Hi Everyone, Can anyone tell me what could be the cause that makes one board (always) successful to update the firmware through OTA
while the other board but also uses WROOM32 chip (always) fail with the same code !!
[SOLVED] OTA Different behavior on different boards !!
Re: OTA Different behavior on different boards !!
For those who may face the same issue. It is a battery issue, My battery was not charged good and it seems during the OTA the Wifi requires more peak current hence the battery lake to supply the required current, and hence the process fails.
Charging the Battery solved the Problem.
Thank you for sharing!
Users browsing this forum: No registered users and 131 guests
