OTA simple example without certificate check
kluverp
Postby kluverp » Thu Jan 24, 2019 2:31 pm
Hi All,
I'm running the OTA "simple example" which is based on the esp_http_client library.
Now, the documentation says, that if you do not want to verify the host, you can omit the "config.cert_pem" entry. However, when I leave this out like so:
esp_http_client_config_t config;
    config.url           = C_ota_url.txt;
   // config.cert_pem      = NULL;//(char *)server_cert_pem_start;
    config.event_handler = _http_event_handler;
    esp_err_t ret = esp_https_ota(&config);
    if (ret == ESP_OK) {
        esp_restart();
    } else {
        ESP_LOGE(TAG, "Firmware Upgrades Failed");
        ota_cancel();
    while (1) {
I get an mbedTLS error:
E (12684) esp-tls: mbedtls_x509_crt_parse returned -0x2180
E (12684) esp-tls: Failed to open new connection
E (12684) TRANS_SSL: Failed to open a new connection
E (12694) HTTP_CLIENT: Connection failed, sock < 0
E (12694) esp_https_ota: Failed to open HTTP connection: ESP_ERR_HTTP_CONNECT
E (12704) simple_ota_example: Firmware Upgrades Failed
When I fill it in, it works. But I want to skip the SSL verification.
fly135
Re: OTA simple example without certificate check
Postby fly135 » Fri Jan 25, 2019 5:47 pm
Seems that config.cert_pem has a random non-null value. Otherwise it would have failed and printed a message on this line in esp_https_ota....
if (!config->cert_pem) {
ESP_LOGE(TAG, "Server certificate not found in esp_http_client config");
return ESP_FAIL;
Now, if you set it to NULL, it will fail in that line. You need to modify esp_https_ota to remove the return ESP_FAIL. Then it will work.
You can also remove the return in this test if you want to use HTTP....
if (esp_http_client_get_transport_type(client) != HTTP_TRANSPORT_OVER_SSL) {
ESP_LOGE(TAG, "Transport is not over HTTPS");
return ESP_FAIL;
John A
Junior
Postby Junior » Sun May 03, 2020 2:45 pm
I got the same error trying to call a web api directly after connecting. I then tried calling the api a few seconds later, and got the status code 200.
daonguyen_iot47
Postby daonguyen_iot47 » Thu Jun 09, 2022 8:10 am
you just need to enable the "Allow HTTP for OTA" option in the sdk configure section and you're done :D :D :D
Users browsing this forum: Bing [Bot] and 175 guests
