Building ESP32 using CMAKE
mfawzy79
Postby mfawzy79 » Sat Mar 06, 2021 8:12 pm
what is the needed command line to compile the ESP23 project using the CMAKE not the idf.py
Thanks,
Re: Building ESP32 using CMAKE
Postby ESP_Sprite » Sun Mar 07, 2021 6:04 am
Just use idf.py; it uses cmake under the hood so you get all the cmake advantages.
mfawzy79
Postby mfawzy79 » Sun Mar 07, 2021 6:45 pm
actually, invoking idf.py from my tool is returning
'idf.py' is not recognized as an internal or external command,
operable program or batch file.
jimas13
Postby jimas13 » Sun Mar 07, 2021 10:59 pm
Hello, you should use the terminal window that gets setup upon installation of the framework.
Once you open the esp-idf-terminal all of the paths needed in order to run the IDF.py and such commands are added to the session and you can utilise all of the python scripts, at your disposal
Postby ESP_Sprite » Mon Mar 08, 2021 1:54 am
It sounds like you haven't installed esp-idf correctly (or haven't set it up correctly, indeed). If you can't run idf.py from the command line, multiple other things will be broken and using cmake manually is not going to save you. Suggest you figure out what's wrong with your install first.
Users browsing this forum: espmich, greycon, sazanof and 93 guests
