It does help because now I understand more about how it works.
Unfortunately, I am still getting the same error even after cleanning and recompiling.
Here are the change I did :
-I got rid of the extern C wrapper in the spi.cpp
-Here is the spi.h now
- esp-idf bug #9.png (17.99 KiB) Viewed 14259 times
-Here is the main.cpp
- esp-idf bug#10.png (19.27 KiB) Viewed 14259 times
For the rest I didn't change anything
As for the linker error :
FAILED: app-template.elf
: && /home/isecurity/.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++ -mlongcalls -Wno-frame-address -nostdlib CMakeFiles/app-template.elf.dir/project_elf_src.c.obj -o app-template.elf esp-idf/esp_ringbuf/libesp_ringbuf.a esp-idf/driver/libdriver.a esp-idf/wpa_supplicant/libwpa_supplicant.a esp-idf/efuse/libefuse.a esp-idf/bootloader_support/libbootloader_support.a esp-idf/app_update/libapp_update.a esp-idf/spi_flash/libspi_flash.a esp-idf/nvs_flash/libnvs_flash.a esp-idf/esp_wifi/libesp_wifi.a esp-idf/esp_eth/libesp_eth.a esp-idf/lwip/liblwip.a esp-idf/tcpip_adapter/libtcpip_adapter.a esp-idf/esp_event/libesp_event.a esp-idf/pthread/libpthread.a esp-idf/espcoredump/libespcoredump.a esp-idf/esp32/libesp32.a esp-idf/xtensa/libxtensa.a esp-idf/esp_common/libesp_common.a esp-idf/esp_rom/libesp_rom.a esp-idf/soc/libsoc.a esp-idf/log/liblog.a esp-idf/heap/libheap.a esp-idf/freertos/libfreertos.a esp-idf/vfs/libvfs.a esp-idf/newlib/libnewlib.a esp-idf/cxx/libcxx.a esp-idf/app_trace/libapp_trace.a esp-idf/asio/libasio.a esp-idf/coap/libcoap.a esp-idf/console/libconsole.a esp-idf/nghttp/libnghttp.a esp-idf/esp-tls/libesp-tls.a esp-idf/esp_adc_cal/libesp_adc_cal.a esp-idf/esp_gdbstub/libesp_gdbstub.a esp-idf/tcp_transport/libtcp_transport.a esp-idf/esp_http_client/libesp_http_client.a esp-idf/esp_http_server/libesp_http_server.a esp-idf/esp_https_ota/libesp_https_ota.a esp-idf/protobuf-c/libprotobuf-c.a esp-idf/protocomm/libprotocomm.a esp-idf/mdns/libmdns.a esp-idf/esp_local_ctrl/libesp_local_ctrl.a esp-idf/esp_websocket_client/libesp_websocket_client.a esp-idf/expat/libexpat.a esp-idf/wear_levelling/libwear_levelling.a esp-idf/sdmmc/libsdmmc.a esp-idf/fatfs/libfatfs.a esp-idf/freemodbus/libfreemodbus.a esp-idf/jsmn/libjsmn.a esp-idf/json/libjson.a esp-idf/libsodium/liblibsodium.a esp-idf/mqtt/libmqtt.a esp-idf/openssl/libopenssl.a esp-idf/spiffs/libspiffs.a esp-idf/ulp/libulp.a esp-idf/unity/libunity.a esp-idf/wifi_provisioning/libwifi_provisioning.a esp-idf/main/libmain.a -Wl,--cref -Wl,--Map=/home/isecurity/esp/eclipse-workspace/ak8975/build/app-template.map -fno-rtti -fno-lto esp-idf/asio/libasio.a esp-idf/coap/libcoap.a esp-idf/esp_adc_cal/libesp_adc_cal.a esp-idf/esp_gdbstub/libesp_gdbstub.a esp-idf/esp_https_ota/libesp_https_ota.a esp-idf/esp_http_client/libesp_http_client.a esp-idf/esp_local_ctrl/libesp_local_ctrl.a esp-idf/esp_websocket_client/libesp_websocket_client.a esp-idf/expat/libexpat.a