In your story, it looks like the root of your project is C:\Work\Actisense\http_server2
beneath this will be your components. These are the source files that should be compiled and linked together to build your application. It further seems that you have source files in a distinct directory called C:\Work\\LibDev\CommonLib ... which by location, appears not to be a component in your project.
It is common for me to see all components living under the <Project>/components directory structure.
When you compile the source in CommonLib, what is the final output? Perhaps libCommonLib.a or something similar?
ESP-IDF include additional paths
Re: ESP-IDF include additional paths
Can Anyone answer my query. I am waiting for reply.
Yes Location of my CommonLib is not under C:\msys32\home\naeem\esp\esp-idf\components.
Our current code base is different folder structure.
C:\Work\LibDev\CommonLib has component.mk.
It is not generating libCommonLib.a static library. I need to specify correct rules to generate static library using GNU make. I am looking at this issue. any help will be appreciated.
Thanks,
Naeem
Thanks,
Naeem
It looks like for all static libraries expected under esp-idf\components by find script in esp-idf\make\project.mk
COMPONENT_DIRS := $(PROJECT_PATH)/components $(EXTRA_COMPONENT_DIRS) $(IDF_PATH)/components $(PROJECT_PATH)/main
My component/library is in different folder. I guess I can add my path to above script line?
Thanks,
Naeem
Thanks,
Naeem
My issue is sorted
Adding my path to this line.
COMPONENT_DIRS := $(PROJECT_PATH)/components $(EXTRA_COMPONENT_DIRS) $(IDF_PATH)/components $(PROJECT_PATH)/main $(IDF_PATH)/LibDev
My IDF_PATH = c:\Work
Users browsing this forum: Gaston1980 and 104 guests
