What good ESP32 TFT libraries compatible with ESP-IDF are there that are updated regularly?
I like loboris' library, but he uses his own modified SPI library and I'm seeing some issues with my other SPI devices and I'm not sure if it's because the two libraries are 'clashing' (I don't yet know the underlying SPI well enough).
What libraries do you guys know of?
Ideally it would have:
- Support for ILI9431 controller.
- Require drawing fonts, jpegs
- 3 or 4 wire SPI support
Many thanks in advance.
ESP32 TFT Library using IDF?
Re: ESP32 TFT Library using IDF?
Thank you @Victoria Nope
You could check HAGL which is a lightweight hardware agnostic graphics library. It does not contain any hardware or platform specific code. You can use it with any microcontroller including ESP32 and esp-idf.
Being hardware agnostic means user has to provide a HAL. There is a HAL for ESP32 which supports most hobbyist displays. There is also an SDL2 HAL for normal computers. You can use the latter to develop graphics code on your laptop.
For example when I was doing the Old school demo effects I first coded them on my laptop. When I was happy with the effects I used the same code for ESP32. I also did some other proof of concepts with the library such as ESP video player.
Users browsing this forum: MicroController and 117 guests
