- # Name, Type, SubType, Offset, Size, Flags
- # Note: if you have increased the bootloader size, make sure to update the offsets to avoid overlap
- nvs, data, nvs, , 0x006000,
- otadata, data, ota, , 0x002000,
- phy_init, data, phy, , 0x001000,
- ota_0, app, ota_0, , 0x140000,
- ota_1, app, ota_1, , 0x140000,
- storage, data, spiffs, , 0x160000,
* ESP32-S2-WROVER (4MB) with ESP-IDF V5.0
* ESP32 is erased completely using "idf.py erase_flash"
If ESP32 gets flashed using flash tool "idf.py flash", firmware runs fine.
If ESP32 gets flashed using USB DFU "idf.py dfu dfu-flash" SPIFFS partition seems to be missing.
E (488) SPIFFS: mount failed, -10025
My partition table.
dfu.bin seems to contain all partitions.
Does anybody have an idea what could be wrong?
