- /* ESPNOW Example
- This example code is in the Public Domain (or CC0 licensed, at your option.)
- Unless required by applicable law or agreed to in writing, this
- software is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR
- CONDITIONS OF ANY KIND, either express or implied.
- This example shows how to use ESPNOW.
- Prepare two device, one for sending ESPNOW data and another for receiving
- ESPNOW data.
- #include <stdlib.h>
- #include <time.h>
- #include <string.h>
- #include <assert.h>
- #include "freertos/FreeRTOS.h"
- #include "freertos/semphr.h"
- #include "freertos/timers.h"
- #include "nvs_flash.h"
- #include "esp_event.h"
- #include "esp_netif.h"
- #include "esp_wifi.h"
- #include "esp_log.h"
- #include "esp_system.h"
- #include "esp_now.h"
- #include "esp_crc.h"
- #include "espnow_example.h"
- #define ESPNOW_MAXDELAY 512
- typedef enum
- EXAMPLE_ESPNOW_SEND_CB,
- EXAMPLE_ESPNOW_RECV_CB,
- } example_espnow_event_id_t;
- typedef struct
- uint8_t mac_addr[ESP_NOW_ETH_ALEN];
- esp_now_send_status_t status;
- } example_espnow_event_send_cb_t;
- typedef struct
- uint8_t *data;
- int data_len;
- } example_espnow_event_recv_cb_t;
- typedef union
- example_espnow_event_send_cb_t send_cb;
- example_espnow_event_recv_cb_t recv_cb;
- } example_espnow_event_info_t;
- /* When ESPNOW sending or receiving callback function is called, post event to ESPNOW task. */
- typedef struct
- example_espnow_event_id_t id;
- example_espnow_event_info_t info;
- } example_espnow_event_t;
- /* User defined field of ESPNOW data in this example. */
- typedef struct
- uint8_t type; //Broadcast or unicast ESPNOW data.
- uint8_t state; //Indicate that if has received broadcast ESPNOW data or not.
- uint16_t seq_num; //Sequence number of ESPNOW data.
- uint16_t crc; //CRC16 value of ESPNOW data.
- uint32_t magic; //Magic number which is used to determine which device to send unicast ESPNOW data.
- uint32_t payload[0]; //Real payload of ESPNOW data.
- } __attribute__((packed)) example_espnow_data_t;
- /* Parameters of sending ESPNOW data. */
- typedef struct
- bool unicast; //Send unicast ESPNOW data.
- bool broadcast; //Send broadcast ESPNOW data.
- uint16_t count; //Total count of unicast ESPNOW data to be sent.
- uint16_t delay; //Delay between sending two ESPNOW data, unit: ms.
- int len; //Length of ESPNOW data to be sent, unit: byte.
- uint8_t *buffer; //Buffer pointing to ESPNOW data.
- uint8_t dest_mac[ESP_NOW_ETH_ALEN]; //MAC address of destination device.
- } example_espnow_send_param_t;
- static const char *TAG = "espnow_example";
- static xQueueHandle s_example_espnow_queue;
- static uint8_t s_example_broadcast_mac[ESP_NOW_ETH_ALEN] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
- static uint16_t s_example_espnow_seq[EXAMPLE_ESPNOW_DATA_MAX] = {0, 0};
- static void example_espnow_deinit(example_espnow_send_param_t *send_param);
- /* WiFi should start before using ESPNOW */
- static void example_wifi_init(void)
- ESP_ERROR_CHECK(esp_netif_init());
- ESP_ERROR_CHECK(esp_event_loop_create_default());
- wifi_init_config_t cfg = WIFI_INIT_CONFIG_DEFAULT();
- ESP_ERROR_CHECK(esp_wifi_init(&cfg));
- ESP_ERROR_CHECK(esp_wifi_set_storage(WIFI_STORAGE_RAM));
- ESP_ERROR_CHECK(esp_wifi_set_mode(ESPNOW_WIFI_MODE));
- ESP_ERROR_CHECK(esp_wifi_start());
- #if CONFIG_ESPNOW_ENABLE_LONG_RANGE
- ESP_ERROR_CHECK(esp_wifi_set_protocol(ESPNOW_WIFI_IF, WIFI_PROTOCOL_11B | WIFI_PROTOCOL_11G | WIFI_PROTOCOL_11N | WIFI_PROTOCOL_LR));
- #endif
- /* ESPNOW sending or receiving callback function is called in WiFi task.
