1.8V on GPIO High?
w3llschmidt
1.8V on GPIO High?
Postby w3llschmidt » Tue Mar 30, 2021 8:42 pm
My ESP32 have a strange behavior.
With this code i read 3.3V on GPIO19 but 1.8V on GPIO18 :o
I have no idea what did this :cry:
PWM.H
#ifndef MCPWM_H // Header wrapper
#define MCPWM_H // Header wrapper
	#define GPIO_PWM0A_OUT  5
	#define GPIO_INA1_OUT   18
	#define GPIO_INA2_OUT   19
	#define GPIO_FAULT0_IN  17
	#define GPIO_PWM0B_OUT  4		//PWM0B - PWM B-Signal
	#define GPIO_INB1_OUT   15		//INB1 - Direction
	#define GPIO_INB2_OUT   2		//INB2 - Direction
	#define GPIO_FAULT1_IN  16		//LO2 - Low on Motor Error
	#include "driver/mcpwm.h"
	#include "soc/mcpwm_reg.h"
	#include "soc/mcpwm_struct.h"
	//PWM initialisieren
	void pwm_init();
	//Drive the motor
	void brushed_motor_forward(mcpwm_unit_t mcpwm_num, mcpwm_timer_t timer_num , float duty_cycle);
	void brushed_motor_backward(mcpwm_unit_t mcpwm_num, mcpwm_timer_t timer_num , float duty_cycle);
	void brushed_motor_coast(mcpwm_unit_t mcpwm_num, mcpwm_timer_t timer_num);
	void brushed_motor_hard_stop(mcpwm_unit_t mcpwm_num, mcpwm_timer_t timer_num);
#endif // MCPWM_H // Header wrapper
PWM.C
https://docs.espressif.com/projects/esp-idf/en/latest/api-reference/peripherals/mcpwm.html
static const char* TAG = "pwm.c";
#include <freertos/FreeRTOS.h>
#include <freertos/task.h>
#include <driver/mcpwm.h>
#include <soc/mcpwm_reg.h>
#include <soc/mcpwm_struct.h>
#include <driver/gpio.h>
#include <esp_log.h>
#include <pwm.h>
#define GPIO_OUTPUT_PIN_SEL  ((1ULL<<GPIO_INA1_OUT) | (1ULL<<GPIO_INA2_OUT) | (1ULL<<GPIO_INB1_OUT) | (1ULL<<GPIO_INB2_OUT))
void gpio_initialize() {
    https://docs.espressif.com/projects/esp-idf/en/latest/api-reference/peripherals/mcpwm.html#_CPPv418mcpwm_io_signals_t
    mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM0A, GPIO_PWM0A_OUT);
    mcpwm_gpio_init(MCPWM_UNIT_1, MCPWM0B, GPIO_PWM0B_OUT);
    mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM_FAULT_0, GPIO_FAULT0_IN);
    mcpwm_gpio_init(MCPWM_UNIT_1, MCPWM_FAULT_1, GPIO_FAULT1_IN);
    gpio_config_t io_conf;
        //disable interrupt
        io_conf.intr_type = GPIO_PIN_INTR_DISABLE;
        //set as output mode
        io_conf.mode = GPIO_MODE_INPUT_OUTPUT;
        //bit mask of the pins that you want to set,e.g.GPIO18/19
        io_conf.pin_bit_mask = GPIO_OUTPUT_PIN_SEL  ;
        //pull-down mode
        io_conf.pull_down_en = 0;
        //pull-up mode
        io_conf.pull_up_en = 0;
    //configure GPIO with the given settings
    gpio_config(&io_conf);
    gpio_set_level(GPIO_INA1_OUT, 1);
    gpio_set_level(GPIO_INA2_OUT, 1);
Re: 1.8V on GPIO High?
Postby ESP_Sprite » Wed Mar 31, 2021 3:43 am
How do you define GPIO_OUTPUT_PIN_SEL ?
w3llschmidt
Postby w3llschmidt » Thu Apr 01, 2021 4:34 pm
Sorry, i corrected my starting post.
This is how i configure them:
I got a correct reply:
I (550) cpu_start: App cpu up.
I (568) heap_init: Initializing. RAM available for dynamic allocation:
I (575) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (581) heap_init: At 3FFB9EF0 len 00026110 (152 KiB): DRAM
I (588) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (594) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (600) heap_init: At 40096DC0 len 00009240 (36 KiB): IRAM
I (607) cpu_start: Pro cpu start user code
I (624) spi_flash: detected chip: generic
I (625) spi_flash: flash io: dio
I (625) cpu_start: Starting scheduler on PRO CPU.
chip_info.revision: 1
chip_info.cores: 2
4MB external flash
I (649) gpio: GPIO[2]| InputEn: 1| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (649) gpio: GPIO[15]| InputEn: 1| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (659) gpio: GPIO[18]| InputEn: 1| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (669) gpio: GPIO[19]| InputEn: 1| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (679) pwm.c: ready
I (729) wifi:wifi driver task: 3ffc2a24, prio:23, stack:6656, core=0
I (729) system_api: Base MAC address is not set
I (729) system_api: read default base MAC address from EFUSE
w3llschmidt
Postby w3llschmidt » Thu Apr 01, 2021 7:20 pm
Any ideas?
With this code i can read 3.3V on both pin's.
//main.c
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#define GPIO_OUTPUT_PIN_SEL	((1ULL<<GPIO_INA1_OUT) | (1ULL<<GPIO_INA2_OUT));
void app_main() {
		//disable interrupt
		io_conf.mode = GPIO_MODE_OUTPUT;
		//pull-down mode
		//pull-up mode
	mcpwm_config_t pwm_config;
		pwm_config.frequency = 22000;
		pwm_config.cmpr_a = 50;
		pwm_config.cmpr_b = 50;
		pwm_config.counter_mode = MCPWM_UP_COUNTER;
		pwm_config.duty_mode = MCPWM_DUTY_MODE_0;
	mcpwm_init(MCPWM_UNIT_0, MCPWM_TIMER_0, &pwm_config);
Users browsing this forum: Bing [Bot] and 86 guests