esp-idf/fatfs/libfatfs.a esp-idf/wear_levelling/libwear_levelling.a esp-idf/sdmmc/libsdmmc.a esp-idf/freemodbus/libfreemodbus.a esp-idf/jsmn/libjsmn.a esp-idf/libsodium/liblibsodium.a esp-idf/mqtt/libmqtt.a esp-idf/tcp_transport/libtcp_transport.a esp-idf/esp-tls/libesp-tls.a esp-idf/openssl/libopenssl.a esp-idf/spiffs/libspiffs.a esp-idf/ulp/libulp.a esp-idf/unity/libunity.a esp-idf/wifi_provisioning/libwifi_provisioning.a esp-idf/protocomm/libprotocomm.a esp-idf/esp_http_server/libesp_http_server.a esp-idf/nghttp/libnghttp.a esp-idf/protobuf-c/libprotobuf-c.a esp-idf/mdns/libmdns.a esp-idf/console/libconsole.a esp-idf/json/libjson.a esp-idf/esp_ringbuf/libesp_ringbuf.a esp-idf/driver/libdriver.a esp-idf/wpa_supplicant/libwpa_supplicant.a esp-idf/efuse/libefuse.a esp-idf/bootloader_support/libbootloader_support.a esp-idf/app_update/libapp_update.a esp-idf/spi_flash/libspi_flash.a esp-idf/nvs_flash/libnvs_flash.a esp-idf/esp_wifi/libesp_wifi.a esp-idf/esp_eth/libesp_eth.a esp-idf/lwip/liblwip.a esp-idf/tcpip_adapter/libtcpip_adapter.a esp-idf/esp_event/libesp_event.a esp-idf/pthread/libpthread.a esp-idf/espcoredump/libespcoredump.a esp-idf/esp32/libesp32.a esp-idf/xtensa/libxtensa.a esp-idf/esp_common/libesp_common.a esp-idf/esp_rom/libesp_rom.a esp-idf/soc/libsoc.a esp-idf/log/liblog.a esp-idf/heap/libheap.a esp-idf/freertos/libfreertos.a esp-idf/vfs/libvfs.a esp-idf/newlib/libnewlib.a esp-idf/cxx/libcxx.a esp-idf/app_trace/libapp_trace.a esp-idf/mbedtls/mbedtls/library/libmbedtls.a esp-idf/mbedtls/mbedtls/library/libmbedcrypto.a esp-idf/mbedtls/mbedtls/library/libmbedx509.a /home/isecurity/esp/esp-idf/components/esp_wifi/lib_esp32/libcoexist.a /home/isecurity/esp/esp-idf/components/esp_wifi/lib_esp32/libcore.a /home/isecurity/esp/esp-idf/components/esp_wifi/lib_esp32/libespnow.a /home/isecurity/esp/esp-idf/components/esp_wifi/lib_esp32/libmesh.a /home/isecurity/esp/esp-idf/components/esp_wifi/lib_esp32/libnet80211.a /home/isecurity/esp/esp-idf/components/esp_wifi/lib_esp32/libphy.a /home/isecurity/esp/esp-idf/components/esp_wifi/lib_esp32/libpp.a /home/isecurity/esp/esp-idf/components/esp_wifi/lib_esp32/librtc.a /home/isecurity/esp/esp-idf/components/esp_wifi/lib_esp32/libsmartconfig.a esp-idf/esp_ringbuf/libesp_ringbuf.a esp-idf/driver/libdriver.a esp-idf/wpa_supplicant/libwpa_supplicant.a esp-idf/efuse/libefuse.a esp-idf/bootloader_support/libbootloader_support.a esp-idf/app_update/libapp_update.a esp-idf/spi_flash/libspi_flash.a esp-idf/nvs_flash/libnvs_flash.a esp-idf/esp_wifi/libesp_wifi.a esp-idf/esp_eth/libesp_eth.a esp-idf/lwip/liblwip.a esp-idf/tcpip_adapter/libtcpip_adapter.a esp-idf/esp_event/libesp_event.a esp-idf/pthread/libpthread.a esp-idf/espcoredump/libespcoredump.a esp-idf/esp32/libesp32.a esp-idf/xtensa/libxtensa.a esp-idf/esp_common/libesp_common.a esp-idf/esp_rom/libesp_rom.a esp-idf/soc/libsoc.a esp-idf/log/liblog.a esp-idf/heap/libheap.a