- * Users should not do lengthy operations from this task. Instead, post
- * necessary data to a queue and handle it from a lower priority task. */
- static void example_espnow_send_cb(const uint8_t *mac_addr, esp_now_send_status_t status)
- example_espnow_event_t evt;
- example_espnow_event_send_cb_t *send_cb = &evt.info.send_cb;
- if (mac_addr == NULL)
- ESP_LOGE(TAG, "Send cb arg error");
- return;
- evt.id = EXAMPLE_ESPNOW_SEND_CB;
- memcpy(send_cb->mac_addr, mac_addr, ESP_NOW_ETH_ALEN);
- send_cb->status = status;
- if (xQueueSend(s_example_espnow_queue, &evt, ESPNOW_MAXDELAY) != pdTRUE)
- ESP_LOGW(TAG, "Send send queue fail");
- int example_espnow_data_parse(uint8_t *data, uint16_t data_len) //int example_espnow_data_parse(uint8_t *data, uint16_t data_len, uint8_t *state, uint16_t *seq, int *magic)
- example_espnow_data_t *buf = (example_espnow_data_t *)data;
- uint16_t crc, crc_cal = 0;
- if (data_len < sizeof(example_espnow_data_t))
- ESP_LOGE(TAG, "Receive ESPNOW data too short, len:%d", data_len);
- return -1;
- // *state = buf->state;
- // *seq = buf->seq_num;
- // *magic = buf->magic;
- crc = buf->crc;
- buf->crc = 0;
- crc_cal = esp_crc16_le(UINT16_MAX, (uint8_t const *)buf, data_len);
- ESP_LOGI(TAG, "This is seq_num:%d", buf->seq_num);
- ESP_LOGI(TAG, "This is data:%u", buf->payload[0]);
- ESP_LOGI(TAG, "This is data:%u", buf->payload[1]);
- ESP_LOGI(TAG, "This is data:%u", buf->payload[2]);
- ESP_LOGI(TAG, "This is data:%u", buf->payload[3]);
- ESP_LOGI(TAG, "This is data:%u", buf->payload[4]);
- ESP_LOGI(TAG, "This is magic:%d", buf->magic);
- if (crc_cal == crc)
- return buf->type;
- return -1;
- static void example_espnow_recv_cb(const uint8_t *mac_addr, const uint8_t *data, int len)
- example_espnow_event_recv_cb_t *recv_cb = &evt.info.recv_cb;
- if (mac_addr == NULL || data == NULL || len <= 0)
- ESP_LOGE(TAG, "Receive cb arg error");
- return;
- evt.id = EXAMPLE_ESPNOW_RECV_CB;
- memcpy(recv_cb->mac_addr, mac_addr, ESP_NOW_ETH_ALEN);
- recv_cb->data = malloc(len);
- if (recv_cb->data == NULL)
- ESP_LOGE(TAG, "Malloc receive data fail");
- return;
- //ESP_LOGE(TAG, "This is data:%u", *data);
- memcpy(recv_cb->data, data, len);
- recv_cb->data_len = len;
- // if (xQueueSend(s_example_espnow_queue, &evt, ESPNOW_MAXDELAY) != pdTRUE)
- // ESP_LOGW(TAG, "Send receive queue fail");
- // free(recv_cb->data);
- ESP_LOGI(TAG, "DATA HEREEE");
- ESP_LOGI(TAG, "Receiveth broadcast data from: " MACSTR ", len: %d", MAC2STR(recv_cb->mac_addr), recv_cb->data_len);
- int ret = example_espnow_data_parse(recv_cb->data, recv_cb->data_len);
- free(recv_cb->data);
- // int ret = example_espnow_data_parse(recv_cb->data, recv_cb->data_len);
- /* Parse received ESPNOW data. */
- /* Prepare ESPNOW data to be sent. */
- void example_espnow_data_prepare(example_espnow_send_param_t *send_param)
- example_espnow_data_t *buf = (example_espnow_data_t *)send_param->buffer;
- assert(send_param->len >= sizeof(example_espnow_data_t));
- buf->type = IS_BROADCAST_ADDR(send_param->dest_mac) ? EXAMPLE_ESPNOW_DATA_BROADCAST : EXAMPLE_ESPNOW_DATA_UNICAST;
- buf->state = send_param->state;
- buf->seq_num = s_example_espnow_seq[buf->type]++;
- buf->crc = 0;
- buf->magic = send_param->magic;
- buf->payload[0] = 3423; //data_Array[0]; // identifier that reader moved to new tree
- buf->payload[1] = 454; //data_Array[1]; //old tree id
