (11603761) wifi:connected with TEST-AP, aid = 1, channel 11, 40D, bssid = 18:a6:f7:ab:ca:66
I (11603765) wifi:security: WPA2-PSK, phy: bgn, rssi: -38
D (11603770) wifi:remove all except 18:a6:f7:ab:ca:66 from rc list
D (11603776) wifi:clear blacklist
D (11603779) wifi:filter: set rx policy=7
I (11603783) wifi:pm start, type: 1
D (11603787) wifi:Send sta connected event
D (11603790) wifi:connect status 1 -> 5
D (11603794) wifi:obss scan is disabled
D (11603797) wifi:start obss scan: obss scan is stopped
I (11603860) wifi:AP's beacon interval = 102400 us, DTIM period = 1
I (11644072) wifi:state: run -> init (ce00)
D (11644073) wifi:connect status 5 -> 6
D (11644073) wifi:stop beacon/connect timer, send diassoc(8)
D (11644076) wifi:sta leave
I (11644077) wifi:pm stop, total sleep time: 30399387 us / 40290930 us
D (11644084) wifi:stop CSA timer
D (11644087) wifi:remove 18:a6:f7:ab:ca:66 from rc list
I (11644092) wifi:new:<11,0>, old:<11,2>, ap:<255,255>, sta:<11,2>, prof:1
D (11644099) wifi:filter: set rx policy=8
D (11644102) wifi:Send disconnect event, reason=8, AP number=0
D (11644118) wifi:Start wifi connect
D (11644121) wifi:connect status 6 -> 0
D (11644125) wifi:connect chan=0
D (11644128) wifi:first chan=11
D (11644131) wifi:connect status 0 -> 1
D (11644134) wifi:filter: set rx policy=3
D (11644138) wifi:clear scan ap list
D (11644141) wifi:start scan: type=0x50f, priority=2, cb=0x40164534, arg=0x0, ss_state=0x1, time=-1192471841, index=0
D (11644152) wifi:perform scan: ss_state=0x9, chan<11,0>, dur<0,120>
D (11644164) wifi:rsn valid: gcipher=3 ucipher=3 akm=5
D (11644165) wifi:profile match: ss_state=0x7
D (11644173) wifi:rsn valid: gcipher=3 ucipher=3 akm=5
D (11644174) wifi:set max rate: from <rate=130, phy=3, sig=0> to <rate=144, phy=3 sig=0>
D (11644180) wifi:sig_b=0, sig_g=0, sig_n=0, max_b=22, max_g=108, max_n=144
D (11644186) wifi:profile match: ss_state=0x7
D (11644276) wifi:rsn valid: gcipher=3 ucipher=3 akm=5
D (11644277) wifi:profile match: ss_state=0x7
D (11644278) wifi:scan end: arg=0x0, status=0, ss_state=0x7
D (11644280) wifi:find first mathched ssid, scan done
D (11644285) wifi:filter: set rx policy=4
D (11644288) wifi:first chan=1
D (11644291) wifi:handoff_cb: status=0
D (11644295) wifi:ap found, mac=18:a6:f7:ab:ca:66
D (11644299) wifi:new_bss=0x3ffb7d58, cur_bss=0x0, new_chan=<11,2>, cur_chan=11
D (11644306) wifi:filter: set rx policy=5
I (11644310) wifi:new:<11,2>, old:<11,0>, ap:<255,255>, sta:<11,2>, prof:1
D (11644317) wifi:connect_op: status=0, auth=5, cipher=3
D (11644321) wifi:auth mode is not none
D (11644325) wifi:connect_bss: auth=1, reconnect=0
I (11644329) wifi:state: init -> auth (b0)
D (11644334) wifi:start 1s AUTH timer
D (11644337) wifi:clear scan ap list
D (11644342) wifi:recv auth: seq=2, status=0
I (11644344) wifi:state: auth -> assoc (0)
D (11644348) wifi:restart connect 1s timer for assoc
D (11644362) wifi:recv assoc: type=0x10
D (11644363) wifi:filter: set rx policy=6
I (11644363) wifi:state: assoc -> run (10)
D (11644364) wifi:start 10s connect timer for 4 way handshake
D (11644379) wifi:rsn valid: gcipher=3 ucipher=3 akm=5
I (11644381) wifi:connected with TEST-AP, aid = 1, channel 11, 40D, bssid = 18:a6:f7:ab:ca:66
I (11644382) wifi:security: WPA2-PSK, phy: bgn, rssi: -38
D (11644388) wifi:remove all except 18:a6:f7:ab:ca:66 from rc list
D (11644393) wifi:clear blacklist
