Appending version number to project bin file
alsaleem00
Postby alsaleem00 » Sun Jan 31, 2021 10:46 am
I managed to set app version number to project using PROJECT_VER in "CMakeLists.txt".
If I compile the project, it will produce {projectname}.bin.
I can read the version using code. However, all versions have same bin name.
Is there a config variable i can use to make build produces distinctive bin name based on PROJECT_VER and/or other variable ?
Something like {projectname}_{othervar}_{PROJECT_VER}.bin
Thanks.
chegewara
Re: Appending version number to project bin file
Postby chegewara » Mon Feb 01, 2021 7:39 am
How about this:
include($ENV{IDF_PATH}/tools/cmake/project.cmake)
set(PROJECT_VER "1.0.0")
project(projectname_${PROJECT_VER})
Only thing is that PROJECT_VER is stripped after first dot which will result:
-- App "projectname_1.0.0" version: 1.0.0
build/projectname_1.bin
Maybe @Angus can help with that.
alsaleem00
Postby alsaleem00 » Mon Feb 01, 2021 11:49 am
Hi @chegewara,
this is smart approach.
Indeed, it will produce {projectname}_1.bin for (1.0.1) PROJECT_VER.
I tried to concat the two strings out side like
set(PROJECT_VER "3.0.1")
set(PROJECT_PREF "myproject")
set(PROJECT_BIN "${PROJECT_PREF}_${PROJECT_VER}")
project(${PROJECT_BIN})
but same result. It looks that dot is prohibited?
can you help @Angus ?
thanks.
alsaleem00
Postby alsaleem00 » Mon Feb 01, 2021 12:25 pm
It looks that this is a problem with cmake.
If i replace dots with underscore 1_0_1, it works.
.map & .elf files are produced correctly (with dots)
Any further suggestion?
Thanks.
alsaleem00
Postby alsaleem00 » Mon Feb 01, 2021 5:22 pm
I came up with a compromise solution:
set(PROJECT_VER "4.0.1")
set(PROJECT_VERU ${PROJECT_VER})
string (REPLACE "\." "_" PROJECT_VERU ${PROJECT_VERU})
set(PROJECT_BIN "${PROJECT_PREF}_${PROJECT_VERU}")
project("${PROJECT_BIN}")
This way i keep the version number inside with "dot" and produce bin file that shows version with underscore.
Thanks.
Users browsing this forum: No registered users and 119 guests
