build errors in ESP-IDF
Arnie$$ESP
Postby Arnie$$ESP » Sun Jan 03, 2021 1:59 pm
I try to install the IDF now more than two weeks.
1. I have a Windows 7 PC. I try to work the commands in different folder. IDF command prompt work.
2. The IDF Installer make all right, but I get errors when I try to start the "hello_world" or all other projects with the command "idf.py build" or "idf.py menuconfig". Every time I get the same error.
-- Detecting CXX compile features - done
-- Building ESP-IDF components for target esp32
-- Project sdkconfig file C:/esp32/esp-idf-master/hello_world/sdkconfig
CMake Error at ../tools/cmake/component.cmake:305 (message):
Include directory
'C:/esp32/esp-idf-master/components/mbedtls/mbedtls/include' is not a
directory.
../tools/cmake/component.cmake:475 (__component_add_include_dirs)
../components/mbedtls/CMakeLists.txt:4 (idf_component_register)
See also "C:/esp32/esp-idf-master/hello_world/build/CMakeFiles/CMakeOutput.log".
cmake failed with exit code 1
c:\esp32\esp-idf-master\hello_world>
3. The last commands in the CMakeOutput.log are
arg [c:/espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/crtend.o] ==> ignore
arg [c:/espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/crtn.o] ==> ignore
collapse library dir [c:/espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.4.0] ==> [C:/Espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/lib/gcc/xtensa-esp32-elf/8.4.0]
collapse library dir [c:/espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin/../lib/gcc] ==> [C:/Espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/lib/gcc]
collapse library dir [c:/espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/lib] ==> [C:/Espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/xtensa-esp32-elf/lib]
implicit libs: [stdc++;m;gcc;c;nosys;c;gcc]
implicit dirs: [C:/Espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/lib/gcc/xtensa-esp32-elf/8.4.0;C:/Espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/lib/gcc;C:/Espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/xtensa-esp32-elf/lib]
implicit fwks: []
Did anyone similar failure or know how I can solve it?
ESP_Jan
Re: build errors in ESP-IDF
Postby ESP_Jan » Mon Jan 04, 2021 5:50 am
Hi Arnie,
this looks as though you cloned the esp-idf repository and missed the --recursive option.
To fix this, run the following command inside your esp-idf directory.
git submodule update --init
Jan
Users browsing this forum: derveroonibo and 83 guests
