The full repository is available at:
https://github.com/fc92/ESP32_MP3_Decod ... f-v4.3-dev
(git submodule update --init --recursive is also required to get the full code)
Compilation works but I still have some linker issue :
idf.py build
Executing action: all (aliases: build)
Running ninja in directory /home/f/esp/ESP32_MP3_Decoder/build
Executing "ninja all"...
[1/5] Performing build step for 'bootloader'
ninja: no work to do.
[2/3] Linking CXX executable esp32_mp3_decoder.elf
FAILED: esp32_mp3_decoder.elf
: && /home/f/.espressif/tools/xtensa-esp32-elf/esp-2020r2-8.2.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++ -mlongcalls -Wno-frame-address CMakeFiles/esp32_mp3_decoder.elf.dir/project_elf_src.c.obj -o esp32_mp3_decoder.elf esp-idf/xtensa/libxtensa.a esp-idf/mbedtls/libmbedtls.a esp-idf/efuse/libefuse.a esp-idf/bootloader_support/libbootloader_support.a esp-idf/app_update/libapp_update.a esp-idf/esp_ipc/libesp_ipc.a esp-idf/spi_flash/libspi_flash.a esp-idf/esp_system/libesp_system.a esp-idf/soc/libsoc.a esp-idf/vfs/libvfs.a esp-idf/esp_eth/libesp_eth.a esp-idf/tcpip_adapter/libtcpip_adapter.a esp-idf/esp_netif/libesp_netif.a esp-idf/esp_event/libesp_event.a esp-idf/wpa_supplicant/libwpa_supplicant.a esp-idf/nvs_flash/libnvs_flash.a esp-idf/esp_wifi/libesp_wifi.a esp-idf/lwip/liblwip.a esp-idf/log/liblog.a esp-idf/heap/libheap.a esp-idf/esp_ringbuf/libesp_ringbuf.a esp-idf/driver/libdriver.a esp-idf/pthread/libpthread.a esp-idf/espcoredump/libespcoredump.a esp-idf/perfmon/libperfmon.a esp-idf/esp32/libesp32.a esp-idf/esp_common/libesp_common.a esp-idf/esp_timer/libesp_timer.a esp-idf/freertos/libfreertos.a esp-idf/newlib/libnewlib.a esp-idf/cxx/libcxx.a esp-idf/app_trace/libapp_trace.a esp-idf/asio/libasio.a esp-idf/bt/libbt.a esp-idf/cbor/libcbor.a esp-idf/coap/libcoap.a esp-idf/console/libconsole.a esp-idf/nghttp/libnghttp.a esp-idf/esp-tls/libesp-tls.a esp-idf/esp_adc_cal/libesp_adc_cal.a esp-idf/esp_gdbstub/libesp_gdbstub.a esp-idf/esp_hid/libesp_hid.a esp-idf/tcp_transport/libtcp_transport.a esp-idf/esp_http_client/libesp_http_client.a esp-idf/esp_http_server/libesp_http_server.a esp-idf/esp_https_ota/libesp_https_ota.a esp-idf/protobuf-c/libprotobuf-c.a esp-idf/protocomm/libprotocomm.a esp-idf/mdns/libmdns.a esp-idf/esp_local_ctrl/libesp_local_ctrl.a esp-idf/sdmmc/libsdmmc.a esp-idf/esp_serial_slave_link/libesp_serial_slave_link.a esp-idf/esp_websocket_client/libesp_websocket_client.a esp-idf/expat/libexpat.a esp-idf/wear_levelling/libwear_levelling.a esp-idf/fatfs/libfatfs.a esp-idf/freemodbus/libfreemodbus.a esp-idf/jsmn/libjsmn.a esp-idf/json/libjson.a esp-idf/libsodium/liblibsodium.a esp-idf/mqtt/libmqtt.a esp-idf/openssl/libopenssl.a esp-idf/spiffs/libspiffs.a esp-idf/ulp/libulp.a esp-idf/unity/libunity.a esp-idf/wifi_provisioning/libwifi_provisioning.a esp-idf/main/libmain.a esp-idf/MerusAudio/libMerusAudio.a esp-idf/url_parser/liburl_parser.a esp-idf/http/libhttp.a esp-idf/fifo/libfifo.a esp-idf/common/libcommon.a esp-idf/controls/libcontrols.a esp-idf/libfaad/liblibfaad.a esp-idf/libm4a/liblibm4a.a