xtensa compiler: case label does not reduce to an integer constant
danpf1
Postby danpf1 » Wed Apr 27, 2022 2:09 pm
When compiling the simple program below with a macro as a case label, I receive the error:
The error only happens with the xtensa-esp32s3-elf-gcc compiler. This does not happen with plain gcc.
#include <stdio.h>
// #include <stdlib.h>
#include <stdint.h>
#include <math.h>
#include <string.h>
#define HTST(s, i, x) (s[2])
int main() {
  switch(12) {
     case HTST("anything", 0, 0):
        printf("anything!");
        break;
     default:
        printf("DEFAIULT");
Compile command:
> xtensa-esp32s3-elf-gcc t.c
t.c: In function 'main':
t.c:12:6: error: case label does not reduce to an integer constant
GCC compile shows no warnings or errors.
This is on a Mac OSX 12.3.1
Xtensa compiler: xtensa-esp32s3-elf-gcc (crosstool-NG esp-2021r2) 8.4.0
Gcc compiler: Apple clang version 13.1.6 (clang-1316.0.21.2.3)
Thoughts?
Thanks!
ESP_igrr
Re: xtensa compiler: case label does not reduce to an integer constant
Postby ESP_igrr » Wed Apr 27, 2022 5:08 pm
Hi danpf1,
I'm afraid what you are running into isn't an Xtensa specific behavior. This error is also reported by GCC on other architectures. Here's the example with latest GCC (trunk) on x86_64: https://godbolt.org/z/EsK8qja5v
As you have found, clang does allow such a construct, indeed https://godbolt.org/z/jKPx41nd1.
GCC accepts this only when compiling C++ code: https://godbolt.org/z/Wce8hab7M
danpf1
Postby danpf1 » Wed Apr 27, 2022 6:19 pm
Thanks for the thorough and quick response! I'll look for some workaround for what I'm doing.
- Dan
Users browsing this forum: Baidu [Spider], Bing [Bot] and 64 guests
