ESP IDF: Station + soft-AP (WIFI_MODE_APSTA) There is no working example - why? Where is?
ryanf55
Re: ESP IDF: Station + soft-AP (WIFI_MODE_APSTA) There is no working example - why? Where is?
Postby ryanf55 » Wed May 13, 2020 6:51 pm
In follow up to my previous post, adding in a few time delays between tearing down AP and starting STA helped. Also, I turned off nvs_flash for WiFi as I think that was causing the corruption when starting in STA mode.
Here's my menuconfig changes.
[OFF ] Wi-Fi -> WiFi NVS flash
[OFF] Phy ->Store phy calibration data in NVS
I was seeing brownouts earlier in the transition and increased
[2.7v] * ESP32-specific -> Brownout Voltage Level
For debugging
[On] WiFi -> Enable Wifi debug Log
[Verbose] WiFi -> WiFi debug log level
If anyone has seen similar issues when trying to use both WiFi modes, please share if you had any better resolutions.
mcmega
Postby mcmega » Tue Dec 22, 2020 1:45 pm
This works well for string parameters.
strncpy((char *)ap_config.ap.password, configDev.apPSK, strlen(configDev.apPSK));
Tell me, how to properly set the WiFi channel in the Access Point mode?
Postby ESP_Sprite » Tue Dec 22, 2020 2:52 pm
That is... I don't think you understand what that does exactly and why one would use strncpy. Str[n]cpy already stops copies as much bytes as are in configDev.aPSK; to specifically set it as a limit with the strlen parameter does nothing useful. In contrast, if configDev.apPSK is too large, you can overwrite the memory of ap_config and corrupt stuff and make your app crash and your strncpy will do nothing to stop it. Correct method is:
strncpy((char *)ap_config.ap.password, configDev.apPSK, sizeof(ap_config.ap.password));
This will copy bytes up to either the length of configDev.apPSK or until it doesn't fit into ap_config.ap.password anymore, whichever happens earlier.
Wrt your question: as the docs indicate, the ap_config.ap struct has a channel member, so it would be
ap_config.ap.channel=4;
pranjal.jamdade
Postby pranjal.jamdade » Wed Jun 23, 2021 8:46 am
Did any one find a proper solution for accessing both AP and STA mode ? Once AP mode is getting after receving SSID+PASS , i am facing issue for station mode.
If any one could suggest please help me out.
Thanks in advance
Ritesh
Contact:
Postby Ritesh » Thu Jul 08, 2021 8:02 pm
Thanks in advance
Is your issue has been resolved or still looking for solution?
Regards,
Ritesh Prajapati
pranjal.jamdade
Postby pranjal.jamdade » Fri Jul 09, 2021 5:10 am
Hello ,
Still Looking for Proper Solution for it.
Thanks & Regards
Pranjal
Ritesh
Contact:
Postby Ritesh » Fri Jul 23, 2021 6:35 pm
Hello ,
Thanks & Regards
Pranjal
Any luck for working or still looking for solution. Let me know if need any help from my side.
Regards,
Ritesh Prajapati
monkeyinapocket
Postby monkeyinapocket » Tue Oct 05, 2021 8:11 pm
i'm also looking for a good solution, it would be great if you could just stop "offering your help" and provide a simple example instead because you said it would work....
With the current exmaples it is/was not possible for me to provide a SoftAP (that worked) and also to connect to a available WiFi.
It would be awesome if you could just share your proposed working snippets.
Thanks in advance.
Best Thomas
Ritesh
Contact:
Postby Ritesh » Sun Oct 10, 2021 10:51 am
Thanks in advance.
Best Thomas
Hello
Can you please share me example which you are trying and facing issues at your end?
so that i will look it at my end and help for the same.
Regards,
Ritesh Prajapati
monkeyinapocket
Postby monkeyinapocket » Sun Oct 17, 2021 8:47 pm
Sorry, it took me some time to prepare the example. The following code snipped should be able to create an AP an also connect to a available WiFi - it would be great if you can tell me, what i'm doing wrong.