esp-idf/audio_renderer/libaudio_renderer.a esp-idf/libfaad_decoder/liblibfaad_decoder.a esp-idf/fdk-aac/libfdk-aac.a esp-idf/fdk-aac_decoder/libfdk-aac_decoder.a esp-idf/mad/libmad.a esp-idf/mp3_decoder/libmp3_decoder.a esp-idf/audio_player/libaudio_player.a esp-idf/inih_port/libinih_port.a esp-idf/vector/libvector.a esp-idf/playlist/libplaylist.a esp-idf/user_driver/libuser_driver.a esp-idf/ui/libui.a esp-idf/web_radio/libweb_radio.a -Wl,--cref -Wl,--Map=/home/f/esp/ESP32_MP3_Decoder/build/esp32_mp3_decoder.map -fno-rtti -fno-lto esp-idf/main/libmain.a esp-idf/fifo/libfifo.a esp-idf/common/libcommon.a esp-idf/libm4a/liblibm4a.a esp-idf/audio_renderer/libaudio_renderer.a esp-idf/libfaad_decoder/liblibfaad_decoder.a esp-idf/fdk-aac_decoder/libfdk-aac_decoder.a esp-idf/mp3_decoder/libmp3_decoder.a esp-idf/audio_player/libaudio_player.a esp-idf/playlist/libplaylist.a esp-idf/web_radio/libweb_radio.a esp-idf/asio/libasio.a esp-idf/cbor/libcbor.a esp-idf/coap/libcoap.a esp-idf/esp_adc_cal/libesp_adc_cal.a esp-idf/esp_gdbstub/libesp_gdbstub.a esp-idf/esp_hid/libesp_hid.a esp-idf/esp_https_ota/libesp_https_ota.a esp-idf/esp_local_ctrl/libesp_local_ctrl.a esp-idf/esp_serial_slave_link/libesp_serial_slave_link.a esp-idf/esp_websocket_client/libesp_websocket_client.a esp-idf/expat/libexpat.a esp-idf/fatfs/libfatfs.a esp-idf/sdmmc/libsdmmc.a esp-idf/wear_levelling/libwear_levelling.a esp-idf/freemodbus/libfreemodbus.a esp-idf/jsmn/libjsmn.a esp-idf/libsodium/liblibsodium.a esp-idf/mqtt/libmqtt.a esp-idf/openssl/libopenssl.a esp-idf/spiffs/libspiffs.a esp-idf/unity/libunity.a esp-idf/wifi_provisioning/libwifi_provisioning.a esp-idf/protocomm/libprotocomm.a esp-idf/bt/libbt.a -L/home/f/esp/esp-idf/components/bt/controller/lib -lbtdm_app esp-idf/protobuf-c/libprotobuf-c.a esp-idf/mdns/libmdns.a esp-idf/console/libconsole.a esp-idf/json/libjson.a esp-idf/ui/libui.a esp-idf/user_driver/libuser_driver.a esp-idf/MerusAudio/libMerusAudio.a esp-idf/libfaad/liblibfaad.a esp-idf/fdk-aac/libfdk-aac.a esp-idf/mad/libmad.a esp-idf/inih_port/libinih_port.a esp-idf/url_parser/liburl_parser.a esp-idf/http/libhttp.a esp-idf/url_parser/liburl_parser.a esp-idf/http/libhttp.a esp-idf/controls/libcontrols.a esp-idf/vector/libvector.a esp-idf/xtensa/libxtensa.a esp-idf/mbedtls/libmbedtls.a esp-idf/efuse/libefuse.a esp-idf/bootloader_support/libbootloader_support.a esp-idf/app_update/libapp_update.a esp-idf/esp_ipc/libesp_ipc.a esp-idf/spi_flash/libspi_flash.a esp-idf/esp_system/libesp_system.a esp-idf/soc/libsoc.a esp-idf/vfs/libvfs.a esp-idf/esp_eth/libesp_eth.a esp-idf/tcpip_adapter/libtcpip_adapter.a esp-idf/esp_netif/libesp_netif.a esp-idf/esp_event/libesp_event.a esp-idf/wpa_supplicant/libwpa_supplicant.a esp-idf/nvs_flash/libnvs_flash.a esp-idf/esp_wifi/libesp_wifi.a esp-idf/lwip/liblwip.a esp-idf/log/liblog.a esp-idf/heap/libheap.a esp-idf/esp_ringbuf/libesp_ringbuf.a esp-idf/driver/libdriver.a esp-idf/pthread/libpthread.a esp-idf/espcoredump/libespcoredump.a esp-idf/perfmon/libperfmon.a esp-idf/esp32/libesp32.a esp-idf/esp_common/libesp_common.a esp-idf/esp_timer/libesp_timer.a