Hi All,
Does anyone know an easy way to figure out the IP addresses of all connected stations on the esp32? When a station connects or disconnects I only get the mac address. I know I can then get the IP from the mac address with a another call but is there another API call to get a list of connected station IP's?
Imtiaz
connected wifi stations
Re: connected wifi stations
Well hmmm .... that was harder than it should have been. From my study, I believed that the answer was the tcpip_adapter component but after a search I could'nt find any docs in the web site on that component. Has it been accidently missed from the inclusion in the web based docs?
The answer to your question though can be technically found here ...
https://github.com/espressif/esp-idf/bl ... ter.h#L423
The API you are likely going to want to use is called:
tcpip_adapter_get_sta_list()
Hi Kolban,
Thanks a bunch. I'll give it a go now .
Imtiaz
Imtiaz
Hi Kolban ,
I tried it it doesnt work .
Station IP comes out at 0 even if I have two stations connected.
I (149840) wifi: n:1 0, o:1 0, ap:1 1, sta:255 255, prof:1
I (149840) wifi: station: 90:68:c3:5b:f7:66 join, AID=2, n, 20
D (149841) event: SYSTEM_EVENT_AP_STACONNECTED, mac:90:68:c3:5b:f7:66, aid:2
OTA esp32.core Image Running
Mac : 194 , STA IP : 0
Num: 1 , Mac : 194
Mac : 0 , STA IP : 0
Num: 1 , Mac : 251
Num: 1 , Mac : 132
Num: 1 , Mac : 251
Num: 1 , Mac : 194
Num: 1 , Mac : 251
Num: 1 , Mac : 132
Num: 1 , Mac : 251
void printStationLists(void)
wifi_sta_list_t wifi_sta_list;
tcpip_adapter_sta_list_t tcp_sta_list;
if(tcpip_adapter_get_sta_list(&wifi_sta_list, &tcp_sta_list) == ESP_OK)
for(uint8_t i = 0; i<4 ; i++)
TRACE_D("Mac : %d , STA IP : %d\n",tcp_sta_list.sta[i].mac[0] ,tcp_sta_list.sta[i].ip.addr);
TRACE_D("Num: %d , Mac : %d\n",wifi_sta_list.num,wifi_sta_list.sta[i].mac[0]);
else
TRACE_E("Cant get sta list\n");
Num: 1 , Mac : 194
Num: 1 , Mac : 251
Num: 1 , Mac : 132
Num: 1 , Mac : 251
Num: 1 , Mac : 194
Num: 1 , Mac : 251
Num: 1 , Mac : 132
Num: 1 , Mac : 251
This works
@Inputs:
@Outputs:
@Comments:
ip4_addr_t addr;
wifi_sta_list_t staList;
esp_wifi_ap_get_sta_list(&staList);
for(uint8_t i = 0 ; i<staList.num ; i++)
if(dhcp_search_ip_on_mac(staList.sta[i].mac , &addr))
TRACE_D("IP = %d\n",addr.addr);
else
HI,
I have got the following code work. You can try this.
esp_wifi_ap_get_sta_list(&wifi_sta_list);
tcpip_adapter_get_sta_list(&wifi_sta_list, &tcpip_adapter_sta_list);
for (i=0; i<wifi_sta_list.num; i++){
printf("StaInfo:"MACSTR","IPSTR"",MAC2STR(wifi_sta_list.sta[i].mac),IP2STR(&tcpip_adapter_sta_list.sta[i].ip));
Users browsing this forum: Baidu [Spider] and 66 guests