- buf->payload[2] = 354; //data_Array[2]; //new tree id
- buf->payload[3] = 654; //data_Array[3]; //fruit1
- buf->crc = esp_crc16_le(UINT16_MAX, (uint8_t const *)buf, send_param->len);
- static void example_espnow_task(void *pvParameter)
- uint8_t recv_state = 0;
- uint16_t recv_seq = 0;
- int recv_magic = 0;
- bool is_broadcast = false;
- int ret;
- vTaskDelay(5000 / portTICK_RATE_MS);
- ESP_LOGI(TAG, "Start sending broadcast data");
- /* Start sending broadcast ESPNOW data. */
- example_espnow_send_param_t *send_param = (example_espnow_send_param_t *)pvParameter;
- if (esp_now_send(send_param->dest_mac, send_param->buffer, send_param->len) != ESP_OK)
- ESP_LOGE(TAG, "Send error");
- example_espnow_deinit(send_param);
- vTaskDelete(NULL);
- vTaskDelay(send_param->delay / portTICK_RATE_MS);
- esp_err_t send_data()
- example_espnow_send_param_t *send_param;
- /* Initialize sending parameters. */
- send_param = malloc(sizeof(example_espnow_send_param_t));
- memset(send_param, 0, sizeof(example_espnow_send_param_t));
- if (send_param == NULL)
- ESP_LOGE(TAG, "Malloc send parameter fail");
- vSemaphoreDelete(s_example_espnow_queue);
- esp_now_deinit();
- return ESP_FAIL;
- send_param->unicast = false;
- send_param->broadcast = true;
- send_param->state = 0;
- send_param->magic = esp_random();
- send_param->count = CONFIG_ESPNOW_SEND_COUNT;
- send_param->delay = CONFIG_ESPNOW_SEND_DELAY;
- send_param->len = 18; //CONFIG_ESPNOW_SEND_LEN;
- send_param->buffer = malloc(18);
- if (send_param->buffer == NULL)
- ESP_LOGE(TAG, "Malloc send buffer fail");
- free(send_param);
- esp_now_deinit();
- return ESP_FAIL;
- memcpy(send_param->dest_mac, s_example_broadcast_mac, ESP_NOW_ETH_ALEN);
- example_espnow_data_prepare(send_param);
- ESP_LOGI(TAG, "Came heree");
- xTaskCreate(example_espnow_task, "example_espnow_task", 2048, send_param, 4, NULL);
- return ESP_OK;
- free(send_param->buffer);
- free(send_param);
- esp_now_deinit();
- static void example_espnow_init(void)
- s_example_espnow_queue = xQueueCreate(ESPNOW_QUEUE_SIZE, sizeof(example_espnow_event_t));
- if (s_example_espnow_queue == NULL)
- ESP_LOGE(TAG, "Create mutex fail");
- return ESP_FAIL;
- /* Initialize ESPNOW and register sending and receiving callback function. */
- ESP_ERROR_CHECK(esp_now_init());
- ESP_ERROR_CHECK(esp_now_register_send_cb(example_espnow_send_cb));
- ESP_ERROR_CHECK(esp_now_register_recv_cb(example_espnow_recv_cb));
- /* Set primary master key. */
- ESP_ERROR_CHECK(esp_now_set_pmk((uint8_t *)CONFIG_ESPNOW_PMK));
- /* Add broadcast peer information to peer list. */
- esp_now_peer_info_t *peer = malloc(sizeof(esp_now_peer_info_t));
- if (peer == NULL)
- ESP_LOGE(TAG, "Malloc peer information fail");
- esp_now_deinit();
- return ESP_FAIL;
- memset(peer, 0, sizeof(esp_now_peer_info_t));
- peer->channel = CONFIG_ESPNOW_CHANNEL;
- peer->ifidx = ESPNOW_WIFI_IF;
- peer->encrypt = false;
- memcpy(peer->peer_addr, s_example_broadcast_mac, ESP_NOW_ETH_ALEN);
- ESP_ERROR_CHECK(esp_now_add_peer(peer));
- free(peer);
- void app_main()
- example_wifi_init();
- example_espnow_init();
- send_data();
buf->payload[4] =34;
buf->payload[5] = 564;
This is the error
I have seen from similar questions that this comes up because of not having the required stack depth. But increasing the value 2048 here***ERROR*** A stack overflow in task main has been detected.
Any suggestion would be really helpful. Thankss in advance