Thanks in advance,
Best Monkeyinapocket
#include <cstring>
#include "freertos/task.h"
#include "freertos/event_groups.h"
#include "esp_system.h"
#include "esp_wifi.h"
#include "esp_event.h"
#include "esp_log.h"
#include "nvs_flash.h"
#include "lwip/err.h"
#include "lwip/sys.h"
#define WIFI_CONNECTED_BIT BIT0
#define WIFI_FAIL_BIT      BIT1
static const char *TAG = "test";
static EventGroupHandle_t s_wifi_event_group;
static wifi_config_t wifi_config;
static void wifi_event_handler(void* arg, esp_event_base_t event_base,
                               int32_t event_id, void* event_data)
    if (event_id == WIFI_EVENT_AP_STACONNECTED) {
        wifi_event_ap_staconnected_t* event = (wifi_event_ap_staconnected_t*) event_data;
    } else if (event_id == WIFI_EVENT_AP_STADISCONNECTED) {
        wifi_event_ap_stadisconnected_t* event = (wifi_event_ap_stadisconnected_t*) event_data;
void wifi_init_softap(void)
    esp_netif_create_default_wifi_ap();
    wifi_init_config_t cfg = WIFI_INIT_CONFIG_DEFAULT();
    ESP_ERROR_CHECK(esp_wifi_init(&cfg));
    ESP_ERROR_CHECK(esp_event_handler_instance_register(WIFI_EVENT,
                                                        ESP_EVENT_ANY_ID,
                                                        &wifi_event_handler,
                                                        NULL,
                                                        NULL));
    const char* ssid = "ESPTest";
    const char* pw = "testtest";
    std::strcpy(reinterpret_cast<char *>(wifi_config.ap.ssid), ssid);
    std::strcpy(reinterpret_cast<char *>(wifi_config.ap.password), pw);
    wifi_config.ap.ssid_len = static_cast<uint8_t>(strlen(ssid));
    wifi_config.ap.channel = 1;
    wifi_config.ap.max_connection = 1;
    wifi_config.ap.authmode = WIFI_AUTH_WPA_WPA2_PSK;
    if (strlen(pw) == 0) {
        wifi_config.ap.authmode = WIFI_AUTH_OPEN;
    ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_APSTA));
    ESP_ERROR_CHECK(esp_wifi_set_config(WIFI_IF_AP, &wifi_config));
    ESP_ERROR_CHECK(esp_wifi_start());
static int s_retry_num = 0;
static int maxRetry = 5;
static void sta_event_handler(void* arg, esp_event_base_t event_base,
    if (event_base == WIFI_EVENT && event_id == WIFI_EVENT_STA_START) {
        esp_wifi_connect();
    } else if (event_base == WIFI_EVENT && event_id == WIFI_EVENT_STA_DISCONNECTED) {
        if (s_retry_num < maxRetry) {
            esp_wifi_connect();
            s_retry_num++;
            ESP_LOGI(TAG, "retry to connect to the AP");
        } else {
            xEventGroupSetBits(s_wifi_event_group, WIFI_FAIL_BIT);
        ESP_LOGI(TAG,"connect to the AP fail");
    } else if (event_base == IP_EVENT && event_id == IP_EVENT_STA_GOT_IP) {
        ip_event_got_ip_t* event = (ip_event_got_ip_t*) event_data;
        ESP_LOGI(TAG, "got ip:" IPSTR, IP2STR(&event->ip_info.ip));
        s_retry_num = 0;
        xEventGroupSetBits(s_wifi_event_group, WIFI_CONNECTED_BIT);
void wifi_init_sta(void)
    s_wifi_event_group = xEventGroupCreate();
    esp_netif_create_default_wifi_sta();
    esp_event_handler_instance_t instance_any_id;
    esp_event_handler_instance_t instance_got_ip;
                                                        ESP_EVENT_ANY_ID,
                                                        &sta_event_handler,
                                                        NULL,
                                                        &instance_any_id));
    ESP_ERROR_CHECK(esp_event_handler_instance_register(IP_EVENT,
                                                        IP_EVENT_STA_GOT_IP,
                                                        &sta_event_handler,
                                                        NULL,
                                                        &instance_got_ip));
    const char* ssid = "TestSSID";
    std::strcpy(reinterpret_cast<char *>(wifi_config.sta.ssid), ssid);
    std::strcpy(reinterpret_cast<char *>(wifi_config.sta.password), pw);
    wifi_config.sta.threshold.authmode = WIFI_AUTH_WPA2_PSK;
    wifi_config.sta.channel = 2;
    wifi_config.sta.pmf_cfg.capable = true;
    wifi_config.sta.pmf_cfg.required = false;
    ESP_LOGI(TAG, "Test -> %s %s.", wifi_config.sta.ssid, wifi_config.sta.password);
    ESP_ERROR_CHECK(esp_wifi_set_config(WIFI_IF_STA, &wifi_config) );
    //ESP_ERROR_CHECK(esp_wifi_start());
    ESP_LOGI(TAG, "wifi_init_sta finished.");
    /* Waiting until either the connection is established (WIFI_CONNECTED_BIT) or connection failed for the maximum
     * number of re-tries (WIFI_FAIL_BIT). The bits are set by event_handler() (see above) */
    EventBits_t bits = xEventGroupWaitBits(s_wifi_event_group,
                                           WIFI_CONNECTED_BIT | WIFI_FAIL_BIT,
                                           pdFALSE,
                                           pdFALSE,
                                           portMAX_DELAY);
    /* xEventGroupWaitBits() returns the bits before the call returned, hence we can test which event actually
     * happened. */
    if (bits & WIFI_CONNECTED_BIT) {
        ESP_LOGI(TAG, "connected to ap");
    } else if (bits & WIFI_FAIL_BIT) {
        ESP_LOGI(TAG, "Failed to connect");
    } else {
        ESP_LOGE(TAG, "UNEXPECTED EVENT");
    /* The event will not be processed after unregister */
    ESP_ERROR_CHECK(esp_event_handler_instance_unregister(IP_EVENT, IP_EVENT_STA_GOT_IP, instance_got_ip));
    ESP_ERROR_CHECK(esp_event_handler_instance_unregister(WIFI_EVENT, ESP_EVENT_ANY_ID, instance_any_id));
    vEventGroupDelete(s_wifi_event_group);
extern "C" void app_main(void)
    //Initialize NVS
    esp_err_t ret = nvs_flash_init();
    if (ret == ESP_ERR_NVS_NO_FREE_PAGES || ret == ESP_ERR_NVS_NEW_VERSION_FOUND) {
        ESP_ERROR_CHECK(nvs_flash_erase());
    ESP_ERROR_CHECK(ret);
    ESP_ERROR_CHECK(esp_netif_init());
    ESP_ERROR_CHECK(esp_event_loop_create_default());
   wifi_init_softap();
   vTaskDelay(10000);
   wifi_init_sta();
Users browsing this forum: Bhaydar, ok-home and 122 guests
