esp_aes_gcm_finish(): assert triggered (BUG?)
mfranz
Postby mfranz » Wed Sep 01, 2021 1:04 pm
Hey,
using esp-idf plugin v1.1.1 with code v4.3 I get an assertion while trying to decrypt aes128gcm:
assertion "stream_bytes == 0 || stream_out != NULL" failed: file "$HOME/esp/esp-idf/components/mbedtls/port/aes/dma/esp_aes.c", line 308, function: esp_aes_process_dma
Here's a a stripped down code example with all input data zeroed out that causes this:
static void test(void)
        static const uint8_t key[16] = { 0 };
        static const uint8_t iv[12] = { 0 };
        static const uint8_t aad[16] = { 0 };
        static const uint8_t tag[12] = { 0 };
        static const uint8_t input[90] = { 0 };
        static uint8_t output[90] = { 0 };
        mbedtls_gcm_context ctx;
        mbedtls_gcm_init(&ctx);
        (void)mbedtls_gcm_setkey(&ctx, MBEDTLS_CIPHER_ID_AES, key, 128);
        mbedtls_gcm_auth_decrypt(&ctx, sizeof(input),
                        iv, sizeof(iv),
                        aad, sizeof(aad),
                        tag, sizeof(tag),
                        input, output);
        mbedtls_gcm_free(&ctx);
The problem seems to be the tag with length 12. Enlarging it to 16 doesn't cause the assertion. With size 12 in file ~/esp/esp-idf/components/mbedtls/port/aes/esp_aes_gcm.c line 488 parameter stream_block is set to zero:
esp_aes_crypt_ctr(&ctx->aes_ctx, tag_len, &nc_off, ctx->ori_j0, 0, ctx->ghash, tag);
... and so esp_aes_crypt_ctr() calls in line 1001 of ~/esp/esp-idf/components/mbedtls/port/aes/esp_aes.c ...
esp_aes_process_dma(ctx, input, output, 12 /*length*/, 0 /*stream_block*/);
... which leads to this assertion in function esp_aes_process_dma(), line 308 of file ~/esp/esp-idf/components/mbedtls/port/aes/dma/esp_aes.c:
assert(stream_bytes == 0 || stream_out != NULL);
where stream_bytes = 12 and stream_out = NULL.
I tried to fix it by providing an non-NULL stream in esp_aes_gcm_finish() just as it's done in esp_aes_gcm_update(), but I cannot say if that's actually a fix and doesn't just hide a bug elsewhere leading to wrong results:
diff --git a/components/mbedtls/port/aes/esp_aes_gcm.c b/components/mbedtls/port/aes/esp_aes_gcm.c
old mode 100644
new mode 100755
index b8cb59f22..c20ba9fe6
--- a/components/mbedtls/port/aes/esp_aes_gcm.c
+++ b/components/mbedtls/port/aes/esp_aes_gcm.c
@@ -474,6 +474,7 @@ int esp_aes_gcm_finish( esp_gcm_context *ctx,
     size_t nc_off = 0;
     uint8_t len_block[AES_BLOCK_BYTES] = {0};
+    uint8_t stream[AES_BLOCK_BYTES] = {0};
     if ( tag_len > 16 || tag_len < 4 ) {
         return ( MBEDTLS_ERR_GCM_BAD_INPUT );
@@ -485,7 +486,7 @@ int esp_aes_gcm_finish( esp_gcm_context *ctx,
     esp_gcm_ghash(ctx, len_block, AES_BLOCK_BYTES, ctx->ghash);
     /* Tag T = GCTR(J0, ) where T is truncated to tag_len */
-    esp_aes_crypt_ctr(&ctx->aes_ctx, tag_len, &nc_off, ctx->ori_j0, 0, ctx->ghash, tag);
+    esp_aes_crypt_ctr(&ctx->aes_ctx, tag_len, &nc_off, ctx->ori_j0, stream, ctx->ghash, tag);
     return 0;
Could someone knowledgeable please have a look at this and, ideally, fix it properly?
ESP-Marius
Re: esp_aes_gcm_finish(): assert triggered (BUG?)
Postby ESP-Marius » Thu Sep 02, 2021 2:37 am
Yeah this looks like a bug. I think the length here should always be 16 bytes, and for smaller tags it should be clipped afterwards.
I'll look into and fix this. In the meanwhile you should be able to bypass this by disabling MBEDTLS_HARDWARE_GCM if this is issue is a blocker for you.
mfranz
Postby mfranz » Mon Sep 06, 2021 7:29 am
Hey Marius,
turning off MBEDTLS_HARDWARE_GCM is good enough for me, because my encrypted messages are really short. Works for me now. Thanks a lot!
m.
Jeroen88
Postby Jeroen88 » Tue Jan 03, 2023 10:15 am
Hi all,
The problem is still present in the latest release of the core. I found a fix here: https://git.thc420.dev/blackbeard420/es ... 6f9e2c2bfc
Will it be solved and when?
Best reagrads, Jeroen
ESP_harshal
Postby ESP_harshal » Thu Jan 05, 2023 9:02 am
The issue has been fixed on the master branch. Please let us know which ESP-IDF version would you like to have the fix on as well.
Users browsing this forum: No registered users and 102 guests