esp-idf/freertos/libfreertos.a esp-idf/newlib/libnewlib.a esp-idf/cxx/libcxx.a esp-idf/app_trace/libapp_trace.a esp-idf/nghttp/libnghttp.a esp-idf/esp-tls/libesp-tls.a esp-idf/tcp_transport/libtcp_transport.a esp-idf/esp_http_client/libesp_http_client.a esp-idf/esp_http_server/libesp_http_server.a esp-idf/ulp/libulp.a esp-idf/mbedtls/mbedtls/library/libmbedtls.a esp-idf/mbedtls/mbedtls/library/libmbedcrypto.a esp-idf/mbedtls/mbedtls/library/libmbedx509.a esp-idf/soc/soc/esp32/libsoc_esp32.a /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libcoexist.a /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libcore.a /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libespnow.a /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libmesh.a /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libnet80211.a /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libpp.a /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/librtc.a /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libsmartconfig.a /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libphy.a esp-idf/xtensa/libxtensa.a esp-idf/mbedtls/libmbedtls.a esp-idf/efuse/libefuse.a esp-idf/bootloader_support/libbootloader_support.a esp-idf/app_update/libapp_update.a esp-idf/esp_ipc/libesp_ipc.a esp-idf/spi_flash/libspi_flash.a esp-idf/esp_system/libesp_system.a esp-idf/soc/libsoc.a esp-idf/vfs/libvfs.a esp-idf/esp_eth/libesp_eth.a esp-idf/tcpip_adapter/libtcpip_adapter.a esp-idf/esp_netif/libesp_netif.a esp-idf/esp_event/libesp_event.a esp-idf/wpa_supplicant/libwpa_supplicant.a esp-idf/nvs_flash/libnvs_flash.a esp-idf/esp_wifi/libesp_wifi.a esp-idf/lwip/liblwip.a esp-idf/log/liblog.a esp-idf/heap/libheap.a esp-idf/esp_ringbuf/libesp_ringbuf.a esp-idf/driver/libdriver.a esp-idf/pthread/libpthread.a esp-idf/espcoredump/libespcoredump.a esp-idf/perfmon/libperfmon.a esp-idf/esp32/libesp32.a esp-idf/esp_common/libesp_common.a esp-idf/esp_timer/libesp_timer.a esp-idf/freertos/libfreertos.a esp-idf/newlib/libnewlib.a esp-idf/cxx/libcxx.a esp-idf/app_trace/libapp_trace.a esp-idf/nghttp/libnghttp.a esp-idf/esp-tls/libesp-tls.a esp-idf/tcp_transport/libtcp_transport.a esp-idf/esp_http_client/libesp_http_client.a esp-idf/esp_http_server/libesp_http_server.a esp-idf/ulp/libulp.a esp-idf/mbedtls/mbedtls/library/libmbedtls.a esp-idf/mbedtls/mbedtls/library/libmbedcrypto.a esp-idf/mbedtls/mbedtls/library/libmbedx509.a esp-idf/soc/soc/esp32/libsoc_esp32.a /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libcoexist.a /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libcore.a /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libespnow.a /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libmesh.a /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libnet80211.a /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libpp.a /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/librtc.a /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libsmartconfig.a /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libphy.a esp-idf/xtensa/libxtensa.a