Hello
I have been trying to build a current version of openocd on Windows using the instructions here
https://docs.espressif.com/projects/esp ... ndows.html
I have tried it multiple times but I fail with
configure: error: libusb-1.x is required for the MPSSE mode of FTDI based devices
even though I downloaded and unzipped libusb-1.x as per the instructions and when I ls I see it is were I think it should be
$ echo $CPPFLAGS
-I/c/Users/bjpic/esp/libusb/include/libusb-1.0 -D__USE_MINGW_ANSI_STDIO=1 -Wno-error
bjpic@LAPTOP-70Q5CT1Q MSYS ~/esp
$ echo $LDFLAGS
-L/c/Users/bjpic/esp/libusb/MinGW32/.libs/dll
$ ls
buildsetup.bat config.bat examples install.bat libusb-1.0.22.7z openocd-esp32 sdkconfig.ci
CMakeLists.txt example_test.py export.bat **libusb** Makefile README.md sdkconfig.defaults
Because configure fails I cannot run make. If I run configure without the options (i.e. --disable-doxygen-pdf --enable-ftdi --enable-jlink --enable-ulink --build=i686-w64-mingw32 --host=i686-w64-mingw32) It give me errors because libusb is not found.
I have attached a fill trace of the problem.
I am trying to build the most recent version of openocd because when I try to run it as per https://docs.espressif.com/projects/esp ... ing-target
I get the following
C:\Users\bjpic\Desktop\esp-idf>openocd -f board/esp32c3-builtin.cfg
Open On-Chip Debugger v0.10.0-esp32-20210401 (2021-04-01-15:46)
Licensed under GNU GPL v2
For bug reports, read
Info : only one transport option; autoselect 'jtag'
Warn : Transport "jtag" was already selected
force hard breakpoints
Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Info : esp_usb_jtag: Device found. Base speed 40000KHz, div range 1 to 255
Info : clock speed 40000 kHz
Info : JTAG tap: esp32c3.cpu tap/device found: 0x00005c25 (mfg: 0x612 (Espressif Systems), part: 0x0005, ver: 0x0)
Info : datacount=2 progbufsize=16
Info : Examined RISC-V core; found 1 harts
Info : hart 0: XLEN=32, misa=0x40101104
Note the **Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED**
This occurs even though I have tried all the permutations of drivers for the USB port.
Thank you
Unable to build openocd on Windows: libusb not found
- openocdfails.txt
- (9.88 KiB) Downloaded 481 times
Re: Unable to build openocd on Windows: libusb not found
FWIW: the 'Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED' is probably a red herring; the fact that the tap gets properly detected indicates that OpenOCD has found its way to the adapter and is able to communicate with the core.
Thanks for the reply.
OpenOCD does find the device but then then it doesn't work regardless. It seems to spew out a register dump and other info but I figured it made more sense to bring it up to latest version and then see what happened.
Users browsing this forum: No registered users and 157 guests
