I don't think it's a problem with the wiring because I'm able to flash the image over the same UART0 connection without problems.
I've tried all different baudrates, changing the TX/RX buffer sizes on the UART, and disabled UART0 debug console in menuconfig.
Is there some setting I've overlooked? Any suggestions for troubleshooting? Is it possible this is because I'm using UART0 pins, even though I'm remapping them?
This example code is in the Public Domain (or CC0 licensed, at your option.)
Unless required by applicable law or agreed to in writing, this
software is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR
CONDITIONS OF ANY KIND, either express or implied.
#include <stdio.h>
#include <string.h>
#include "nvs_flash.h"
#include "esp_bt.h"
#include "soc/uhci_periph.h"
#include "driver/uart.h"
#include "driver/periph_ctrl.h"
#include "esp_log.h"
static const char *tag = "CONTROLLER_UART_HCI";
static void uart_gpio_reset(void)
#if CONFIG_BT_HCI_UART_NO == 1
periph_module_enable(PERIPH_UART1_MODULE);
#elif CONFIG_BT_HCI_UART_NO == 2
periph_module_enable(PERIPH_UART2_MODULE);
#endif
periph_module_enable(PERIPH_UHCI0_MODULE);
#ifdef CONFIG_BT_HCI_UART_NO
ESP_LOGI(tag, "HCI UART%d Pin select: TX 5, RX 0, RTS 12, CTS 32", CONFIG_BT_HCI_UART_NO);
uart_set_pin(UART_NUM_0, 5, 0, 12, 32); // Remap UART0 to different pins
uart_set_pin(CONFIG_BT_HCI_UART_NO, 1, 3, 22, 19); // Remap HCI uart to uart0 pins
const int uart_buffer_size = (1024 * 4);
//QueueHandle_t uart_queue1;
QueueHandle_t uart_queue2;
// Install UART driver using an event queue here
//ESP_ERROR_CHECK(uart_driver_install(UART_NUM_0, 128, 128, 10, &uart_queue1, 0));
ESP_ERROR_CHECK(uart_driver_install(CONFIG_BT_HCI_UART_NO, uart_buffer_size, uart_buffer_size, 10, &uart_queue2, 0));
uart_set_baudrate(CONFIG_BT_HCI_UART_NO, 460800);
// 1 is TXD0
// 3 is RXD0
// 22 is RTS0
// 19 is CTS0
#endif
void app_main()
esp_err_t ret;
/* Initialize NVS — it is used to store PHY calibration dataa */
ret = nvs_flash_init();
if (ret == ESP_ERR_NVS_NO_FREE_PAGES || ret == ESP_ERR_NVS_NEW_VERSION_FOUND) {
ESP_ERROR_CHECK(nvs_flash_erase());
ESP_ERROR_CHECK( ret );
/* As the UART1/2 pin conflict with flash pin, so do matrix of the signal and pin */
uart_gpio_reset(); //
esp_bt_controller_config_t bt_cfg = BT_CONTROLLER_INIT_CONFIG_DEFAULT();
bt_cfg.auto_latency = true;
ret = esp_bt_controller_init(&bt_cfg);
if (ret != ESP_OK) {
ESP_LOGE(tag, "Bluetooth Controller initialize failed: %s", esp_err_to_name(ret));
return;
ret = esp_bt_controller_enable(ESP_BT_MODE_CLASSIC_BT);
return;
ret = esp_bt_sleep_disable();
ESP_LOGE(tag, "Bluetooth Sleep Disable Failed: %s", esp_err_to_name(ret));
return;
