I would like to install the IDF with eclipse. I followed https://github.com/espressif/idf-eclips ... /README.md. So I got the compatible version 2021-06. But when I try to add the Repo https://dl.espressif.com/dl/idf-eclipse ... es/latest/ I get an error that the software is not found. If I enter https://dl.espressif.com/dl/idf-eclipse ... es/latest/ in my browser I get an access forbidden error. Also I installed Git but the "Team" menu is not showing up in the preferences.
What is going on? What is wrong?
Kind regards
Problem installing ESP IDF with eclipse
Re: Problem installing ESP IDF with eclipse
Thanks for reporting. Looks like some issue in accessing url. Will take a look at this.
However, you can use the zip file to download and update your eclipse.
Here is the link to download https://dl.espressif.com/dl/idf-eclipse ... v2.2.0.zip
Please follow the instructions for installation from here
https://github.com/espressif/idf-eclips ... gLocalFile
Hello, raspitin
Could you please try once again, it should work now
Worked now, thank you!
Users browsing this forum: No registered users and 74 guests
