Hello everybody!
I am trying the following setup: I have a mesh + wifi running in a group of ESP32 devices. It works properly. I want to debug and trace what is happening in the devices, so I setup up an esp-now configuration to send the logs to an outsider esp32 device that just prints them in a serial port (whatever it receives). When the mesh is running and the wifi is "offline" (no router), the esp-now msgs are sent normally from all the nodes + root. As soon as the wifi goes "online" (router in on), the root stops sending the esp-now messages (even though esp_now_send returns ESP_OK).
Is it possible to use Wifi + Now + Mesh simultaneously?
My project is basically a merge from [https://github.com/espressif/esp-idf/t ... fi/espnow] + [https://github.com/espressif/esp-idf/t ... unication], with modifications to tx/rx properly my data.
I am using the esp-idf v4.3.1
I've already checked many other pages with different possible solutions that didn't work for me, as below:
- Esp-now and Wifi in the same channel;
- Disable power saving (esp_wifi_set_ps(WIFI_PS_NONE));
- Enable both softAP + STA;
Thanks in advance for any help
ESP Now + ESP Wifi + ESP Mesh -> Is it possible?
Re: ESP Now + ESP Wifi + ESP Mesh -> Is it possible?
Magnetuz wrote: ↑Wed Dec 08, 2021 10:03 amHello everybody!
Hey hi is your softAP is getting connected to wifi(router) or any smartphones..?? If you getting connected means can you help me out please..
Hi kalmesh_S.
I am using the STA to connect to the router. What is your issue?
Hi
I'm trying to connect my smartphone and some other wifi devices to esp32 in AP mode which is there in example/wifi/getting_started/softAP because whenever i try to connect means it is not getting connected
can i get any help from your side
thanks in advance
thanks in advance
Sorry, but this issue is not related to this post. As a small help, your problem seems a wrong/incomplete initialization. You should check if you are properly enabling the softAP mode and initializing/configuring the softAP interface, including the wifi configuration and DHCP server. You could go for the IDF/MDF examples and compare to your code.
Users browsing this forum: Baldhead and 147 guests
