Only validate image when anti-rollback is enabled?
RichPiano
Postby RichPiano » Tue May 25, 2021 12:51 pm
I'm using the example "advanced_https_ota" as a base for my app development. Recently I've gotten more and more confused by about following code passage which is triggered in main() after successful wifi connection is established:
#if defined(CONFIG_BOOTLOADER_APP_ROLLBACK_ENABLE) && defined(CONFIG_BOOTLOADER_APP_ANTI_ROLLBACK)
     * We are treating successful WiFi connection as a checkpoint to cancel rollback
     * process and mark newly updated firmware image as active. For production cases,
     * please tune the checkpoint behavior per end application requirement.
    const esp_partition_t *running = esp_ota_get_running_partition();
    esp_ota_img_states_t ota_state;
    if (esp_ota_get_state_partition(running, &ota_state) == ESP_OK) {
        if (ota_state == ESP_OTA_IMG_PENDING_VERIFY) {
            if (esp_ota_mark_app_valid_cancel_rollback() == ESP_OK) {
                ESP_LOGI(TAG, "App is valid, rollback cancelled successfully");
            } else {
                ESP_LOGE(TAG, "Failed to cancel rollback");
#endif
It seems that the app only validates when both directives, CONFIG_BOOTLOADER_APP_ROLLBACK_ENABLE and CONFIG_BOOTLOADER_APP_ANTI_ROLLBACK are set. However, the documentation clearly states the following:
If the self-test has completed successfully, then you must call the function esp_ota_mark_app_valid_cancel_rollback() because the application is awaiting confirmation of operability (ESP_OTA_IMG_PENDING_VERIFY state).
Thus my question: Shouldn't I always confirm the image whenever CONFIG_BOOTLOADER_APP_ROLLBACK_ENABLE is set without the need for CONFIG_BOOTLOADER_APP_ANTI_ROLLBACK also to also be enabled? Is this a bug in the demo app?
Re: Only validate image when anti-rollback is enabled?
Postby ESP_Sprite » Wed May 26, 2021 1:04 am
Agree that that line smells funny. I'll see if I can ask the person who wrote that line.
ESP_Shubham
Postby ESP_Shubham » Mon May 31, 2021 9:01 am
Hi, thanks for reporting this issue.
I agree that image should also be validated when ROLLBACK is enabled. We were focusing on Anti-Rollback test while adding the change, due to which this condition was added.
I have added the fix in internal merge queue and is under review. It will be pushed to GitHub once all internal checks are passed.
Thanks,
Shubham
RichPiano
Postby RichPiano » Sat Jun 05, 2021 6:15 pm
Thank you! In this case I can wholeheartedly remove this line from my own app ;)
Users browsing this forum: No registered users and 106 guests
