Hi. I'm having trouble updating the BLE Advertising Raw Data.
I have taken as an example the ibeacon example of esp-idf, however this example does not allow me to update the raw data in real time since no more events are produced once the process has started.
I would like to know if I can force some event (timer style) to be able to make it work an update of values in raw data. Or perhaps there is another better option, and the ibeacon example was not the best in this case.
Update 'adv_data_raw' in my BLE ADV application
Re: Update 'adv_data_raw' in my BLE ADV application
Why not update adv_raw_data in app_main or any other place you want?
Maybe you will need to add some flag in events, that will tell you when you can setup advertising first time, but i believe you can try without it.
because Im using the
esp_ble_gap_config_adv_data_raw()
Maybe if it should implement some flag.
What flag could it be? I need to update the raw data every certain time interval
Thats good. You can call it anywhere you want, not just from events handler. Just remember you have to re-start advertising each time.GustavoGB wrote: ↑Sat Jun 12, 2021 1:32 ambecause Im using thefunction, and its a blocking function.Code: Select all
By flag i mean some bool value which will be set to true in events handler that will tell you when ble stack is ready to set and start advertising. I believe it should be done only 1 time, before first advertising.
Users browsing this forum: Bing [Bot] and 95 guests