esp-idf/mbedtls/libmbedtls.a esp-idf/efuse/libefuse.a esp-idf/bootloader_support/libbootloader_support.a esp-idf/app_update/libapp_update.a esp-idf/esp_ipc/libesp_ipc.a esp-idf/spi_flash/libspi_flash.a esp-idf/esp_system/libesp_system.a esp-idf/soc/libsoc.a esp-idf/vfs/libvfs.a esp-idf/esp_eth/libesp_eth.a esp-idf/tcpip_adapter/libtcpip_adapter.a esp-idf/esp_netif/libesp_netif.a esp-idf/esp_event/libesp_event.a esp-idf/wpa_supplicant/libwpa_supplicant.a esp-idf/nvs_flash/libnvs_flash.a esp-idf/esp_wifi/libesp_wifi.a esp-idf/lwip/liblwip.a esp-idf/log/liblog.a esp-idf/heap/libheap.a esp-idf/esp_ringbuf/libesp_ringbuf.a esp-idf/driver/libdriver.a esp-idf/pthread/libpthread.a esp-idf/espcoredump/libespcoredump.a esp-idf/perfmon/libperfmon.a esp-idf/esp32/libesp32.a esp-idf/esp_common/libesp_common.a esp-idf/esp_timer/libesp_timer.a esp-idf/freertos/libfreertos.a esp-idf/newlib/libnewlib.a esp-idf/cxx/libcxx.a esp-idf/app_trace/libapp_trace.a esp-idf/nghttp/libnghttp.a esp-idf/esp-tls/libesp-tls.a esp-idf/tcp_transport/libtcp_transport.a esp-idf/esp_http_client/libesp_http_client.a esp-idf/esp_http_server/libesp_http_server.a esp-idf/ulp/libulp.a esp-idf/mbedtls/mbedtls/library/libmbedtls.a esp-idf/mbedtls/mbedtls/library/libmbedcrypto.a esp-idf/mbedtls/mbedtls/library/libmbedx509.a esp-idf/soc/soc/esp32/libsoc_esp32.a /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libcoexist.a /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libcore.a /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libespnow.a /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libmesh.a /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libnet80211.a /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libpp.a /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/librtc.a /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libsmartconfig.a /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libphy.a esp-idf/xtensa/libxtensa.a esp-idf/mbedtls/libmbedtls.a esp-idf/efuse/libefuse.a esp-idf/bootloader_support/libbootloader_support.a esp-idf/app_update/libapp_update.a esp-idf/esp_ipc/libesp_ipc.a esp-idf/spi_flash/libspi_flash.a esp-idf/esp_system/libesp_system.a esp-idf/soc/libsoc.a esp-idf/vfs/libvfs.a esp-idf/esp_eth/libesp_eth.a esp-idf/tcpip_adapter/libtcpip_adapter.a esp-idf/esp_netif/libesp_netif.a esp-idf/esp_event/libesp_event.a esp-idf/wpa_supplicant/libwpa_supplicant.a esp-idf/nvs_flash/libnvs_flash.a esp-idf/esp_wifi/libesp_wifi.a esp-idf/lwip/liblwip.a esp-idf/log/liblog.a esp-idf/heap/libheap.a esp-idf/esp_ringbuf/libesp_ringbuf.a esp-idf/driver/libdriver.a esp-idf/pthread/libpthread.a esp-idf/espcoredump/libespcoredump.a esp-idf/perfmon/libperfmon.a esp-idf/esp32/libesp32.a esp-idf/esp_common/libesp_common.a esp-idf/esp_timer/libesp_timer.a esp-idf/freertos/libfreertos.a esp-idf/newlib/libnewlib.a esp-idf/cxx/libcxx.a esp-idf/app_trace/libapp_trace.a esp-idf/nghttp/libnghttp.a esp-idf/esp-tls/libesp-tls.a esp-idf/tcp_transport/libtcp_transport.a esp-idf/esp_http_client/libesp_http_client.a esp-idf/esp_http_server/libesp_http_server.a