D (11644397) wifi:filter: set rx policy=7
I (11644400) wifi:pm start, type: 1
D (11644404) wifi:Send sta connected event
D (11644408) wifi:connect status 1 -> 5
D (11644411) wifi:obss scan is disabled
D (11644415) wifi:start obss scan: obss scan is stopped
I (11644480) wifi:AP's beacon interval = 102400 us, DTIM period = 1
I (27854225) wifi:state: run -> init (ce00)
D (27854226) wifi:connect status 5 -> 6
D (27854226) wifi:stop beacon/connect timer, send diassoc(8)
D (27854229) wifi:sta leave
I (27854230) wifi:pm stop, total sleep time: 13207842995 us / 16209826507 us
D (27854237) wifi:stop CSA timer
D (27854240) wifi:remove 18:a6:f7:ab:ca:66 from rc list
I (27854245) wifi:new:<11,0>, old:<11,2>, ap:<255,255>, sta:<11,2>, prof:1
D (27854252) wifi:filter: set rx policy=8
D (27854255) wifi:Send disconnect event, reason=8, AP number=0
D (27854272) wifi:Start wifi connect
D (27854275) wifi:connect status 6 -> 0
D (27854278) wifi:connect chan=0
D (27854281) wifi:first chan=11
D (27854284) wifi:connect status 0 -> 1
D (27854288) wifi:filter: set rx policy=3
D (27854291) wifi:clear scan ap list
D (27854295) wifi:start scan: type=0x50f, priority=2, cb=0x40164534, arg=0x0, ss_state=0x1, time=-2079088348, index=0
D (27854305) wifi:perform scan: ss_state=0x9, chan<11,0>, dur<0,120>
D (27854317) wifi:rsn valid: gcipher=3 ucipher=3 akm=5
D (27854319) wifi:profile match: ss_state=0x7
D (27854327) wifi:rsn valid: gcipher=3 ucipher=3 akm=5
D (27854327) wifi:set max rate: from <rate=130, phy=3, sig=0> to <rate=144, phy=3 sig=0>
D (27854333) wifi:sig_b=0, sig_g=0, sig_n=0, max_b=22, max_g=108, max_n=144
D (27854340) wifi:profile match: ss_state=0x7
D (27854429) wifi:rsn valid: gcipher=3 ucipher=3 akm=5
D (27854430) wifi:profile match: ss_state=0x7
D (27854432) wifi:scan end: arg=0x0, status=0, ss_state=0x7
D (27854433) wifi:find first mathched ssid, scan done
D (27854437) wifi:filter: set rx policy=4
D (27854441) wifi:first chan=1
D (27854444) wifi:handoff_cb: status=0
D (27854447) wifi:ap found, mac=18:a6:f7:ab:ca:66
D (27854452) wifi:new_bss=0x3ffb7d58, cur_bss=0x0, new_chan=<11,2>, cur_chan=11
D (27854459) wifi:filter: set rx policy=5
I (27854463) wifi:new:<11,2>, old:<11,0>, ap:<255,255>, sta:<11,2>, prof:1
D (27854470) wifi:connect_op: status=0, auth=5, cipher=3
D (27854474) wifi:auth mode is not none
D (27854478) wifi:connect_bss: auth=1, reconnect=0
I (27854482) wifi:state: init -> auth (b0)
D (27854487) wifi:start 1s AUTH timer
D (27854490) wifi:clear scan ap list
D (27854496) wifi:recv auth: seq=2, status=0
I (27854497) wifi:state: auth -> assoc (0)
D (27854501) wifi:restart connect 1s timer for assoc
D (27854521) wifi:recv assoc: type=0x10
D (27854522) wifi:filter: set rx policy=6
I (27854522) wifi:state: assoc -> run (10)
D (27854523) wifi:start 10s connect timer for 4 way handshake
I (27854579) wifi:connected with TEST-AP, aid = 1, channel 11, 40D, bssid = 18:a6:f7:ab:ca:66
I (27854579) wifi:security: WPA2-PSK, phy: bgn, rssi: -40
D (27854581) wifi:remove all except 18:a6:f7:ab:ca:66 from rc list
D (27854587) wifi:clear blacklist
D (27854591) wifi:filter: set rx policy=7
I (27854594) wifi:pm start, type: 1
D (27854598) wifi:Send sta connected event
D (27854602) wifi:connect status 1 -> 5
D (27854605) wifi:obss scan is disabled
D (27854608) wifi:start obss scan: obss scan is stopped
I (27854736) wifi:AP's beacon interval = 102400 us, DTIM period = 1