esp-idf/freertos/libfreertos.a esp-idf/vfs/libvfs.a esp-idf/newlib/libnewlib.a esp-idf/cxx/libcxx.a esp-idf/app_trace/libapp_trace.a esp-idf/mbedtls/mbedtls/library/libmbedtls.a esp-idf/mbedtls/mbedtls/library/libmbedcrypto.a esp-idf/mbedtls/mbedtls/library/libmbedx509.a /home/isecurity/esp/esp-idf/components/esp_wifi/lib_esp32/libcoexist.a /home/isecurity/esp/esp-idf/components/esp_wifi/lib_esp32/libcore.a /home/isecurity/esp/esp-idf/components/esp_wifi/lib_esp32/libespnow.a /home/isecurity/esp/esp-idf/components/esp_wifi/lib_esp32/libmesh.a /home/isecurity/esp/esp-idf/components/esp_wifi/lib_esp32/libnet80211.a /home/isecurity/esp/esp-idf/components/esp_wifi/lib_esp32/libphy.a /home/isecurity/esp/esp-idf/components/esp_wifi/lib_esp32/libpp.a /home/isecurity/esp/esp-idf/components/esp_wifi/lib_esp32/librtc.a /home/isecurity/esp/esp-idf/components/esp_wifi/lib_esp32/libsmartconfig.a -u esp_app_desc -L /home/isecurity/esp/esp-idf/components/esp_wifi/lib_esp32 -u pthread_include_pthread_impl -u pthread_include_pthread_cond_impl -u pthread_include_pthread_local_storage_impl -L /home/isecurity/esp/eclipse-workspace/ak8975/build/esp-idf/esp32 -T esp32_out.ld -u app_main -L /home/isecurity/esp/eclipse-workspace/ak8975/build/esp-idf/esp32/ld -T esp32.project.ld -L /home/isecurity/esp/esp-idf/components/esp32/ld -T esp32.peripherals.ld -u call_user_start_cpu0 -u ld_include_panic_highint_hdl /home/isecurity/esp/esp-idf/components/xtensa/esp32/libhal.a -Wl,--gc-sections -L /home/isecurity/esp/esp-idf/components/esp_rom/esp32/ld -T esp32.rom.ld -T esp32.rom.libgcc.ld -T esp32.rom.syscalls.ld -T esp32.rom.newlib-data.ld -T esp32.rom.newlib-funcs.ld -Wl,--undefined=uxTopUsedPriority -u vfs_include_syscalls_impl esp-idf/newlib/libnewlib.a -u newlib_include_locks_impl -u newlib_include_heap_impl -u newlib_include_syscalls_impl -u newlib_include_pthread_impl -u __cxa_guard_dummy -lstdc++ esp-idf/pthread/libpthread.a -u __cxx_fatal_exception -lgcov -lc -lm -lgcc && :
/home/isecurity/.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld: esp-idf/main/libmain.a(main.cpp.obj):(.literal.app_main+0x20): undefined reference to `Spi::spiBusAddDevice(spi_host_device_t, spi_device_interface_config_t const*, spi_device_t**)'
/home/isecurity/.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld: esp-idf/main/libmain.a(main.cpp.obj): in function `app_main':
/home/isecurity/esp/eclipse-workspace/ak8975/build/../main/main.cpp:49: undefined reference to `Spi::spiBusAddDevice(spi_host_device_t, spi_device_interface_config_t const*, spi_device_t**)'
Just in case, I'm adding the Problem windows because I'm also getting warning issue with the "driver/spi_master.h" librairie which is included in my spi.h file :
- esp-idf bug#11.png (72.41 KiB) Viewed 14259 times
Thank you so much for your help, it's been 3 weeks now since I started setuping this environment and I'm still not able to use it fully.
Dythe
