Hello All
I use ESP32-C3 idf 4.3
I want to know how can reset timer in this example :
https://github.com/espressif/esp-idf/bl ... ple_main.c
I wanna build a dimmer with zeroCross pulse
I read ZC Pulse in GPIO interrupt and then set out put LED GPIO
here I need a timer for dimming LED (timer for -> 0 to 10 millisecond)
so How can Reset Timer Value to zero? is there any Idea?
Do not be embarrassed any idea may be useful
thank you
Timer/Counter with ZeroCross for dimmer
Re: Timer/Counter with external pulse
this is my code :
Edited !!
Edited !!
- #include <stdio.h>
- #include "freertos/FreeRTOS.h"
- #include "freertos/task.h"
- #include "freertos/queue.h"
- #include "driver/timer.h"
- #include "esp_log.h"
- #include <string.h>
- #include <unistd.h>
- #include "esp_timer.h"
- #include "esp_sleep.h"
- #include "sdkconfig.h"
- #include "driver/gpio.h"
- static const char* TAG = "example";
- #define TIMER_RESOLUTION_HZ 10000000 // resolution
- #define TIMER_ALARM_PERIOD_S 1 // Alarm period sec
- #define ZeroCross GPIO_NUM_4 // zerocross
- #define ZeroCrossPIN_Select (1ULL << ZeroCross)
- #define Indicator_LED1 GPIO_NUM_8
- static xQueueHandle gpio_evt_queue;
- esp_timer_handle_t oneshot_timer;
- uint32_t counter1 = 0;
- // static void periodic_timer_callback(void* arg);
- static void oneshot_timer_callback(void* arg);
- bool LED_Toggle(gpio_num_t gpioNum)
- bool state = false;
- gpio_num_t pin = (gpio_num_t)(gpioNum & 0x1F);
- state = GPIO_REG_READ(GPIO_ENABLE_REG);
- if(GPIO_REG_READ(GPIO_ENABLE_REG) & BIT(pin))
- //pin is output - read the GPIO_OUT_REG register
- state ^= (GPIO_REG_READ(GPIO_OUT_REG) >> pin) & 1U;
- gpio_set_level(gpioNum, state);
- else
- //pin is input - read the GPIO_IN_REG register
- state = (GPIO_REG_READ(GPIO_IN_REG) >> pin) & 1U;
- return state;
- static void IRAM_ATTR GPIO_ISR_Handler(void* arg)
- uint32_t gpio_num = (uint32_t) arg;
- xQueueSendFromISR(gpio_evt_queue, &gpio_num, NULL);
- static void Interrupt_Task_Function(void* arg)
- uint32_t ioNum;
- printf("GPIO Interrupt Task Start... \r\n");
- while(1)
- if(xQueueReceive(gpio_evt_queue, &ioNum, portMAX_DELAY))
- if(ioNum == ZeroCross)
- printf("GPIO ZeroCross detected ... \r\n");
- // reset timer value ????????????????????????
- counter1 = counter1 + 100;
- void app_main(void)
- const esp_timer_create_args_t oneshot_timer_args = {
- .callback = &oneshot_timer_callback,
- /* argument specified here will be passed to timer callback function */
- // .arg = (void*) periodic_timer,
- .name = "one-shot"
- ESP_ERROR_CHECK(esp_timer_create(&oneshot_timer_args, &oneshot_timer));
- /* Start the timers */
- ESP_ERROR_CHECK(esp_timer_start_once(oneshot_timer, 1000000));
- ESP_LOGI(TAG, "Started timers, time since boot: %lld us", esp_timer_get_time());
- ESP_LOGI(TAG, "Entering light sleep for 0.5s, time since boot: %lld us",
- esp_timer_get_time());
- gpio_pad_select_gpio(Indicator_LED1);
- gpio_set_direction(Indicator_LED1, GPIO_MODE_OUTPUT);
- gpio_set_level(Indicator_LED1, 0);
- gpio_evt_queue = xQueueCreate(10, sizeof(uint32_t));
- if(xTaskCreate(Interrupt_Task_Function, "Interrupt_Task_Function", 2048, NULL, 3, NULL) == pdPASS)
- printf("Interrupt_Task_Function Created Success! \r\n");
- // zero cross
- gpio_set_direction(ZeroCross, GPIO_MODE_INPUT);
- gpio_set_intr_type(ZeroCross, GPIO_INTR_POSEDGE);
- gpio_set_pull_mode(ZeroCross, GPIO_PULLDOWN_ONLY);
- gpio_install_isr_service(0);
- gpio_isr_handler_add(ZeroCross, GPIO_ISR_Handler, (void*) ZeroCross);
- ESP_LOGI(TAG, "while run");
- while(1)
- printf("timer value : %d \r\n", counter1);
- vTaskDelay(pdMS_TO_TICKS(500));
- // LED_Toggle(Indicator_LED1);
- /* Clean up and finish the example */
- ESP_ERROR_CHECK(esp_timer_stop(oneshot_timer));
- // ESP_ERROR_CHECK(esp_timer_delete(periodic_timer));
- ESP_ERROR_CHECK(esp_timer_delete(oneshot_timer));
- ESP_LOGI(TAG, "Stopped and deleted timers");
- // int64_t time_since_boot = esp_timer_get_time();
- // ESP_LOGI(TAG, "Periodic timer called, time since boot: %lld us", time_since_boot);
- int64_t time_since_boot = esp_timer_get_time();
- ESP_LOGI(TAG, "One-shot timer called, time since boot: %lld us", time_since_boot);
Re: Timer/Counter with ZeroCross for dimmer
You don't need create your own timers to dim an LED. The ESP chips have dedicated hardware to dim LEDs. See the LED Control driver for more details.
thank you I will check it but I want to use Triac for dimmESP_Dazz wrote: ↑Wed Feb 23, 2022 8:55 amYou don't need create your own timers to dim an LED. The ESP chips have dedicated hardware to dim LEDs. See the LED Control driver for more details.
and triac need a sync pulse signal with zerocross
so this is my idea that when any zerocross pulse come and gprio interrupt occur reset my timer and set it to zero
then for example it count up for 5 millisecond and timer interrupt occur and turn on led or lamp or ...
Users browsing this forum: egionet, Google [Bot] and 82 guests