esp-idf/ulp/libulp.a esp-idf/mbedtls/mbedtls/library/libmbedtls.a esp-idf/mbedtls/mbedtls/library/libmbedcrypto.a esp-idf/mbedtls/mbedtls/library/libmbedx509.a esp-idf/soc/soc/esp32/libsoc_esp32.a /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libcoexist.a /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libcore.a /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libespnow.a /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libmesh.a /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libnet80211.a /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libpp.a /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/librtc.a /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libsmartconfig.a /home/f/esp/esp-idf/components/esp_wifi/lib/esp32/libphy.a /home/f/esp/esp-idf/components/xtensa/esp32/libhal.a -u esp_app_desc -L /home/f/esp/esp-idf/components/esp_rom/esp32/ld -T esp32.rom.newlib-time.ld -T esp32.rom.ld -T esp32.rom.libgcc.ld -T esp32.rom.newlib-data.ld -T esp32.rom.syscalls.ld -T esp32.rom.newlib-funcs.ld -u vfs_include_syscalls_impl -L /home/f/esp/esp-idf/components/esp_wifi/lib/esp32 -u pthread_include_pthread_impl -u pthread_include_pthread_cond_impl -u pthread_include_pthread_local_storage_impl -L /home/f/esp/ESP32_MP3_Decoder/build/esp-idf/esp32 -T esp32_out.ld -u app_main -L /home/f/esp/ESP32_MP3_Decoder/build/esp-idf/esp32/ld -T esp32.project.ld -L /home/f/esp/esp-idf/components/esp32/ld -T esp32.peripherals.ld -u call_user_start_cpu0 -u ld_include_panic_highint_hdl -Wl,--gc-sections -Wl,--undefined=uxTopUsedPriority -lm esp-idf/newlib/libnewlib.a -u newlib_include_locks_impl -u newlib_include_heap_impl -u newlib_include_syscalls_impl -u newlib_include_pthread_impl -lgcc -u __cxa_guard_dummy -lstdc++ esp-idf/pthread/libpthread.a -u __cxx_fatal_exception esp-idf/app_trace/libapp_trace.a -lgcov esp-idf/app_trace/libapp_trace.a -lgcov -lc && :
/home/f/.espressif/tools/xtensa-esp32-elf/esp-2020r2-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld: esp-idf/audio_player/libaudio_player.a(audio_player.c.obj):(.literal.start_decoder_task+0x8): undefined reference to `fdkaac_decoder_task'
/home/f/.espressif/tools/xtensa-esp32-elf/esp-2020r2-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld: esp-idf/audio_player/libaudio_player.a(audio_player.c.obj):(.literal.start_decoder_task+0x14): undefined reference to `libfaac_decoder_task'
/home/f/.espressif/tools/xtensa-esp32-elf/esp-2020r2-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld: esp-idf/audio_player/libaudio_player.a(audio_player.c.obj):(.literal.start_decoder_task+0x20): undefined reference to `mp3_decoder_task'
collect2: error: ld returned 1 exit status
ninja failed with exit code 1
I removed cyclic dependencies, checked that the components are listed in PRIV_REQUIRES using the default components directory tree, checked that the functions are not defined or implemented static. Also I found the compiled static libraries like esp-idf/mp3_decoder/libmp3_decoder.a with references required.
Any help to solve this issue would be appreciated.
