Hello all,
I tried to merge Coap_Clienthttps://github.com/espressif/esp-idf/tr ... oap_client example with one of the "cxx" example i.e sensor_mcp9808https://github.com/espressif/esp-idf/tr ... or_mcp9808 However I am facing the following error
/home/harshad/esp/esp-idf/examples/cxx/experimental/sensor_mcp9808/main/sensor_mcp9808.cpp: In function 'void coap_example_client(void*)':
/home/harshad/esp/esp-idf/examples/cxx/experimental/sensor_mcp9808/build/config/sdkconfig.h:93:39: error: invalid conversion from 'int' to 'coap_log_t' [-fpermissive]
#define CONFIG_COAP_LOG_DEFAULT_LEVEL 4
I have put protocols_components into cxx_experimental_components and all library paths are included properly.
Please help on the issue,
Regards,
Problem in merging coap_client example with cxx example
Users browsing this forum: Gaston1980 and 116 guests
